Likes Likes:  5
Results 1 to 3 of 3
Thread: Front feels like it bottoms
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Default Front feels like it bottoms
    2008 GL1800 trike
    29k on ODM
    This customer complained of a poor ride when going over bumps. He said "it feels like the front bottoms." He also had lots of front fender slapping.
    Below is what I removed. His spring stack included a Honda OEM spring and an OEM spacer. Between the spring and spacer was a 2nd spacer.
    FYI ... adding spacers to springs can damage a spring. On trikes it's sometimes done to increase ground clearance. Unfortunately, it can damage the spring, and overtime, as the spring becomes more damaged, will provide an extremely poor ride.
    Yesterday, his spring length measured 12.75". According to Honda, minimum length is 12.94". Today they measure 13.125". Because they have lengthened, that's a sure sign that they were damaged. They also came out with a slight warp to them, another indication they were damaged. Today, the warp has lessoned.
    I installed a Traxxion standard load spring. He already had extended caps of his forks.
    He left with nearly the same ground clearance, a smooth ride, and no fender slapping. Using a spring that is known to add lift to the suspension is by far a better fix then putting a spring under more pressure trying to accomplish the same.
    Jun 2010
    Indianapolis, In.
    29K!!!! It was time for new springs at about 24K, especially on a trike w/a rake kit!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Guess that confirms the spacer damaged the springs.
  1. Replies: 45
    Last Post: 05-15-2019, 03:41 PM
  2. On curves to the left it feels softer than right curves
    By tysavell in forum Outrigger Style Trikes
    Last Post: 08-03-2018, 10:54 PM
  3. HELP. What front end do I have?
    By shadowrider69 in forum Tires, Wheels, Brakes, Front End
    Last Post: 04-15-2013, 07:20 AM
  4. Front End
    By Dean H in forum Stallion Trikes
    Last Post: 01-04-2012, 12:34 PM
  5. Front End.
    By grumpysmithy in forum General Discussion
    Last Post: 07-22-2011, 10:16 AM
