Likes Likes:  23
Results 1 to 20 of 30
Thread: Maintenance time
    10+ Posts Bucco33!'s Avatar
    Jun 2018
    Daytona Beach Fla. USA
    Default Maintenance time
    I bought a set of Rhino ramps to help with my maintenance as my Pit Bull lift is limited now that Pearl is triked. I used 1 on the front wheel to drive up on and changed my oil & filter. Once up on the chock I kicked the chock to the side (lesson learned from forum member)!
    Made for easy removal of the front of the belly pan and removing drain bolt and filter! I use Rotella T-5 15W40 and a Pure one PL16410 filter. Milage at 92,574. I put both chocks behind rear wheels and backed the trike up on them. I figure with me at 260 and the wife at 15^ish and all the backing 2 up and with a trailer we've done it ain't hurting the starter motor! Went up and on no problem with me off of the trike. I installed a chrome bumper and Roadsmith mud flaps and adjusted shocks 2 up from bottom. Experimenting with shock settings and tire pressures. 30psi in rear for 2 up seems to work best and 40psi in front Cobra. I have Traxxion cartridges and springs in the front and a Kuryaken fork brace.
    So far I'm liking this kit but am thinking of either lowering my footpegs or removing them all together and putting my 13EE's on the running boards as my knees are to far up in the air for long rides! I also need to invest in some highway pegs.
    Anyway I've picked up some valuable "how to" tip's on this forum that have made owning and maintaining my trike much easier and I want to say THANKS to all that contribute!
  2. Roadsmith banner
  3. #2
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    We live TO learn. And Love. And laugh.
  4. #3
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Have always ran 22-24 lbs in rear tires .have had success with this.08wing/roadsmith kit 98000 miles
  5. #4
    Jun 2018
    Quote Originally Posted by Lucky View Post
    Interesting 🧐 I might try lowering the rear pressures and see if it smooths the ride.
    "08 Audio Comfort Nav with Roadsmith trike kit Traxxion AK20 cartridges and springs and Kurakan fork brace. Tom Simmons modified seat. 2010 Aluma MCTXL pull behind. 2017 Ducati Multistrada 1200S Touring with QD full exhaust and Rapid Bike EVO tuner.
  6. #5
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by Bucco33! View Post
    Interesting �� I might try lowering the rear pressures and see if it smooths the ride.
    Jamie,
    It will big time. Start at 22lbs, that is what myself and the vast majority of members here have run for years.
    Jun 2018
    Jamie,
    BIG difference in ride quality so far on our flat hot roads! Thanks for the info!! I'm set at 23psi by my digital gauges and my TPMS registers one pound lighter at 22psi. I was going by the manufacturers recommendation. Do you raise the pressures when in the twisty's or if 2 up and towing a trailer? As a two wheeler and as a darksider I ran my ROF tires at 28 to 34 psi depending on my situation. Just wondering how much that applies to a trike!?
    Thanks again for helping out a trike "newbie"
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Told ya! It makes a HUGE difference. Just leave at what you have it at, it will handle the twisties, two up and trailering with no problem.
    10+ Posts Wind Therapy's Avatar
    Jul 2018
    Fredericksburg, VA, USA
    Default Bucco beat me to the punch . . .
    Bucco,
    You must be psychotic! You posted almost verbatim what I was about to do. I too was a Dark Sider, and ran my ROF Dunlop Wintersport @ 28PSI. I got 30k miles+ out of each of 3 such tires on my '04 GL1800.
    I was going to ask the same tire pressure and shock setting questions. My SO and I are pretty near 500lbs. when two-up. I was hoping that I didn't have to play with TP's and shock settings each time I needed to go two-up. I ride 120 miles round trip on I-95 between Fredericksburg, VA and Washington, DC almost daily, solo. But we go two-up on the weekends and some evenings. I'm looking for suggestions for a "Happy Medium" to avoid all the extra work.
    All recommendations will be considered. Thanx in advance . . .
    Dave Calahan
    Fredericksburg, VA
  10. Roadsmith banner
  11. #9
    Jun 2018
    Quote Originally Posted by Wind Therapy View Post
    Bucco,
    Dave Calahan
    Fredericksburg, VA
    My wife loved the “psychotic” description😂!
    Dave I would listen to Lucky and Papa Zook and their recommendations. They’ve been at this trike thing a heck of a lot longer then me!
    I would check your shock settings also. I’ve settled on 2 up from the bottom for now (it is a pain in the rear to do for full sized folk😳 without a lift) . I don’t envy your commute at all😱 . Good luck and be safe!
  12. #10
    Sep 2016
    Springfield, Mass. USA
    I'm also going to try 22-24 lbs in rear(s) thanks for the info here..
    Not sure what I now have in there NOW but going out this morning for a test ride (hope rain stays away)
  13. #11
    Mar 2011
    mountain home,ar. USA
    I know many like the 22 -24 psi in the rears. However, for me, I have found that with two-up I can feel my Michelin rear tires feeling "loosey goosey" when riding the twisties aggressively which I do on a regular basis.
    As I said in another post every rider needs to find their personal "happy space" on some of these settings as long as they don't create a dangerous situation. I've found mine.
  14. #12
    Sep 2012
    Lakeland, FL
    AT Brother Zook's recommendation, I'm now running 23 psi in the rears, he was right, better ride. However, I've not tested that in the twisties, so not sure what I'll find when Maggie Valley rolls around. No matter, it's all good.
  15. #13
    Mar 2011
    Love Maggie Valley and have used it as base camp several times. So many neat roads to ride other than The Dragon which I have several t-shirts from.
    If you get a chance go up around Little Switzerland too. Oh heck, just throw a dart and go riding!
  16. Roadsmith banner
  17. #14
    Sep 2012
    Lakeland, FL
    Thanks Mike, appreciate the kind words. Plan to do 3 days at the TT ride in at Maggie, then spend some time with an old Post Office buddy now living in the Sevierville TN area, rides a Harley and we have a great time exploring. I'm definitely looking fwd to this ride, but checking the weather at that time is not looking good, but perhaps it will improve. Looks like we will have a good crowd, but if the threat of rain is bad, many will drop out, hope the Weather Gods will be kind. Living in the flat lads of Florida, I don't get much opportunity to ride those majestic mountain roads, having lived near the Skyline Drive area for a number of years, I miss it.
  18. #15
    Mar 2011
    You know your trike has wheels, right? You're close enough to make a long weekend trip to MV! Some of those north Georgia roads ain't bad either. Just sayin...…..
  19. #16
    Jun 2018
    Quote Originally Posted by mhgoldwing View Post
    Looking forward to getting back up there and seeing how our trike handles on all the roads we’ve ridden over the years! Going to be different not “peg scraping “ for sure 😳.
    Maybe I’ll find a single rail trailer and tow the DUC up behind the trike lol
  20. #17
    Sep 2012
    Lakeland, FL
    Oh yes, Roger That.....Catching up with some of my 'stuff' so we can do that. Millie loves to ride 'back set', so we are compatible.
  21. #18
    Mar 2011
    Duc! Now you're talking some serious fun! I don't heal fast enough any longer to ride one of those and I would surely get myself into trouble. My ST1300 will have to suffice at a gentlemanly pace.
  22. #19
    Sep 2016
    Ok today (8/22/18) I just lowered my air to 22lbs (rear tires)... I managed to ride it maybe a mile or so.. (only time I had to spear, after adjusting air)... I have to admit that it did indeed seem to ride much better... Tomorrow I'm going on a 350ish mile trip and towing a trailer... I will totally see how much smother this trike is now.. I'll let you all know after I return Sunday evening........
  23. #20
    Sep 2016
    Ok as promised! Just got home from the Trike rally in the catskills, (had a ball /by the way) anyways WOW what a difference lowering my rears down to 22 lbs per tire.......The trike is now smoother (ride) then ever.....Thank you, thank you, thank you!
    Before lowering tire pressure, I could really actually feel every tiny pebble i ran over over, it was like driving a tractor with wheels, now it's smooth,
  1. Stallion Parts & Maintenance Reference
    By Mattel in forum Stallion Trikes
    Last Post: 06-26-2022, 06:06 PM
  2. Motor Trike Maintenance
    By Papa Zook in forum Motor Trike
    Last Post: 04-30-2015, 11:44 AM
  3. 10K maintenance
    By rayg5102 in forum Harley Trike Conversions
    Last Post: 10-11-2013, 03:38 PM
  4. Does anyone know the maintenance schedule?
    By Boscoporp in forum Honda Trikes
    Last Post: 11-22-2010, 01:33 PM
  5. Necessary maintenance
    By spiritdream in forum General Discussion
    Last Post: 06-02-2010, 11:59 AM
