Likes Likes:  7
Thanks Thanks:  1
Results 1 to 7 of 7
Thread: Tri Glide Reverse System Diagnostic Tips
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Default Tri Glide Reverse System Diagnostic Tips
    This is from the Fix My Hog website. I would suspect this applies to the Freewheeler also.
    This month, we continue by reviewing a preliminary, basic, diagnostic overview for determining reverse failure on Tri Glide models. Much testing can be completed with, only, a test light and a multimeter. However, a factory Tri Glide supplement manual and a breakout box is also necessary for complete diagnostic testing.There are four DTC’s that can arise for reverse failure. These codes are #s
    P1772 – ECM terminal 4 is shorted to ground
    P1775 – ECM detects an error within the reverse system(this one is rather vague!)
    P1777 – ECM terminal 16 is shorted to ground
    P1778 – ECM terminal 16 is shorted to battery + voltage
    The reverse system may not properly function if battery voltage is less than 10 VDC (volts, DC). It is best to connect the battery to a charger before and during the performance of any diagnostic testing. If the motorcycle does not start and run correctly, the reverse system may not function properly. Trike rear wheels should be safely lifted off the ground with jack stands beneath the rear axle before performing any diagnostic testing that requires depressing the reverse switch.
    It is important to start with these preliminary inspections:
    Check all fuses
    Verify that battery is fully charged
    Verify that the charging system is functioning fully & correctly
    Trip and reset the 150 amp circuit breaker
    Note: when the trip push button is depressed, the reset lever should extend out
    TO RESET, press the reset lever toward the circuit breaker body until an audible click is heard and the lever is fully seated against the circuit breaker body
    If the circuit breaker continues to open under, only, light load conditions or the reverse motor will not correctly function after resetting the circuit breaker and resetting fuses, move forward with diagnostic testing per your supplement service manual.
    This testing should include:
    Reverse enable testing
    Backup light testing
    Reverse actuator testing
    Reverse motor testing
    Circuit breaker testing
    RCM solenoid control circuit testing
    Reverse switch testing
    Ground circuit testing
    Neutral circuit testing
    Accessory circuit testing
    I hope this helps someone. I also hope I never need it.
    Thumbs up
    Good find Michael
    Oct 2017
    St. Louis, MO USA
    Thanks Jack. Have you ever used a breakout box on a Harley? I didn't know what it was, so I Googled it.
    If the Mods approve, maybe they can make this a sticky.
    Not on a Harley, on cars and trucks yeah
    I have a friend in Daytona that builds them, not cheap but very reliable
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    I'd love to get my greasy little hands on a breakout box.They come up on Ebay now and then.Pricey.Of course you need the cables and overlays or the box is useless.Ive used a DVom with backprobes on my '09 and '14.No dont use paperclips,needles,or other weird crap some of these yingyangs on the internet suggest.
    Short out an ECM/BCM to save 50 bucks is stupid.Nothing says STROKEJOB like someone that uses piercing probes. Kick that guy in the nuts.Had breakfast with a hand at the Flying J in Oklahoma City.
    He told me an indy was trying to find an open in his Dynas main harness and pierced about 3 dozen holes then sealed em up with crazy glue.About 6 months later he needed a new harness cause the boy wonder missed sealing up some holes and moisture got in there.Yeah kick him in the nuts too.
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Get a mechanical from Papa Zook and tell Harley to stick it
    2250+ Posts
    Ocala, Florida
    ​If you've gotten to the point that you've determined your reverse motor is shot, skip going to HD for a new one and take your old one to a local electric motor repair shop. The repair shop will rebuild it for FAR less than HD charges for a new one.
    PC
    Beware of liberals posing as Americans.
  1. Diagnostic connector
    By Freewheeling Ron in forum Harley Tri Glide
    Last Post: 07-08-2017, 12:50 PM
  2. The New Tri Glide getting blacked-out.. cleaning tips?
    By Mixitman in forum Harley Trike Conversions
    Last Post: 07-06-2015, 08:19 PM
  3. Warning Indicators/ diagnostic self test question!
    By mozrocks in forum Yamaha Trikes
    Last Post: 06-28-2015, 07:36 PM
  4. Diagnostic Codes
    By Paw Paw Willie in forum Harley Trike Conversions
    Last Post: 04-05-2012, 06:58 AM
  5. Diagnostic Plug
    By CUNDEL in forum Stallion Trikes
    Last Post: 12-19-2011, 11:35 AM
