LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  9
Results 1 to 13 of 13
Thread: Brakes
    20+ Posts
    Oct 2017
    Spartanburg,SC,29307
    Default Brakes
    I am a long time rider but 34000 miles on a trike. I always felt the the brakes on the trike were poor, mushy and not real effective, I never had to panic stop and glad of it. I just changed to EBC pads and the difference is worth making a post about them. I believe that everyone that has these brake pads will be much safer. The difference is for real!!
    I do not have ABS brakes.
    EBC is a very good product, heat dissipation high = less pedal fade
    Very low dust, We used their brake parts on high end problem jobs on imports for years with very good results
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    I just checked Lyndall page & they are showing pads for the 19 Tri Glides. These were some of the best brakes I ever had on the 2 wheeler. When needed brakes for the 16 Tri , they didn't offer any for the trikes. I called them at the time & was told they didn't make pads for the trikes,but, they were getting calls. So I went with EBC. Much better than HD. I now have a 20 Tri coming so I figured I would check as it had been about 3 yrs. They are listing 2019 Tri, so maybe they got enough calls & have started to make them. There may be more years listed but I didn't check. While the EBC brakes were good, I will go back to Lyndall as soon as the 20 needs some shoes. Great when wet also,plus minimal dust.
    20+ Posts
    Oct 2017
    Bill, I either bought my ebc shoes from J & P or Revzilla, I know they both offered them. I just checked with P & J, they have them for the 2020 models.
    Bill
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Vtrod View Post
    Good to read you're getting better braking with the EBC's.
    On earlier year TG's I think the brakes were hit and miss, mostly miss. I've read a lot of folks not happy with their brakes.
    The brakes on my '11 were great...more than strong enough...could lock up front or back if wanted to. On the '14, they required more pressure than the '11, but still worked well.
    (I'm not sure, but possibly my good braking experience was due to my "breaking in" the brakes?)
    I've ridden a bunch of other folks HD Trikes, but never tried any panic stops on someone elses ride.
    I did ride a few at dealerships. One was horrible, the other two, not so good...not nearly as good as my own '11 or '14.
    That brings me to my current '19. Great brakes, excellent feedback, a whole universe better than previous years...and that is with the stock pads.
    I went with EBC on my '11 after 40K miles. I never had to replace them on my '14. We'll see what's available for my '19 when it comes time to replace them.
    www.DKCustom.com
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Bill
    Thanx Bill
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Kevin, the brakes on the 16 were so crappy, I installed the EBC brakes at 8,000 miles, I think. May be a whole new world on the 20 with the ABS & Brembo Calipers. Breaking in brakes is a big plus when brakes are new. If not satisfied after a time, will not hesitate to get Lyndall. Used them the last 20 yrs or so on every new 2 wheeler I got. Break in right & they were far superior wet or dry .
    20+ Posts
    Oct 2017
    Kevin, I want to tell you how much I have enjoyed your lift kit and coil shocks. When I called to order them, I was told that the trike would ride like a Cadillac instead of a Jeep, she was so right!! A great product!
    bill
    Quote Originally Posted by rae mendonca View Post
    Could you please explain how to break your brakes in? I have never heard that before.
    Brake pads should be bedded in to clean rotors (see rotor maintenance). Start with slow stops ranging from 10-15 mph and increasing in blocks of 10 mph until about 40-50 mph. Repeat this step 2-3 times and resume casual riding. Bedding in brake pads helps prevent glazing and helps to mate the pads to the rotor surface.
  11. #10
    1 very important factor before breaking in your new brakes,
    Clean the rotor faces before installing new pads. I use hot soapy water followed by good rinsing with water. Do not use brake cleaners, they can and will transfer residue to the pads. Avoid touching the linings of the new pads, if you get ANY residue on the pads DO NOT use brake cleaner for the above reason. Lightly scuff pads with some clean new sand paper and blow off with compressed air
  12. #11
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    bill
    Thank you. Very good to hear that you are enjoying the improved ride quality!
    www.DKCustom.com
  13. #12
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Pretty sure the Harley instructions on brake break-in is in your manual, in the same section that covers break-in of the engine.
    What Jack said, but I also avoid any hard stops for the first couple hundred miles.
    www.DKCustom.com
  14. #13
    As Kevin says, The hard stops ( locking up brakes) especially during break in will transfer more materials to the rotor face and can cause high spots eventually warping the rotors ( think of it as the pads being forced against the rotors in 1 spot and sliding the wheels) Bad Ju Ju unless you cannot avoid a wreck
  1. Brakes or no brakes on a sidecar?
    By Jimmyess333 in forum Sidecar Forum
    Last Post: 05-16-2019, 04:55 PM
  2. Rear disc brakes, VERY HARD pedal, weak brakes????
    By TrikerDoone in forum VW Powered Trikes
    Last Post: 05-29-2016, 12:14 PM
  3. Happy With Your Rear Brakes?
    By RiderRick in forum Harley Trike Conversions
    Last Post: 11-13-2011, 11:09 PM
  4. proportioning valve for brakes
    By disabled rider in forum Tires, Wheels, Brakes, Front End
    Last Post: 07-26-2011, 12:04 PM
  5. GL 1500 Motortrike brakes
    By Wayne Harmsen in forum Honda Trikes
    Last Post: 04-29-2009, 07:15 PM
