Likes Likes:  4
Results 1 to 8 of 8
Thread: Weight of trike
    Sep 2016
    Rio Rancho NM USA
    Default Weight of trike
    Does anyone have a ruff ideal of the weight of a 2008 GL1800 with a Motor Trike conversion?
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    I don't,but most of the larger Truck Stops and Farmers Markets have scales that you could weigh on.Hoping that will help.
    May 2011
    San Angelo
    I forget exactly Richard but My '06 with MT conversion was just over 1200 pounds. Of course it carried a lot more down the road!!
    2015 GL1800/Roadsmith HTS1800
    50+ Posts
    Aug 2014
    Clanton, Al. USA
    I have a 08 1800/CSC. Weighted it at a local scrap dealer scales. No driver or passenger. Weighted each axel separately, then entire bike. Results were,
    Front axel 440 lb.
    rear axel 880 lb
    total weight 1320 lb.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Quote Originally Posted by Rabidd View Post
    Their web page might answer your question. About 1/2 down shows the weight.
    http://www.motortrike.com/trikeFastback.aspx
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    I might have missed it but did not see which Motor Trike kit you were referring to. On MT's site, referenced on the previous post, I found the following data:
    Fastback = 1127 lbs
    Fastback 2+2 = 1135 lbs
    Adventure Kit = 1200 lbs
    Carla
    Sep 2016
    Rio Rancho NM USA
    Wink Weight
    The bike has the Adventure Kit. Thanks for all the help I will go with 1320 until I can get it weighted. I am going to put it in a 5th wheel toy hauler and that will help with loading the trailer. Thanks
    Apr 2010
    Shenandoah Valley of Virginia
    What Lehman said about the GTL kit on a GL1500 SE
    • Overall Length - 104”
    • Overall Width- 54”
    • Overall Height - stock.
    • Wheel Base - 68”
    • Ground Clearance - 4” center stand (lowest point).
    • Seat Height - 29”
    • Curb Weight - 1151 lbs.
    • Trunk Volume - 4.5 ft3
  1. Goldwing Roadsmith Trike weight
    By poppajim in forum Roadsmith Trikes
    Owners Forum
    Last Post: 02-15-2015, 09:18 PM
  2. trike weight
    By tinker144 in forum Yamaha Trikes
    Last Post: 01-21-2015, 05:18 PM
  3. trike weight
    By howardg in forum General Discussion
    Last Post: 05-30-2013, 11:52 AM
  4. Trike weight?
    By Scrap Man in forum Honda Trikes
    Last Post: 08-28-2011, 09:04 AM
  5. Trike Weight
    By tis in forum General Discussion
    Last Post: 12-17-2009, 06:22 AM
