Likes Likes:  10
Results 1 to 12 of 12
Thread: Extra Gas Tank
    80+ Posts prowler's Avatar
    Oct 2010
    POCATELLO, ID USA
    Default Extra Gas Tank
    I desired to spent an extra $ to put and extra gas tank on my 2007 K 1200 LT with Hannigan conversion, and I am very glad I done that because the summer of last year I took a trip to Yellowstone Park, I don't have to stop to fuel up all the time and I will keep up the ride with other bike. I am highly recommend if you have extras $ it worth it to have extra gas tank. I getting 32-35 mpg on the trike and other bike get between 48-50 mpg.
    Nov 2012
    Magnolia,Mn
    Default Re: Extra Gas Tank
    I've been think about adding a aux. tank to my 05 K12LT. Did you add the tank when it was converted or after? How long does it take to transfer the fuel to the main tank? Thanks
    randyg
    Oct 2010
    POCATELLO, ID USA
    My old K1200 LT did not have an aux. tank, when I scraped it took the conversion kit to put it in the new bike, I told them to installed it.
    I don't know how long it does transferring the gas because when the main tank show it empty while I riding it I just flip a aux tank to transfer.
    Pawn In The Game Of Life Veritas44's Avatar
    Sep 2011
    Aequitas, KY
    Quote Originally Posted by randyg View Post
    randyg
    Quote Originally Posted by prowler View Post
    Thanks for both of those...
    Been wondering the "real-world" answer myself.
    From what I have heard, it takes about 5-7 minutes to transfer 4 gallons while in motion. Unless there is an issue that needs attention.
    Since the Trike consumes about 2 gallons of Fuel in an hour max (assuming 35 mpg avg and cruising at 70 mph), that would seem more than adequate and acceptable.
    100+ Posts
    Aug 2011
    Duluth, MN and The Villages, FL
    I just converted a K1600 this fall and put the extra tank in. Haven't ridden much yet but I've transferred fuel a couple times while riding.
    I'd say five to eight minutes to complete the transfer. Really glad I got the auxiliary tank.
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    So I have a question? I had a 4wd that I had extra tanks on. I would run on those tanks until they were dry and when the power went mushy switch tanks. The last tank I used was the original main tank with gas gauge. Why couldn't extra tanks on trikes be set this way?
    Happy TRAils/NSD
    Paul
    100+ Posts
    Aug 2011
    Quote Originally Posted by Pegasus1300 View Post
    I believe the Hannigan auxiliary tank is only set up to feed fuel to the main tank.
    100+ Posts ebiss9's Avatar
    Jan 2013
    Vineland, NJ USA
    On my '06KLT, I usually wait for the low fuel light to come on, hit the Aux. tank pump switch, time about 7 minutes on the clock and the auxiliary tank is usually empty.
    Rob Sprague
    Vineland, NJ
    2009 BMW R1200RT Black Metallic
    2006 BMW K1200LT/2012 Hannigan Trike Magnesium Black
    2004 BMW K1200GT Orient Blue
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by ebiss9 View Post
    yup exactly what i do, only i only have 2.5 gal and take 4 min... i used a subaru fuel pump for my transfer ... probably not a big deal but i try not to run the pump dry
    Feb 2015
    West Liberty, IA USA
    I had Hannigan put the extra fuel tank on my 2009 K1200LT when I had it converted last winter. Very glad I did. Like the other posts, I wait until my 'low fuel' light comes on and flip the switch. After about 15 minutes, I turn off the pump. It's important to not let the pump run dry for very long. The easiest way to tell if you have all the gas transferred is to check your 'range' mileage as it increases. When it stops increasing, the spare tank is dry and you can shut off the pump.
    80+ Posts Goldendragon's Avatar
    Feb 2013
    Bend, Oregon USA
    Smile Extra gas tank
    Had mine put in when converting Glad I did. Saved my butt several times. Takes about 15 minutes to transfer fuel.
    Randi Kobernik
    R'di, rider of Norith (my Dragon -2005 BMW Hannigan Trike) & Benden Wing Second
    It is not wise to meddle in the affairs of Dragons for thou art crunchy and good with katsup!!
    1250+ Posts jaxbobg's Avatar
    Nov 2011
    Jacksonville Beach
    Fuel transfer time varies. At highway speeds it can take 15 to 20 minutes, faster at idle but still pretty slow. I replaced the pump on my '09 LT with one from NAPA that had a higher delivery pressure.
    Keep in mind that the aux fuel pump is fighting the pressure of the main pump at the fuel return to the main tank. It's not a straight fuel dump into the main tank.
  1. Power for extra lights ????
    By bfknova in forum Honda Trikes
    Last Post: 01-15-2015, 12:13 PM
  2. Extra lighting on voyager
    By Stoneman123us in forum Outrigger Style Trikes
    Last Post: 12-09-2013, 11:29 AM
  3. extra gas tank
    By Milton Walker in forum New Member Introductions
    Last Post: 10-27-2011, 09:59 AM
  4. Extra Gas
    By Smoken'JOE in forum General Discussion
    Last Post: 10-03-2010, 07:04 PM
  5. Carry extra gas?
    By Big_Steve in forum General Discussion
    Last Post: 08-13-2010, 08:03 AM
