Results 1 to 4 of 4
Thread: U-Joint Part#s for 2008 and up Honda/Roadsmith Conversion
    200+ Posts lgjhn's Avatar
    Jun 2013
    SW Louisiana
    Default U-Joint Part#s for 2008 and up Honda/Roadsmith Conversion
    Hi All.
    I'm looking for the U-joint part#s for the 2008 and up Honda Roadsmith conversion with the 6.75" Ford differential.
    I've found Part# 5-153X (grease-able) for the front, but cannot find any part#s for the rear one at all.
    Thanks,
    LJ
    UPDATE: I found what I was looking for. Please kindly disregard this request/post. Thanks. LJ
  2. Roadsmith banner
  3. #2
    May 2018
    natchez,miss,usa
    Default u-joints
    could you please post the part number (s) and the name for the greaseable u-joints? thanks (2010 roadsmith)
  4. #3
    80+ Posts Wingrider55's Avatar
    Oct 2015
    Kingston, Illinois
    Quote Originally Posted by gl1800roadsmith View Post
    You should be able to download a owners manual from Roadsmith. It should list the part numbers for the driveline.
  5. #4
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Quote Originally Posted by Wingrider55 View Post
    Yes, download the manual. The Spicer #'s ; front is 5-153X the rear is 5-1201X. The rear part number has been replaced with a Dana Spicer 5-7439X. NAPA has a comparable joint that can be greased. The issue, the rear yoke blocks the fitting. I suggest changing out the straight zerk fitting to a 45 degree. Please note, the rear joint has two different size caps. The larger caps fit the differential yoke.
  1. 2012 Honda Goldwing Roadsmith Conversion
    By Danaman in forum Honda Trikes
    Last Post: 03-03-2019, 07:19 AM
  2. 2008 Ultra w Roadsmith V Body Conversion
    By huskerrider in forum New Member Introductions
    Last Post: 02-13-2010, 12:41 AM
