Results 1 to 11 of 11
Thread: Trike Tire Rotation
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Default Trike Tire Rotation
    Since trike tires are non directional I decided today when I had my wheels off to rotate my tires. I was just wondering if any trikers out there ever do that. If so, how often.
    Thanks in advance for your comments.
    1500+ Posts
    Sep 2009
    North East Ohio
    Default Re: Trike Tire Rotation
    I have never rotated my tires. To be truthful with you I never gave it a thought.
    http://imageshack.us/a/img155/9918/trigld1.jpg
    2009 Triglide - Wood TW555 Cams, Suspension Lift By TglideStuff, Butter Smooth Clutch Pull by ClutchWIZ.
    150+ Posts RRSCOTT's Avatar
    Feb 2012
    Maquoketa,Iowa, US
    I have directional Michelin tires.
    Randy
    May 2011
    San Angelo
    And I have directional wheels. Really, My Roadhawk rims are directional. Don't know what difference it would make but they area marked left and right.
    2015 GL1800/Roadsmith HTS1800
    I haven't. I really don't see a need to. But to each his own.
    Dan
    800+ Posts
    Aug 2011
    Evansville, IN
    Hey FRR, How did you get one of those P205/65R15 tires on the front and which side did you mount the skinny tire ??
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by 92fxsts View Post
    It was a difficult task, took a bit of welding and modification, but I'm sure it will be worth it, right? LOL
    I hope you dismounted the tires and balanced them, then put them back on. Just taking them off and reversing sides does nothing...
    I never rotate them don't see any need to, I Have over 20 thousand miles on them with no unevenness [11T/G]...
    1500+ Posts
    Oct 2012
    Batavia Ohio
    There is no need to dismount them, they are non directional.
    Quote Originally Posted by FRR View Post
    Has nothing to go with the direction, It has to do with the way they wear'
    ie; If the outside treads of the tires are wearing out, And you just switch them from one side to the other side, The worn side will still be on the out side..
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Makes sense to me, I never thought about that. Actually I never thought about switching tires from side to side either.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
  1. Trike Tire Size
    By crzrlou in forum Tires, Wheels, Brakes, Front End
    Last Post: 12-01-2021, 06:23 PM
  2. Trike Front Tire
    By captdanwh in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-16-2014, 05:09 PM
  3. Front tire on trike
    By saab9k in forum Tires, Wheels, Brakes, Front End
    Last Post: 04-03-2013, 07:05 AM
  4. can the rotation of a car rearend be change
    By alextico3 in forum General Discussion
    Last Post: 02-18-2011, 04:14 PM
  5. tire rotation?
    By Shmick in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-14-2009, 07:00 PM
