Likes Likes:  46
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 61 to 80 of 84
Thread: Roadstar
  1. #61
    750+ Posts
    Jan 2010
    east windsor ct
    did u say u used v max tubes??? curious why?
  2. #62
    100+ Posts
    Dec 2017
    Chauvin, La
    Default V Max Tubes
    Don't remember anything about V Max Tubes.
  3. #63
    100+ Posts
    Dec 2017
    Chauvin, La
    Default 98% DONE
    Rolled her out and took a long test ride today. Looks like everything I left with came home with me! Going to give it a going over tomorrow looking for anything that needs attention. The Reverse didn't work so I'll be checking the wiring for that. Putting wire spoke hub caps on it next week and the auxiliary driving lights needs finalizing and they can be installed later. Getting the horses painted as soon as I repair the body on mine.
    I do thank everyone for the complements!
    Name:  Finished Paint Front.jpg
Size:  175.1 KBName:  Finished Paint Left Side.jpg
Size:  219.2 KBName:  Finished Paint Rear.jpg
Size:  181.2 KBName:  Finished Paint Right Side.jpg
Size:  210.1 KBName:  Finished Paint Top View.jpg
  4. #64
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Hugh, congrats, I think she came out good.
  5. #65
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    That was me. Vmax fork tubes are 4" longer than Road Stars , but the total length is similar. When you rake the front end sits lower. Most people use extenders on the tubes. I like going fast in the twisties so the forks get a workout and can egg shape the fork threads at the joint, so they leak.
  6. #66
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by jjvw View Post
    oh sure NOW u tell us... lol
    just put a sidecar on my * and made a set of extensions
    i have at least 3 sets of max tubes ....
    oh well
  7. #67
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Tubes
    oh well
    You DO? Hmmmm.
  8. #68
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Long Ride
    Well my wife rode over 200 miles today and had only one issue with my work. Seems the front suspension travel was more than I measured and the outer tubes hit the front fender skirts. Not a big deal as I can clean up the damage and re-glass the inside where one cracked. The major issue is with the starting system or possibly charging system. She stopped for a break and the bike wouldn't turn over. Luckily someone was able to jump her (that's funny right there) and the bike started right up. She rode until it was time to fill up and it happened again. Being next to a Battery Plus Store, she bought a new battery, started up and headed home. Of course the same thing happened after visiting her dad but was able to put the battery on a fast charger which got her home. Tomorrow I will do what I despise doing, ELECTRICAL !!!!! I'll begin by checking the main power wires from the battery to starter, starter relay, starter, and rectifier. If anyone has or had issues like this and have advice, I sure would take it. But in the end, she came home with a smile from ear to ear. THAT, made all the time and effort worth it. My Stratoliner is next!!!
  9. #69
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Rickus Dickus View Post
    battery cables are a little on the small side but sounds more like a charging issue
  10. #70
    Dec 2013
    Jenison, MI
    oh well
    How much you want for em?
  11. #71
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Not charging
    Found the starter solenoid crumbling and installed a new one. Didn't solve the problem and Yamaha Roadstar rectifiers can't be bench tested. So I removed it, started the bike up, and tested the stator. Got 65 volts AC, checked the cables and didn't see an issue, and starter checked good. New rectifier should arrive tomorrow.
  12. #72
    100+ Posts
    Dec 2017
    Chauvin, La
    Default On the Road - Almost
    Changed out the starter solenoid and rectifier, got 14.2 volts at the battery running. Karen took off on a road test and the bike failed. She shut it down 60 miles into her trip, the engine jumped and backfired before shutting down. She tried to jump it with a NOCO Boost Plus jump start battery and nothing. Not even the gauges move. All fuses check good. Oh well. Her bike took the ride of shame on a trailer home where I checked the battery. ZERO, nothing, no voltage at all. Pulled the Starter solenoid and it checked out good. Checked the jumper battery and found it is putting out a mere six volts. Not good there. So I put the battery on charge tonight and will check it tomorrow. But I am concerned that even though it was charging, could the battery have been just good enough to give her one or three cranks even being new? That engine jump and backfire could very well have been it drawing the last of the battery juice when shutting down. I so truly hate that despicable electrical crap.
  13. #73
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Finished paint
    My wife and I have been riding a lot and recently slowed down. So I am finally posting pictures of my wife's Roadstar. The base white and black is all I painted. The rest is was done by a professional.
    Name:  Right Front View.jpg
Size:  132.2 KBName:  Right Rear View.jpg
Size:  100.4 KBName:  Rear Center Body.jpg
Size:  53.8 KBName:  Right Rear Body.jpg
Size:  88.8 KBName:  Right Rear Fender.jpg
Size:  103.3 KBName:  Right Side Gas Tank.jpg
Size:  116.3 KBName:  Right Front Fender.jpg
Size:  100.9 KBName:  Front Fender Top.jpg
Size:  84.7 KBName:  Left Front Fender.jpg
Size:  96.0 KBName:  Left Gas Tank.jpg
Size:  98.3 KBName:  Left Rear Fender.jpg
Size:  115.9 KBName:  Left Rear Body.jpg
  14. #74
  15. #75
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    [QUOTE=Rickus Dickus;803706]My wife and I have been riding a lot and recently slowed down. So I am finally posting pictures of my wife's Roadstar. The base white and black is all I painted. The rest is was done by a professional. /QUOTE]
    Now that is a real nice trike! Hat off!!!!
  16. #76
    May 2018
    Angleton, Texas
    Very nice job!
  17. #77
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
  18. #78
    Very Nice great tribute
  19. #79
    Dec 2013
    Jenison, MI
    Nice! I thought I was doing good just installing a kit.
    On that regulator, I hope you didn't use a cheap china one. Usually don't last more than a couple weeks. OEM is the only way to go on that one.
    I would really like to see that at the Maggie Valley event in September!!
  20. #80
    Very Very cool looking trike
  1. Roadstar Luggage Rack...
    By Doc in forum Yamaha Trikes
    Last Post: 09-04-2014, 11:23 AM
  2. Roadstar Seats.
    By Deacon Don in forum Yamaha Trikes
    Last Post: 08-14-2012, 05:32 PM
  3. roadstar rear seat
    By jmhelm in forum Yamaha Trikes
    Last Post: 07-26-2012, 03:06 PM
  4. '01 Roadstar
    By animalracer in forum Yamaha Trikes
    Last Post: 01-08-2012, 07:28 PM
  5. 1600 roadstar, front brakes
    Last Post: 05-18-2011, 04:58 PM
