ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie9ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie9ol' schoolNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie9SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie9Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie9LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  1
Results 1 to 15 of 15
Thread: TriGlide Factory Air Shocks
    Trike Talk Executive Chef
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Default TriGlide Factory Air Shocks
    Based on your air pressure of the Air Shocks, what pressure are yours set at ? Does a higher setting like 30lbs make it ride soft or hard ? And the same with a low setting around 18 / 20lbs, hard or soft ride ? This is based on the factory setting of 26lbs in the rear tires.
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Member Patriot Guard Riders
    Quote Originally Posted by Sully View Post
    I tried every setting from 20 to 50.... I ride solo and weigh 210, And have 22 lbs in the rear tires.
    The best compromise [For me] is 35lbs in the shocks..
    Too soft in the shocks and you'll bottom them out when you hit a sharp bump..
    Too hard and you'll bounce /shimmy on sharp bumps.. That said with the shape of most roads in the North East there isn't any perfect setting for Tri-Glide, When i get on my Gunner it feels like I'm riding a Caddy over the same roads..
    350+ Posts Larry Sobczak's Avatar
    Apr 2015
    Breese, IL
    I run 35 in the shocks riding 2 up most of the time with 26 in the rear tires. I will run 40 to 45 in the shocks when we are on an extended trip.
    9750+ Posts Rod69's Avatar
    Dec 2011
    Lawrenceville Il. USA
    With the tires at 26 back and 36 front, 30 lbs in the shock is a happy medium. Well maybe not happy, lets say acceptable.
    Rod69 Illinois TOI #900
    Joan71 Illinois TOI #901
    13000+ Posts FuzzyWuzHe's Avatar
    Quote Originally Posted by Rod69 View Post
    +1 ... it's what I run ... unless I pick up a co rider ... yea right ...
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Ok, this sounds good. I run 36 in front and 26 in rear also, but only 20 in the shocks, so I'm going to try 30. My weight is around 210, depending on what I BBQ
    I was wondering if the more or higher pressure you put in the shocks does it make it a harder ride ?, but I guess not really. Thanks
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Apr 2015
    Breese, IL
    Ok, this sounds good. I run 26 in front and 36 in rear also, but only 20 in the shocks, so I'm going to try 30. My weight is around 210, depending on what I BBQ
    You mean 26 in rears and 36 in front .
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Quote Originally Posted by Larry Sobczak View Post
    Geez, I made the correction, Thanks Larry.
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Dec 2013
    Clarion PA USA
    Thumbs up 36-22-36
    sounds like figures for something else huh! 36 front, 22 rear and 36 shocks. Works for us two up always my bride and myself. ride safely fearless
  11. #10
    Sep 2014
    Box Elder, SD
    With the DK comfort lift, I run 26 in the tires and 20 in the shocks. That pressure is with 2 up. Jim
  12. #11
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    Quote Originally Posted by desertclassic View Post
    I have no idea what's in the shocks--whatever was in it when I bought it back in June. I do know there is 36 front, 26 rear though.
    I have the regular lift, and shockingly my wife noticed a difference in the way the bike rode the first time she went out with me afterward. She NEVER says anything like that, so that tells me it made a tremendous difference.
  13. #12
    450+ Posts arnie's Avatar
    Dec 2011
    camp grove,il.usa
    I had the lifts on my 14 trike & took them off, thinking I was going to trade it for a 16. After seeing the 16's I've decide not to trade. No matter where I have the shocks set at, it is not good because of the road conditions. Shocks bottom out on the quick dips in the pavement. They are set at 45-50 now,& it's killing my back. I need to get the lifts back on. They are one of the best things I've done to the trike for comfort.
  14. #13
    Apr 2022
    BROWNSVILLE
    Default Air Pressure on shocks
    I'm only guessing, because I only last month bought a Tri Glide, but from what I'm finding out the more air the harder it bounces. I'm about to reduce my air pressure to prove this point, I live in PA (The pothole capital of the world).
    CQ CQ de N3IQS
  15. #14
    Jun 2022
    G.J. Co. mesa
    Default 2016 triglide
    how do i attach air lines to shock
  16. #15
    Quote Originally Posted by cycleguy1970 View Post
    The air lines should be on the shocks and the fill valve should be on the right side on the frame just above the right side cover.. UNLESS the previous owner removed it ..?..
    Also you have to use a no-loss air pump..Not a regular air pump..
  17. DKCustoms postbit
  1. Replies: 14
    Last Post: 07-01-2015, 06:29 PM
  2. Progressive 444 Shocks on TriGlide
    By geezerglide11441 in forum Harley Tri Glide
    Last Post: 05-20-2015, 07:16 PM
  3. TriGlide shocks
    By stroker 23 in forum Harley Tri Glide
    Last Post: 02-09-2015, 12:02 AM
  4. 2011 triglide shocks
    By chev58 in forum Harley Tri Glide
    Last Post: 11-30-2011, 10:39 PM
