Likes Likes:  2
Results 1 to 6 of 6
Thread: reverse
    20+ Posts
    Jan 2018
    australia
    Default reverse
    does installing the mmd reverse alter the width to the outside of the clutch cover.thanks all
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    Quote Originally Posted by david lee View Post
    Hi David. I'm not sure about an MMD reverse. I installed a Champion (from Papa Zook) on mine. It made the clutch cover about a half inch further out plus the width of another gasket. I hope that helps.
    Reverse assembly
    Assembly with cover installed
    Name:  reverse complete.jpeg
    Bill
    R I P MANDY
    With my 2011 Tri-Glide the reverse [Moto-Trike] was alterd Less than a half inch..12.7 MM..
    20+ Posts
    Jan 2018
    australia
    it looks like im going to have to modify the ex pipe as the banjo bolt and line will clear thanks
    A couple of taps with a ball peen hammer on the heat shield will solve the problem....
    20+ Posts
    Jan 2018
    australia
    it will be the pipe the heat shield only covers the outside of the pipe not the inside where the bolt is thank you
  1. Reverse gear for a reverse trike
    By elwirth in forum General Discussion
    Last Post: 05-23-2019, 10:30 AM
  2. Reverse Or No Reverse?
    By GETRDONE in forum Harley Trike Conversions
    Last Post: 09-05-2015, 07:37 PM
  3. new reverse trike
    By Trike Man in forum Home Built Trikes
    Last Post: 10-31-2012, 08:25 AM
  4. Some of my fave "reverse trikes"
    By mkparker in forum Home Built Trikes
    Last Post: 01-09-2011, 05:53 PM
  5. Reverse trikes past and future...
    By ben721364 in forum Other Brands Trikes
    Last Post: 02-24-2008, 06:00 PM
