Likes Likes:  2
Thanks Thanks:  2
Results 1 to 17 of 17
Thread: Rear End Gear Change
    Aug 2019
    Victorville, CA, USA
    Default Rear End Gear Change
    Anybody ever thought of or changed the rear end gear ratio to bring the RPM's down??
    2016 GL1800 with Roadsmith HTS1800
  2. Roadsmith banner
  3. #2
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by JimLindenberg View Post
    Roadsmith currently uses a 2.61:1 (I believe) ratio for the GL1800. You probably have the 2.93:1 that was previously used prior to the 2019 models. You will then need a 'speedo healer'.
    Jim Murphy
    Iron Butt Rider 2001
  4. #3
    Aug 2019
    At around 65 mph I'm at 3,000 RPM. What is your RPM with the 2.61:1?
  5. #4
    Martinsburg, WV
    Cool
    I don't have a Roadsmith but the change is around 10%. 71mph is the new 65mph @ 10%.
    Jim Murphy
  6. #5
    Aug 2019
    Thank You for the info
    Sep 2016
    Springfield, Mass. USA
    Just yesterday (10/23/20) I rode with another Goldwing (stock two wheel'rrr) and I have the R/smith trike (Goldwing) at the gas station, we both filed up at the same time and each of us zero'd out our odomitors........... later on in the ride we would check our O/D's to see the difference................His was always 1.5 miles more than mine, is the difference's because of mine is a trike??
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Yes. You can expect a decrease in MPG when triking a motorcycle. Most trike conversion companies have researched the gear ratios and have matched the gear ratio that gives best performance and fuel mileage to each model and make.
    Quote Originally Posted by trikeman View Post
    I think Ronnie was talking Indicated miles traveled on the odometer... And not Miles Per Gallon......
  10. Roadsmith banner
  11. #9
    Oct 2010
  12. #10
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Odometers and speedometers are notorious for being inaccurate in Goldwings. I have ridden with many different trike brands as well as 2 wheel Goldwings for several years. Very few will ever agree on distance traveled much less MPG even though we all fuel up the same place and ride together. At one time I installed a Valkyrie rear tire on my 2 wheel GL1800 and, because of the larger tire aspect, my speedometer was almost dead on. But handling suffered a bit. I eventually went back to OEM spec. tires and added a Speedo-Healer to that bike. If memory is correct, I believe there was a 6.5% correction required to make the speedometer accurate. But, I did notice that my odometer was then logging slightly fewer miles than I was actually traveling.
    I know my CSC trike also has about a 6% speed error. I will look into the possibility of installing the next larger size tire aspect when the tires need replacing. Currently my speedo indicates I am doing 67 MPH at 2800 RPM but my actual speed is closer to 64. I think the GL1800 has enough torque to carry the same speeds at 200-300 less RPMs. Hope this helps..... Jim
    Additional Info.....
    My trike has a 3.0-1 rear end
    The spec calls for 205/70R14 tires having a diameter of 25.3 inches rotating 798 times per mile.
    I have installed 205/50R17 tires having a diameter of 25.1 inches rotating 805 times per mile
    If I change to 205/55R17 tires the diameter is 25.9 inches and will rotate 780 times per mile
    And if I can fit 205/60R17s I think that is what I would do. Changing tire aspect is a lot easier and less expensive than changing gearing. Something to consider..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
  13. #11
    Sep 2016
    Correct! Miles travel'd...........NOT........... Miles per gallon
  14. #12
    Oct 2010
  15. #13
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Default OOOPS
    I just realized the OP posted this 7 months ago. Oh well. It caused me to do a little checking and determine what I would like to do down the road...... Jim
    Semper Fi
  16. Roadsmith banner
  17. #14
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Default gears changed - indicated speed is low
    When R/S rebuilt my 2014 rear end they supposedly replaced the gears with the same ratio.They did not. Checking the speed using a car in front of me, the driver held 55 mph, my GL1800 was showing about 50. Using a Waze app on my phone showed the same. I guess from here on out I just need to remember that 5 mph difference. Will tire diameter fix this when it comes time to replace rear tires? Thx.
  18. #15
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Japanese bikes are notorious for being 5-7 miles off on the speedometer. We have dealt with this on all our Hondas, our Kawasaki 1200’s, and the Suzukies we had.
    There are others out there but several years ago we used a plug and play device put out by Dakota Digital to correct the speedometer on our 2008 Gold Wings. It was easy to do and we used the Tom Tom gps to set it by.
    Still working today just fine and no more guessing how fast the bike is really travelling when the radar cop is spotted. Peace of mind. People we rode with thought we were spoiling for a ticket because their speedos say we are travelling around 5mph faster than they are.
  19. #16
    250+ Posts
    Jan 2012
    oz
    My 2020 Roadsmith HTS1800 is spot on with my gps mph
  20. #17
    Sep 2016
    Correct (miles traveled)
  1. CSC Viper Rear End Oil Change!
    By Grandpa1 in forum Honda Trikes
    Last Post: 12-01-2022, 04:09 PM
  2. Lehman Jackal Suzuki C90 Rear End Fluid Change
    By Yogisan in forum Suzuki - Kawasaki Trikes
    Last Post: 04-08-2021, 07:18 AM
  3. Photos of your rear end —. Not THAT rear end !!!!!!
    By Snickers1948 in forum Harley Tri Glide
    Last Post: 11-04-2017, 02:07 PM
  4. starter gear teeth 12v 1600 vw of the gear
    By bluedog in forum VW Powered Trikes
    Last Post: 07-24-2013, 04:22 PM
