Likes Likes:  219
Page 9 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 161 to 180 of 297
Thread: Post Your VW Trike Pics
  1. #161
    Aug 2015
    tucson
    Default My ride im currently building
    Hello everyone, Im new to this forum,
    Here is my trike I'm building this year, I just started it July 15th.
    I would like to hear your comments, good or bad.
    http://s887.photobucket.com/user/wah...lideshow/Trike
    rick@rickadams.net
  2. #162
    Meme Master
    Jan 2014
    Farmington, NH USA
    Welcome to the forum Rickety.
    Your build pics look good.
    I've never seen one built using round pipe as the center frame. That's pretty unique.
    During your build you'll likely have setbacks at times, but don't let them slow you down.
    There are a few of us here on TT that have built VW trikes, so if you get to scratchin your head on something post it up & someone will likely be able to help you.
    Think end result & you'll get it done....
  3. #163
    welcome aboard. looken good keep us posted
  4. #164
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Quote Originally Posted by Rickety View Post
    rick@rickadams.net
    Welcome aboard Rickety! Glad you found us here.
    That is quite the interesting build you are doing man!!
  5. #165
    Aug 2015
    tucson
    thanks stinger,
    Well when I decided to build, I looked at every single trike picture I could find on the net.
    and with that I knew exactly what I DID NOT want to build. I hate copying someone else design or similarity.
    So that's why I chose the 8" pipe as a body, My initial thought was to make it the gas tank, it can hold 12 US gallons. But I'm to far along to do that now, but the next one will have the pipe as the gas tank.
    Thanks for the comments, good or bad i would really like to hear them.
    ok the first 6 pictures are new to the slide show,
    I have the wood seats built, the shiftier hooked up and installed, I'm turning the stainless steel front axle on the lathe now.
    Please let me know what you think
    Rickety
  6. #166
    Meme Master
    Jan 2014
    Farmington, NH USA
    Looks like you picked the right "helper" from the first new pic you posted...
    If she can't keep you motivated to finish your project, well good luck...
    It's nice to have access to a machine shop in building/fabricating a trike or anything from scratch, so you're at least one step ahead of the home garage builder in that regard. I'm jealous!
    Keep on keepin on...
  7. #167
    Aug 2015
    tucson
    Looks like you picked the right "helper" from the first new pic you posted... If she can't keep you motivated to finish your project, well good luck... It's nice to have access to a machine shop in building/fabricating a trike or anything from scratch, so you're at least one step ahead of the home garage builder in that regard. I'm jealous! Keep on keepin on...
    yea she is a real cutie pie, she is my photographer, I don't know how she wound up in that slideshow,
    Thanks anyways, Rick
    and Shannon says
    " keep the wheels spin'in and the beavers grin'in "
  8. #168
    Welcome Rickey ... nice job ... looking good.
  9. #169
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Default My trike
Size:  700.4 KB I don't how to resize a photo so I don't know if this is to big. Apologies if its to big.
  10. #170
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I like the style, size.
  11. #171
    +1 ... nice ride
  12. #172
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Awesome looking Dub trike!!!!!
  13. #173
    400+ Posts
    Feb 2015
    Sussex nj usa
    Snu I tried 2 keep it as close 2 the size of a servicar as I could. I wanted something small like a motorcycle,yet keep the proportions correct for the width.
  14. #174
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yep. Understood.*
    I wanted mine motorcycle sized also.
    Old pic. Mine is apart right now.
  15. #175
    Nov 2015
    Macclesfield
    Default VW phoenix body removal problems help
    Hi, hoping someone can help. Need to remove body and front seat however fuel tank in way and cant see any bolts under seat. Cant see any bolts for fuel tank either. Does it slide off?
  16. #176
    Feb 2008
    Anderson, Missouri
    Just brought home this 2007 Roadhawk. (Don't look too close at the dirt, it's just off the trailer after a 600 mile trip from Minnesota.)
    Name:  Trike - Copy.jpg
  17. #177
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by Ozarkryder View Post
    That is a sweet looking trike man!!! Congrats on the purchase
  18. #178
    Meme Master
    Jan 2014
    Farmington, NH USA
    Quote Originally Posted by stinger608 View Post
    x2 On that.
    Black is a tough color to keep clean. Ask me how I know!!!
  19. #179
    Nov 2015
    elgin
    rick@rickadams.net
    Way cool looking trike Rickety, I like the look and the tube idea is an eye catcher! Have you done the math on the front end, it looks like it's really raked out there from the pic view?
  20. #180
    Jan 2016
    wilson
    Default Ed Roth TRike I just picked up, anyone have any knowledge of these
    I just picked up at auction. story is,, it came out of a storage unit in California, plate was last tagged 1995, it has a 1962 1200 motor in it, I'm almost positive its a ed roth body, it is missing front nose that bars go through, otherwise great
  1. Post Your BMW Trike Pics
    By Papa Zook in forum BMW Trikes
    Last Post: 08-12-2016, 09:29 AM
  2. pics of the new trike
    By cooltech in forum General Discussion
    Last Post: 09-10-2013, 05:39 PM
  3. trike build more pics
    By ade747 in forum General Discussion
    Last Post: 04-01-2013, 09:20 AM
  4. Our New Trike Pics
    By skuuter in forum Honda Trikes
    Last Post: 07-11-2010, 03:36 PM
