ADSavarese4trike ladyNew Member Introduct...New member from FL
ADSavarese4Uncle FesterNew Member Introduct...New member from FL
ADSavarese4rhino 2New Member Introduct...New member from FL
ADSavarese4ADSavareseNew Member Introduct...New member from FL
Likes Likes:  7
Results 1 to 19 of 19
Thread: Driveshaft spline grease
    500+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    Default Driveshaft spline grease
    What grease do you use for the driveshaft splines?
    Rake...
    Never had it....
    Never will...
    May 2011
    San Angelo
    Quote Originally Posted by cjmitch View Post
    I was told by a mechanic I highly trust that Black Molly grease is best for splines and gears. Has something to do with ability to absorb or not be adversely affected by the crush factors. Yup, I guess those little molecules get beat up after a while.... Seriously, that is what I use and it has served me well for many years.
    2015 GL1800/Roadsmith HTS1800
    Mar 2011
    mountain home,ar. USA
    Every time I hear this question I have to ask: "When was the last time you greased the driveshaft splines on your car or truck?"
    Jul 2016
    St Joseph Mo
    Quote Originally Posted by mhgoldwing View Post
    Driveshaft splines on your car transmission are lubed by the trans fluid. If you pull the driveshaft out of the trans you will have a fluid mess on your floor. No maintenance required.
    Older 4wd trucks require greasing the splines periodically, newer ones are sealed.
    Feb 2008
    Anderson, Missouri
    Honda used to recommend HondaPro Moly 60, but that is no longer available. The tech at the local Honda shop said that Honda 08 734-0001 Moly Paste (M77) is the replacement. Spendy, but a little goes a long way.
    Mar 2011
    Quote Originally Posted by agetech View Post
    Thanks. I stand corrected. I have never remembered any Honda mechanic telling me my driveshaft splines needed lube; 10 years 1500 and 5 years with 1800. Guess I will read my service manual.
    Apr 2010
    Shenandoah Valley of Virginia
    For years I have used Valvoline VV632 Moly fortified grease and the splines on the drive shafts of both my trike and my two wheeler as well as the rear wheel splines on the two wheeler look new still. I am liberal in it's use. I use it on my wheel bearings and etc as well. Good stuff.
    http://www.valvoline.com/admin/p65.png
    400+ Posts mgwtrike's Avatar
    Nov 2014
    Loving the Southern Life in Central Florida
    I have to check my manual also, news to me.............
    Goldwing:
    A real butt kicking, wheel popping, tire burning old man's bike.
    MIKE W.
    500+ Posts
    Feb 2008
    This is exactly what I bought.
    But it seems waaaaay too thick for usage a
    s a bearing grease
    I did it last yeare when I installed my new Motortrike driveshaft.
    I used regular bearing grease but even at that time it felt too lightweight. I figured correctly that there was a better option
    Rake...
    Never had it....
    Never will...
    Apr 2010
    s a bearing grease
    You want something that will stick to rollers & races .... like biscuits & gravy.
    I have a tub of old school Marfak with the strands .... that's thick.
    500+ Posts
    Feb 2008
    Thats not grease.....
    Thats called GOO....
    Rake...
    Never had it....
    Never will...
    100+ Posts
    Aug 2011
    Cumberland Md USA
    Black Moly Grease will be the best!!
    250+ Posts rhino65's Avatar
    Aug 2016
    Atwood, Illinois United States
    Loctite moly paste. Contains 67 moly. Pricey but have used it for years. Just coated the driveshaft splines on my GW trike
    2002 GL1800 with CSC trike kit
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Below is what Honda's Service Manual calls for. I've never found a source for the Mitsubishi's M-2, so I use Down Corning's Molykote BR-2 plus. Some believe Moly60 is sufficient, however, not according to Honda ... actually, according to Honda, Moly60 is not used anywhere on a GL1800.
    If it's a trike drive shaft, then one should use what the trike manufacture says to use.
    "Use molybdenum disulfide grease (containing more than 3% molybdenum disulfide, NLGI #2 orequivalent).
    Example: Molykote
    ® BR-2 Plus manufactured by Dow Corning, U.S.A.
    Multi-purpose M-2 manufactured by Mitsubishi Oil, Japan"
    500+ Posts
    Feb 2008
    So as an added measure should I be loading this stuff into a grease gun and shooting it into the U-joints on the drive shaft?
    Rake...
    Never had it....
    Never will...
    20+ Posts
    Jun 2012
    Horseshoe Bend, ar,usa
    I checked my Honda service manual and found nothing about maintenance on the splines. If it's in there can someone tell me where ?
    JustWings.com
    May 2016
    Quote Originally Posted by exphoneman View Post
    Lubing the spines in a Honda Service Manual is not a maintenance item. On a 2-whl GL1800, the drive shaft is inclosed and protected from road dust, and climate. Once lubed at the factory, re-lubing is not needed unless a repair is done. In the Service Manual, lubing the rear splines of the drive shaft are shown in the Final Drive section under "installation" (chapter 13, page 22 in Service Manual version I am currently looking at), and the front of the drive shaft's splines are lubed as the engine is being installed (Engine Removal/Installation section (chapter 8, page 11).
    I believe there is no where in a Honda Service manual that show an actual drive shaft or even how to inspect it.
    950+ Posts JaysGone's Avatar
    Nov 2012
    Delray Beach Florida
    I think the splines being referred to by most that need to be greased are on the OEM rear wheel pack. Might not be true of a trikes shaft. I didn't have to, but did the rear wheel pack on my Valkyrie every 5K or so. I used whatever grease had the most moly in it at the time.
  19. #19
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Whether the splines need to be "regularly" greased depends on type of kit and driveshaft design. Many of your "solid axle" conversion kits use an OE (or equivalent) front universal joint (on the GL1800 many used a GL1500 front u-joint assembly) that is a splined fit to the driveshaft coming from the kit.
    On a solid axle as the wheels move up and down this causes the driveshaft to slide in and out on the splines where it meets the front universal joint. Because this is a part that "slides" on top of it's already intended use, most companies recommend applying grease to the splines to help prevent wear to the splines themselves. This isn't necessary on a vehicle because the plunge is inside the tailshaft of the transmission & is constantly lubricated by the transmission fluid (this is one of the reasons there is a seal where the tail shaft goes into the transmission).
  1. Which U-joint grease?
    By Mick in forum Honda Trikes
    Last Post: 12-25-2023, 08:24 AM
  2. Grease
    By dogman513 in forum Lehman Trike
    Last Post: 10-09-2014, 07:26 PM
  3. Grease U Joints???
    By QuapaBrave in forum Honda Trikes
    Last Post: 10-31-2013, 06:06 AM
  4. Universal Grease Fitting
    By Yogisan in forum General Discussion
    Last Post: 07-20-2011, 07:42 AM
