Results 1 to 10 of 10
Thread: Custom dynamics Rings
    700+ Posts kybigmac's Avatar
    Oct 2014
    murray.ky usa
    Default Custom dynamics Rings
    I'm thinking about putting the 'custom dynamics rings ' in my 08RSV/Hannigan. Has anyone on here used them and how well do they work? I like the idea of the clear turn signals that change color when you turn them on. My Hannigan kit has led's in the rear turn signals,so they flash a little faster than normal and I was wondering if putting these in the front was going to change that any? Any advice from someone on here who is using them would be helpful. Would you do it again after using them? Thx in advance
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    No experience but the fast flash is due to the lower current draw of the leds being used with the stock flasher.I think Kissan and maybe others make a replacement flasher,some of the modules that make the lights flash have resistors to fix it,you can add resistors,or if you do not care about the auto cancel function of the flashers usually an automotive flasher designed for leds can be used in place of the stock unit with little trouble.There may be other options but these are what I know of.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    Oct 2014
    murray.ky usa
    I wouldn't give up the self canceling feature at all I love it. My main question is if I add the front lights will it make the signals any faster. I don't mind the speed they flash at now,but I'm not sure I would want them any faster. There is a thread on another forum about fixing the stock flasher to work with the LED's that I might attempt. Just wondering if anyone else has done this conversion. What I have read about the things that load the signals to make them pull more power has not all been positive. I'm also wondering if these lights work as advertised!
    900+ Posts
    Bellville, Texas, USA
    I installed them on my 2015 Harley Freewheeler. They did not change the flash speed but I do not have LED taillights so that may make a difference. I have the smoke lens with mine and they are very bright; they were a very simple plug and play. I am very happy with them and I would buy them again.
    Sunman
    Oct 2014
    murray.ky usa
    Quote Originally Posted by Sunman View Post
    Sunman
    Thanks for your reply,this is the kind of info I'm looking for!
    350+ Posts
    Aug 2009
    Wayne, Mi USA
    Had them on my "09". No problem with the flash rate either. I didn't have driving lights but used hid bulbs in the headlight for that extra brightness at night.
    Anyhow loved those lights.
    Oct 2014
    murray.ky usa
    Quote Originally Posted by Carbon_One View Post
    Thx for your reply! I think I'll give them a try. It's Christmas and my family is always having a hard time trying to buy me a present,when you're my age you have everything you need. I definitely think they're worth a try.
    20+ Posts 6bull's Avatar
    Jan 2014
    Kansas
    Default Re: Custom dynamics Rings
    I know this is an older post, just came across this post.
    I have an HD Tri Glide with rear LED brake/turn signals. I did install the Custom Dynamics Ringz in the front turn signals. Before the LED front signal change the turn signals did flash faster with the LED rear signals and incandescent front turn signals, but after installing the Custom Dynamics Ringz LED's in front the signals flashed the same as before.
    Yes I would do it again. I have used Custom Dynamics on my previous Tri Glide and would use Custom Dynamics again on any Motorcycle in the future.
    Hope this helps you in your decision.
    2016 Tri Glide, Cosmic Blue Pearl, Stage 1, Screamin' Eagle Ventilator Elite Air Cleaner, Power Vision, Rush 7017 HO Exhaust, Big Louie 4" Slip-On Mufflers, DK Custom 14" Pro Action Shocks, DK Custom Tour-Pak Relocator, Custom Dynamics LED Turn Signals, Custom Dynamics SMART Triple Play
    [/SIZE]
    Oct 2014
    murray.ky usa
    Quote Originally Posted by 6bull View Post
    Thanks for the reply,that's good info. I've been putting off ordering till after the holidays,but I think I'm gonna order them this week.
    Oct 2014
    murray.ky usa
    Just a update,I finally got around to ordering and installing the lights. I have to say I really like the looks and I am hoping they make me more visible to cars. As far as the signal flashing it's a little faster,but not bad at all! I would recommend these to anyone.
  1. freewheeler and custom dynamics flasher
    By GLT in forum General Discussion
    Last Post: 04-20-2016, 09:52 AM
  2. New Custom Dynamics LED headlamp
    By Hrolfr in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-06-2016, 09:06 AM
  3. LED Light Rings
    By hocnsoc in forum Harley Trike Conversions
    Last Post: 01-18-2015, 04:53 PM
  4. Rings
    By jcolson in forum Harley Trike Conversions
    Last Post: 01-19-2014, 02:08 AM
  5. Custom Dynamics
    By FLTR2008TRIKE in forum Accessories
    Last Post: 12-18-2012, 11:05 AM
