has any one tried a car tire on the rear of the can am.
Most everyone puts a car tire on the rear. The OEM tire is junk so if you want to improve the handling of your spyder add a car tire to the rear. When the fronts wear out put car tires there also.
Happy TRAils/NSD
Paul
I run a General Altimax RT-43 in 215/60 15 at 23lbs pressure, most everyone I know has switched to a car tire after the stock kenda wears out. I have 15,000 on it and looks like new. No problems in wet or dry conditions. I also run car tires on the front, Federal EVO 595's stock size at 17lbs some are running the Federal Fomoza AD1 in stock size and like them real well. The kenda tires are crap, and there is better avail.
