Likes Likes:  6
Thanks Thanks:  1
Results 1 to 20 of 22
Thread: Led tail light bulb
    Sep 2021
    flushing ny usa
    Default Led tail light bulb
    Has anyone replaced the oem tail light bulb on a Tri Glide with a #1157 led bulb ?
    How did it work out ?
    Hi Gary, Welcome to Trike Talk and your first post
    Not a Triglide, but I use them on my FLRT Freewheeler
    They are brighter than stock bulbs, draw less amperage and will last longer
    You will probably have to sync it to your BCM by turning the ignition on and running the 4 ways for a minute or 2
    These are available every where
    Sep 2021
    flushing ny usa
    [QUOTE=Jack Klarich;908396]Hi Gary, Welcome to Trike Talk and your first post
    The new tri Glide uses a bayonet lug filament bulb and the 1157 bulb is supposed to be a plug and play for it. I want to add a flasher for my brake lights but you need to have LED bulbs. To change both tail light assemblies would cost about 1K. So I thought if I could change only the bulbs then maybe the flashing module would work with them.
    [QUOTE=garbluez;908397]
    Gary.....What Trike do you own......Your profile says you are looking for a trike..???
    Sep 2021
    flushing ny usa
    I own a 2022 Tri Glide Ultra
    Quote Originally Posted by garbluez View Post
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Those are the LED's I put in my 2020Tri. Work great
    The stock bulb is a 3157 K. this is pretty much the same as a 3157 bulb, but a few lumen s brighter, therefore the Sylvania 3157R bulbs will work
    The 3157K bulb has been used for a number of years on HD trikes now
    I have replaced 3 sets of these on 17-21 models already with no problems
    Dec 2012
    Santee
    Those are the ones that I have on my 17 Trike.
    Ray
    2017 Harley Triglide
    Tijuana Border
  11. #10
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    Get a set of these, they have flasher built in, flash 3 times then steady. Note, some of the LED bulbs are directional (diode) so if they do not light, try reversing the bulb in the socket.
    I have these on my 2019 Trike and they work just fine.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  12. #11
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    This is the one I put on my 2016. It just does the tour-pack lights which are more eye level for cages.
    https://www.customdynamics.com/magic-strobes-ltp2
    2016 Tri Glide, More DK than HD. Just shut up and ride.
  13. #12
    450+ Posts MB1953's Avatar
    May 2014
    Peru, IN USA
    I went with these from Eagle Lights:
    https://www.eaglelights.com/products...dson-no-window
    They are always running discount offers.
    They have the strobe built in, got the smoke grey lenses, and added Kuryakin hoods that I refinished in satin black. Gave me just the look I was after.
    2017 TriGlide Vivid Black - DK Outlaw AC, Fullsac performance baffles, PowerVision from DK, Love Jugs Mighty Mites from Papa Zook, HD Black Reach Bars, all kinds of BLACK stuff... Hi, my name is Mark and I used to be a chromeaholic!
    was - 2014 TriGlide Vivid Black - DK Custom Lift, 2" tank lift, DK Dual Cool, DK Discrete breather, Wards Parts Werks FCS, HD Reach Bars, all kinds of shiny stuff!
  14. #13
    300+ Posts
    Nov 2011
    Nampa, ID USA
    Quote Originally Posted by Koolbreeze View Post
    I went to Amazon to order these and their website says it does not fit my 2021 Tri Glide. If the 3157 is a replacement for the stock then I would think these would work. May just get the ones at AutoZone but would really like the ALLA. Can someone please verify that the ALLA really do fit the 2021 Tri Glide.
  15. #14
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Quote Originally Posted by DakotaTG View Post
    if they are ones in Kool Breeze's post; they worked just fine on my 21 TG. They were plug and play on my bike.
  16. #15
    Sylvania like others have not updated their web sites for 21 and newer models
    These bulbs all will work on these models, tho you may still have to run your 4 ways for a minute or two for the canbus system BCM to recognise the change
    You may set a DTC that you can easily clear also following this link you can look up most codes and scrolling down you can see how to read and clear the codes
    https://www.wilkinsharley.com/--Chec...rley-Davidsons
  17. DKCustoms postbit
  18. #16
    80+ Posts
    Aug 2016
    sebastian FL
    I switched my 2020 Freewheeler from the stock bulbs to the Sylvania "super bright" leds. It was a bit of an improvement.
    Then I went to the Eagle units. Night and day difference.
  19. #17
    Feb 2022
    Larimore, ND, usa
    Received these in the mail this morn. I put them in and yes indeed, they do fit perfectly. I love the way they flash when hitting the brakes, kinda have a strange flash for turn signals though. THEN, I turned up the volume on my radio. So much static it made the music hard to understand. Yea, serious static, and got much worse with turn signals applied, or brakes. They would work great for anyone not desiring to use the radio, for me, they came out and stock bulbs went back in. Don't know what I'm going to do with the ALLA bulbs but I can say they will not be going back on my '21 trike.
  20. #18
    70+ Posts Seaweed's Avatar
    Jan 2020
    Cape Cod, MA, USA
    I used the ProBEAM also from Custom Dynamics on my '15 front & rear. No radio issues, easy install.
  21. #19
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    Quote Originally Posted by FrozenInTime View Post
    Unfortunately this is a common issue with the "cheaper" LEDs. They produce a lot more noise due to weak EMI suppression. That's why I went with all Custom Dynamics in mine. If I had've went cheaper, with as many as I have added, I probably wouldn't be able to use my phone either. I just watched for sales or built up points at JP to get all of mine or used Harley gift cards I have been given. Sometimes it really is buy once, cry once.
  22. #20
    Jan 2023
    PORTAGE, mi,usa
    I did not find the leds to be any brighter than the original bulbs.
  1. Tail light & brake light ... Lehman GTL
    By CrystalPistol in forum Lehman Trike
    Last Post: 05-12-2020, 06:27 PM
  2. An inexpensive & simple LED Tail Light Upgrade!
    Last Post: 10-14-2018, 03:22 PM
  3. TG LED Tail Light Bulbs
    By DTR 11TG in forum Harley Tri Glide
    Last Post: 01-26-2015, 06:36 PM
  4. How to change rear tail light bulb on Roadsmith trike?
    By thumperjlb in forum Honda Trikes
    Last Post: 04-04-2014, 12:15 PM
  5. LED tail light bulbs
    By scooty in forum Harley Trike Conversions
    Last Post: 03-29-2012, 06:43 AM
