Likes Likes:  10
Thanks Thanks:  1
Results 1 to 10 of 10
Thread: Custom Dynamics delivers
    200+ Posts New Orleans Kevin's Avatar
    May 2021
    Arabi, LA USA
    Default Custom Dynamics delivers
    I’ve got an array of Custom Dynamics lighting on my 21 TriGlide and 17 FlHXS. Recently the Trike threw some codes and shut down all lights except headlight and brake lights. Diag revealed Bcm was shutting down as something was overloading . It turned out it was the pass through harness for my vent light ( with the module built in) on one side . One call to Custom Dynamics with an explanation of issue and one call to get process and get part shipped and then a few minutes to plug a new one in once it was delivered , free of charge, and all lights are up and running again. Kudos to Custom Dynamics for lifetime warranty and actually living up to their promise!
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    2019 Goldwing CSC
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    +++On CD. And thats the wonder of the BCM...allows the use of micro switches, eliminates a big honking fuse panel- with two miles of wiring could you imagine circuit protection for all that? If anyone has added passing aka auxiliary lamps all you need are the lamps/ buckets, a bit of wire, a on/ off switch and your in business (connector 109A). The BCM takes care of circuit protection and will turn off the aux lamps when you hit the high beams then back on again when high beams are off. And thats only one circuit!
    Quote Originally Posted by Old Road Dog View Post
    With all of my Triglides my dealer just flashed the BMC/EMC ? No charge so the spotlights will stay on with the high beams…👍
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Same here . . . and I run with high beam and running lights both on during the day. It is amazing how much better one's visibility is with high beam on even if running lights are off.
    May 2021
    Arabi, LA USA
    same here. Suddenly theres tons of deer visible on side some roads at night!!!!
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Thats not legal in every jurisdiction.
    Only in some jurisdictions........
    100+ Posts Cagmo's Avatar
    Jun 2016
    Glen Carbon, IL, USA
    Quote Originally Posted by ultrafxr View Post
    Me, too, Ultra. High beams and spots on all day long.
  11. #10
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    NJ it's illegal. Basically if they think it will dazzle or otherwise interfere with on coming traffics ability to see, i.e. Driving Lights, they can cite you. Don't think they enforce it all that vigorously, though.
  1. Custom Dynamics LED front turn signals
    Last Post: 10-11-2019, 07:52 PM
  2. Custom dynamics Rings
    By kybigmac in forum Yamaha Trikes
    Last Post: 01-28-2017, 10:05 AM
  3. freewheeler and custom dynamics flasher
    By GLT in forum General Discussion
    Last Post: 04-20-2016, 09:52 AM
  4. New Custom Dynamics LED headlamp
    By Hrolfr in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-06-2016, 09:06 AM
  5. Custom Dynamics
    By FLTR2008TRIKE in forum Accessories
    Last Post: 12-18-2012, 11:05 AM
