Likes Likes:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
Thread: Road*/Champion Rear Brakes
  1. #21
    80+ Posts Roadie's Avatar
    Oct 2013
    Fredericksburg, VA
    Default Re: Road*/Champion Rear Brakes
    Well gang, I finally got the brake issue ironed out - turns out that the main brake line from MC to rear of trike got too close to the rear cylinder exhaust pipe and collapsed - got it fixed (but still need to replace brake line) and I now have rear brakes - thanks to all who gave suggestions and advice.
  2. #22
    550+ Posts
    Feb 2012
    tupelo MS
    Quote Originally Posted by Roadie View Post
    Sounds like installer did a bu bu. did not check if all was done right.
    happen often from reading here on board.
  3. #23
    90+ Posts Chappy KC's Avatar
    Apr 2015
    Marion, Illinois
    Quote Originally Posted by saab9k View Post
    Hook hose to upper bleeder, make sure hose is in brake fluid.
    It will bleed all air out, gravity feed fluid from reservoir.
    saab9k....For this operation do I need to pump the pedal or just let gravity do it's job?
    2017 Can Am Spyder RT-S
  1. Replies: 5
    Last Post: 05-27-2022, 06:19 PM
  2. Champion/Road Star is Back
    Last Post: 04-06-2014, 01:04 PM
  3. Champion Rear Brakes
    Last Post: 03-24-2014, 10:15 AM
  4. Brake fluid for Champion rear brakes?
    By Shimpy in forum Champion Trike
    Last Post: 06-22-2013, 03:33 PM
  5. champion road star kit quality?
    By allanintexas in forum Miscellaneous
    Last Post: 04-27-2011, 09:17 PM
