Likes Likes:  4
Results 1 to 11 of 11
Thread: Ball platform for Hannigan trailer hitch
    80+ Posts Oldrodder's Avatar
    Mar 2018
    Sudbury, on. Canada
    Default Ball platform for Hannigan trailer hitch
    Is there a commercially available ball platform for this hitch? My 1 1/4" one is too big! Suggestions?
    Thanks,
    Mike
    100+ Posts ebiss9's Avatar
    Jan 2013
    Vineland, NJ USA
    Quote Originally Posted by Oldrodder View Post
    Thanks,
    Mike
    Hi Mike, Not sure what you mean by ball platform! Are you stating the ball hitch size? My Hannigan conversion kit was ordered with the hitch assembly and included a 1 7/8" ball which was the correct size for my Aspen camper. I don't believe the hitch assembly is commercially manufactured. I could take a few photo's of it if needed........Rob
    Rob Sprague
    Vineland, NJ
    2009 BMW R1200RT Black Metallic
    2006 BMW K1200LT/2012 Hannigan Trike Magnesium Black
    2004 BMW K1200GT Orient Blue
    Sep 2016
    Springfield, Mass. USA
    Thanks,
    Mike
    Mike, I'm not sure what you mean by "platform" either (sorry) My hitch assembly came with my bike also.. it also has a 1 7/8* ball.... If you mean the wrong sized ball (that can be replaced very easily... ** just unbolt it from the bottom**
    Mar 2018
    Sudbury, on. Canada
    Quote Originally Posted by ebiss9 View Post
    Rob,
    The ball platform is the part that holds the ball and is inserted into the receiver (hitch). They come in 1 1/4" 1 1/2" & 2" sizes as well as different drops. I bought my trike used and came with the receiver installed but missing the ball platform. My 1 1/4" is too big. I'm just wondering if Hannigan, in their wisdom, decided to use a non standard size.
    Thanks for your help.
    Jan 2013
    Vineland, NJ USA
    Rob,
    Huh, guess I never noticed the size discrepancy but it definitely is smaller than 1 1/4", (see picture). The tape measure is slightly skewed but you can see it looks like 1 3/16", odd size unless it's metric which is a little over 30 mm? It also fits slightly loose within the square receiver and Hannigan provides a bolt on the hitch assembly to take up any slack. It is a solid square bar. In any event it was part of the package from Hannigan so maybe e-mail or give them a call. You'll also notice I reversed the drop to up which makes my camper closer to level. With it on down drop it was too close to the ground for me........Rob
    Rob Sprague
    Vineland, NJ
    Rob,
    Bicycle shops sell them......Thats the receiver size for holding bicycle racks...
    Mar 2018
    Sudbury, on. Canada
    Thanks Rob. I might attempt to grind one to fit. I have three of them!!
    Mike
    Apr 2010
    Shenandoah Valley of Virginia
    Always heard that called a drawbar. it is a hair under 1-1/4" so that it doesn't get stuck over time in the often exactly 1-1/4" receiver. To eliminate slack or play, I went underneath and drill a hole up through receiver into drawbar ahead of cross pin and tapped it for a 3/8" bolt that I tighten, but then I usually leave my drawbar in place on the trike (like a bumper, has tail skid too) unless I use the hitch rack I built (and it too uses both the hitch pin & 3/8" bolt). I only ever heard of 1-1/4", 2" and now ... 3" receivers (really HD) except for a no longer made Reese hidden hitch on my Mercury GM that has a flat drawbar (about 3/4" thick but 3" wide).
    Sep 2016
    Do you have a Harbor Freight store in your area?? OR maybe a UHaul hitch store, I'd look there for your drawbar......
    Just a suggestion!
    Mar 2018
    Sudbury, on. Canada
    Spring is just around the corner here in Northern Ontario and I've neglected to work out a solution for this problem I might just take the Hannigan receiver off and install a "standard" 1 1/4" Problem solved!!
    Thanks everyone for all your advice!!
    Be well, stay safe during these trying times.
    Mar 2018
    Sudbury, on. Canada
    CrystalPistol, Could you post photos of the hitch rack that you built? I'm unable to PM you.
    If you prefer, you can send them to my e-mail.....tuff.32@fibreop.ca
    Thanks,
    Mike
  1. Receiver Hitch Platform
    By Alan Oakley in forum General Harley Chat
    Last Post: 07-12-2020, 05:25 PM
  2. Hannigan trailer hitch
    By alwrmcusn in forum Yamaha Trikes
    Last Post: 04-02-2013, 07:04 AM
  3. trike Platform,work stand.
    By BIBS in forum General Discussion
    Last Post: 11-08-2010, 01:48 PM
  4. Stallion Cargo Platform/Hitch Mounted
    By symplysimon in forum Stallion Trikes
    Last Post: 05-28-2009, 10:10 PM
  5. Trailer Ball Height
    By tis in forum Trailers / Campers
    Last Post: 05-28-2009, 07:07 AM
