Likes Likes:  100
Thanks Thanks:  3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 71
Thread: Escort trike build
  1. #41
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
  2. #42
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    have seen some prefairing european bikes, BMW? with a vinyl type of snap on fairing wind breaks. Thinking of doing similar....bigger windshield and some wind/water proof material to snap on or off, depending on precip/temperature.
  3. #43
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Quote Originally Posted by LarryA View Post
    I did that on my old Beemer motorcycle . Made "Hippo Hands" out of vinyl and then a section of vinyl to connect the hands to the fairing.
  4. #44
    40+ Posts
    Aug 2019
    Naples, Id, USA
    wheel well liners going in. Name:  IMG_1338.jpg
  5. #45
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by goodwrench View Post
    Got the floating brakes built and installed. All this stuff will be removed and finished welding and painted before it is done.
    Attachment 86173Attachment 86174
    with the weight on the front end .. i find if the pivot is about an inch lower than the axle it rides a lot better... think about pulling a loaded wheel barrow over a curb as opposed to pushing it
  6. #46
    40+ Posts
    Aug 2019
    Naples, Id, USA
    thanks . The pic you saw was when it was on jack stands but when on the ground the geometry is like what you said.
  7. #47
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Got it started today! Sounds great! A little sporty sounding. I just temporarily put the dash in where the plugs are. Have to lengthen all those wires that go to the front. It is a mass of wires!
  8. #48
    Well Done ... you got mad skills!
  9. #49
    ah yes wiring is always the fun part.
  10. #50
    Jun 2016
    milnor n.d. usa
    That first fireup sure renews your desire to get on with the project!... then back to work!
  11. #51
    40+ Posts
    Aug 2019
    Naples, Id, USA
    pics of progress, mostly wiring. Went to install speedo cable into speedometer and found out a chunk was broken off inside where cable goes so I ordered a used speedo head on ebay. Besides that found the ignition switch, clutch switch and reverse switch were shot! They had a hot wire to start it.Name:  IMG_1347.jpg
Size:  148.9 KBName:  IMG_1348.jpg
Size:  139.7 KBName:  IMG_1349.jpg
  12. #52
    Jun 2016
    milnor n.d. usa
    lol... wiring is enough of a challenge, then throw in bad existing components, and yet the possibility of bad new parts... great sport indeed!
  13. #53
    40+ Posts
    Aug 2019
    Naples, Id, USA
    You're right Larry. The first new ignition switch I bought wouldn't even work!
  14. #54
    Nov 2020
    Perry, Florida, United States
    Well heck! I went all the way through and at first wasn't too sure about it, but then it started shaping up and looked real good after paint. I got excited and couldn't wait to see the finish. lol Now we have to wait for more posts. Great idea posting as you go, I think when I start mine I will do the same, good job so far!
  15. #55
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Well I'll be gone south for warm and clear weather for a few months. Be back at it in April. here's the latest pic. Name:  IMG_1352.jpg
  16. #56
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Shaping up nice Jerry.
  17. #57
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Well I'm back at it again. Takes awhile to get going again after leaving it. So I'm finishing up the wiring. Got all the lights and horn working. Got the front brakes cleaned out reinstalled and halfway working. The master cyinder for these brakes doesn't put out enough fluid to run both brake calipers up front. So I ordered a different master cylinder that is for these brakes and will put it on the opossite side of the handlebars. This will be dual hand brakes, unless the new one will work both at once.
    Getting the aluminum sheet metal tomorrow for the body and panniers and front dust bin fairing.
    Have to hook up the motorcycle twist grip throttle also. A few weeks and the DMV guy can come and give me a vin number!
  18. #58
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Can't wait to see the finished pics Jerry
  19. #59
    40+ Posts
    Aug 2019
    Naples, Id, USA
    got the second front brake master cylinder installed and we now have functioning brakes up front. Installed the rear view mirrors. Hand throttle cable hooked up along with rostra cruise control witch came with the donor. Got to measure for floorboards. Having problem with weak connection to starter. Has new ignition switch, clutch switch. the wire goes into the fuse box and is connected to the rad fan for some reason. might be a high resistance there.
Size:  129.6 KBName:  IMG_1355_2.jpg
  20. #60
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Got her weighed today. with about 4 gal. gas and no sheet metal which will add another 30 or 40 lbs it weighs 1,500 lbs. Car original weight was 2385.
  1. PGR MISSION EScort.
    By Phill Griggs in forum Trike Travel
    Last Post: 11-01-2015, 10:41 PM
  2. My first Honor Flight escort
    By Thor in forum Military & Veterans
    Last Post: 10-08-2015, 04:32 PM
  3. Reverse Trike - Concept build
    By michaelplogue in forum Home Built Trikes
    Last Post: 01-28-2010, 11:02 AM
  4. New Member, trike build underway
    By pin-hi in forum New Member Introductions
    Last Post: 06-30-2009, 11:49 PM
  5. first step craz trike build
    By cra-ze-trikeman in forum General Discussion
    Last Post: 04-08-2009, 02:41 PM
