Likes Likes:  38
Page 2 of 2 FirstFirst 1 2
Results 21 to 39 of 39
Thread: Oil mist on my rear cylinder exhaust heat shield and right side fender
  1. #21
    Quote Originally Posted by Fitter View Post
    It's full but as we speak my wife is looking for the turkey baster!!
    I can't see that dropping the oil level a little with the way I ride hurting anything.
    You will be surprised, hot oil is going to expand
    Combine that with hard riding, the oil cannot find its way back to the oil pan fast enough and the head breathers are working as hard as they can
    IMO you should NOT have oil laying in the bottom of your air filter housing, if that is the case can you imagine how much oil is getting in thru the throttle plate?
    I have rode the snot out of a 15 and now my 17 Freewheeler, i keep the oil a bit more than 1/2 way up the stick and it does NOT puke oil JMO
    Good Luck and happy riding your Trike
    Check your oil level after a ride, how full or over full is it?
    1/2 way up the stick cold is where my 17 oil is supposed to be, when hot it will be closer to the full mark
  2. #22
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    After learning on here, I keep my 2017 FW 1/2 way up on the dipstick, when cold, as Jack said. It's perfect when checked hot & it never pukes any oil out my external breather.
    You can learn a lot on here if your open to it.
  3. #23
    Jul 2018
    Ruffin NC USA
    I am open to it and will act accordingly tomorrow.
    I defer to the knowledge on these these threads and will act accordingly.
    I'm learning.
  4. #24
    I'm learning.
    Alot of learning about Harleys is trial and error
    Harley , ( back in the AMF era) made a mistake in the shop repair manual
    This was a huge problem for many engines, that said some times the better info IMO is from tried and trued
  5. #25
    Like Yogi once said that he didn't say.....You can observe a lot just by watching....
  6. #26
    Jul 2018
    Ruffin NC USA
    Exactly rhino 2.
  7. #27
    That is how I taught my techs, then I watched them do it
    I always told them don't be afraid to ask questions, just don't question my authority
  8. #28
    Jul 2018
    Ruffin NC USA
    Jack I removed the oil and now I’ll see. Will report back with good or bad. Thanks for your input.
  9. #29
    Thumbs up
    Good on you
  10. #30
    Jul 2018
    Ruffin NC USA
    BTW I removed a shy 1/2 quart!
  11. #31
    That can make a difference , it would on mine
    I ran ALL my Harleys on the low side
  12. #32
    Jul 2018
    Ruffin NC USA
    Well like I said I removed a shy half quart of oil and have now ridden 300 or so miles and no more oil misting.
    Thanks all for your good advice!
  13. #33
    Thumbs up
    Good on you, now ride that hog
  14. #34
    Oct 2017
    St. Louis, MO USA
    I learned that from you!
  15. #35
    SHHHHHHH don't tell any one
    I owe you
  16. #36
    Nov 2017
    Delton, MI, USA
    I had the exact same problem with my 2017 Freewheeler. Turned out to be the "Y hose" inside the air cleaner had some small tears on both ends of the rubber. Replaced the hose and the oil misting on the right side stopped. Happy camper now!
  17. #37
    Quote Originally Posted by Red Dragon View Post
    Yup, those breather hoses live in a hostile environment IMO they are not rated for oil
    I replaced mine on my 15 Freewheeler twice under warranty
    The 17 M8 set up is just as cheesie IMO
    When ever I make a change to a work around to the stock HD set up I use either double wall hose or silicone hose
    The silicone hose is more spendy but it holds up to heat and oil way better
  18. #38
    Oct 2017
    St. Louis, MO USA
    When I modified mine to an external breather, I went with clear silicone & where it passes close to the engine, I split a black fuel line & covered it. After almost a year, it's still OK.
  19. #39
    1000+ Posts dannymax's Avatar
    Jan 2018
    Upper Hudson Valley, NY
    I did this mod but used heavy duty automotive fuel line to the catch can with a bracket to center it between the pipes. 1K miles with no sign of heat issues. Pretty amazed at the amount of oily vapor that gets removed.
    2017 Freewheeler
    Billet Silver
    Compassion for animals is intimately connected with goodness of character....and it
    may be confidently asserted that he who is cruel to animals,cannot be a good man.
  1. Removal of one heat shield
    By GoSlo in forum Harley Trike Conversions
    Last Post: 06-27-2016, 09:27 AM
  2. Right hand brake master cylinder paint falure
    By MB1953 in forum Harley Tri Glide
    Last Post: 02-28-2016, 07:04 PM
  3. Long ride shield vs freedom shield. Take 2
    By DonC in forum Harley Tri Glide
    Last Post: 11-23-2015, 09:57 PM
  4. Long ride shield vs freedom shield
    By DonC in forum Trike Travel
    Last Post: 11-04-2015, 02:54 PM
  5. Oil spots on right fender
    By sparky1597 in forum Harley Trike Conversions
    Last Post: 09-09-2013, 06:49 AM
