ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie1LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Likes Likes:  11
Results 1 to 8 of 8
Thread: Trike Brake Holder
    Apr 2010
    Shenandoah Valley of Virginia
    Default Trike Brake Holder
    We've had this trike since 2004. In the early years, I realized that when placed in neutral, like when being warmed up in front of the motel while I wipe dew off, etc, it will "roll" as there is no stand on it like a bike. I've seen others wish for a hold device other than "reverse" which I also wished for (I have reverse, I just do not wish to use it as a parking brake), then one day I had an idea. I've seen /read/heard tales of trikes rolling off from garage doors, etc as the owner exited to close a door … and down driveways into parked cars, the street … even into woods. A friend once had it happen and turned to grab the trike to stop it and it pulled them down too, messed up their wrist & arm as I recall.
    So, years ago … I used a piece of 3/8" aluminum 1.5" long, beveled on one end like a car ramp, and I added steps with a file. I hung it from a "ball chain" attached to the front brake hose with a zip tie. I've used it a lot, just apply the front brake with one hand and with the other, grab the wedge and insert in between the lever "tab" and lever bracket above the little button for front brake switch, release lever and brake was secure until next squeeze of the lever. I have long thought of adding a handle or something to make it easier with gloves on or just to "feel" direction if seated on the trike.
    Yesterday, I made a new one. This one is made from just 1/4" aluminum, 1.75" long, no steps, just a long slight bevel on one end. Being 1/4" thick, it will fit snuggly all the way in so no steps are needed. It remains 1/2" wide, I did drill a 1/4" hole and fully countersink a 1/4-20 SS screw with a nut lock-tited and a "cap" type nut on tip. I used a little different type chain. It works superbly, immediately dropping at the pull of the lever to hang ready for next time needed.
    I am thinking just from memory, that it'll work on 1200s & 1800s too, maybe others like Valks or VTX, maybe even HDs too?…. but this is on a GL1500. It's always there & to me, seems easier than messing with straps, bungies, etc. Mine, I've only used for short periods, and like I said, once set, just squeeze the lever and it'll drop on chain to be there next it's need.
    90+ Posts
    Sep 2012
    Magnolia, Ms USA
    I use a Velcro strap wrapped around the brake lever.
    David
    Apr 2010
    Quote Originally Posted by Warlock View Post
    I use a Velcro strap wrapped around the brake lever.David
    I tried that, still got it somewhere, it works, but the strap wasn't "always" handy or there with me.
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    I just use a bungee ball wrap. When not in use, I hang it on the mirror stem.
    250+ Posts wehrme's Avatar
    May 2014
    Decatur, IL
    Zip tie. Wrap around the reservoir, semi-snug fit for sizing.
    When needed, slip it off and put on front brake handle and grip.
    Brother Mike
    60+ Posts
    Oct 2012
    Cold Lake Alberta Canada
    Nice idea! I always put my trike in 1st gear. I will have one to fit my trike this year. Thanks!!!
    Apr 2010
    Quote Originally Posted by coolpoolken View Post
    I do too if not being left to run while I'm off.
    There have been a few times when I used it just to sit still for maybe others to form up on a group ride too, not just while wiping dew off as it warms, etc.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Why would anyone need to warm up a Goldwing?
  1. Cup Holder Ideas?
    By Juju in forum General Discussion
    Last Post: 04-14-2016, 10:02 PM
  2. Harley Drink Holder
    By BlueTrinity in forum Harley Trike Conversions
    Last Post: 09-10-2015, 06:03 PM
  3. GPS Holder for arm
    By burgman2170 in forum Accessories
    Last Post: 07-08-2011, 07:12 AM
  4. Flag holder
    By hitime in forum Accessories
    Last Post: 12-25-2009, 10:18 PM
  5. I designed a new MP3 holder
    By cjmitch in forum Accessories
    Last Post: 10-31-2008, 12:20 PM
