Likes Likes:  3
Results 1 to 9 of 9
Thread: No air in shocks
    30+ Posts
    n.ireland
    Default No air in shocks
    Phoned dealer today about ride seemed very hard,they said to let some air out,but there was no air in them,will it do any harm to ride to the dealer,thanks
    Dec 2013
    Clarion PA USA
    You can put air in them if they are not ruined. Remove right side cover air valve is in the top left side use hand pump to fill it doesn't take much do not use air compressor. check owners manual should be OK though. call dealer and let him know. Fred
    30+ Posts
    n.ireland
    thanks, it is a new 2017 model
    Quote Originally Posted by pflatout View Post
    If you used a tire air gauge to check it you might of let the air out yourself... For the air shock you need to use a No-loss air gauge..AKA Suspension Air Pump..
    But take it back to the dealer ,Just in case you do have a leak...
    If you had no air don't worry you just did not have any pre-load. The oil in the shock still did what it was designed to do. If the shocks are dry of any oil then they should be good.
    30+ Posts
    n.ireland
    Had a look today and there is no air line going to the valve and i an not see it.
    Dec 2013
    Clarion PA USA
    Get it back to the dealer and let them deal with it. Fred
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Or you can go to no air shock and get the ones that Kevin at DK custom products sells, I'm thinking of them since I lost 20lbs of air in 4 days, my road king shocks never lose air but the triglide does, will have to take a look at it, even over the whole winter I only lose 5lbs in the road king, must be a better shock built in 2002 than now.
    All for now Trampas
    30+ Posts
    n.ireland
    Cool
    I got a harley pump and put 30lbs in it and lost 5lbs in a day,i went to harley dealer they said they cannot find a leak,back from dealer 3 days and no leak,happy days
  1. new shocks
    By CaveManDave in forum VW Powered Trikes
    Last Post: 09-20-2016, 08:46 AM
  2. Shocks on a CSC
    By icedad in forum California Sidecar Trikes
    Owners Forum
    Last Post: 01-17-2013, 07:50 AM
  3. shocks
    By homer in forum Harley Trike Conversions
    Last Post: 11-22-2012, 10:30 AM
  4. Air shocks
    By Snooks in forum Honda Trikes
    Last Post: 04-25-2012, 05:00 AM
