Likes Likes:  19
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 40 of 68
Thread: Anyone install an LED brake/running/turn signal light on the trunk?
  1. #21
    80+ Posts
    Cochise, AZ USA
    Default Custom Dynamics
    Thanks for posting pics John.
    I'm just looking for a light assembly to put on the back of the trunk below the lock.
    No bears please. I would never be able to keep that with grandkids/Great grandkids.
    LB07
    Not good at this picture crap! Here is a pic of what should work for you! Brake Strobe LED Knight Riderz Light Bar
    It's $29.95 it is 4.5"L x 0.7" W x 0.7" H
    They have other types listed, I had a 7.5 in Knight Riderz light bar with the crazy dot moving back and forth for tail light and 4 strobe and then full on brake! One hole for wire and 3m stick it on in place of the reflect on the trunk!
    Use a heat gun or good blow dryer and the stick on harley comes right off; may need a little goo gone for a clean job!
    Check em out search knight riderz on their sight this one in pic used to come longer; i didn't see it!
    Sorry no pic's trike is totaled and gone!
    Dave
    Skip to the beginning of the images gallery
  2. #22
    300+ Posts RedOregon's Avatar
    Aug 2015
    south of San Antonio
    Can't believe I didn't catch this thread before. My bad.
    Here's your Knight Riderz in action. Made a bracket and mounted under the rack lip.
    https://photos.app.goo.gl/TNxvkEjHka9xwRRG2
    2024 Tri Glide! Only modifications so far - transferred Rider backrest from old 2015 Freewheeler, just added highway pegs!
  3. #23
    950+ Posts Free Bird's Avatar
    Mar 2018
    Saint Louis
    Quote Originally Posted by RedOregon View Post
    Nice!
  4. #24
    100+ Posts haute pursuit's Avatar
    Aug 2016
    houston, texas, usa
    Quote Originally Posted by DayWalker View Post
    Do you have photos?
    Sorry it took so long. I had to put the bike back in the shop to get some paint corrected. You can see the Radiantz LED bar in the recess of the trunk. It functions as running, brake and turns. It is plenty bright.
  5. #25
    Mar 2018
    Saint Louis
    Quote Originally Posted by haute pursuit View Post
    I like the fenders and the light relocation. Very nice installation. I will explore that option for my trike as well as I have a similar challenge with my fenders.
    Did you have to do anything special with the electrics or was it a direct swap. Like I said in an earlier post, a lot of what is needed on the new bikes/trikes is new to me.
    Was an electric load balancer needed? What approach did you take to tie in to the wire harness (i.e What's it look like inside the trunk?).
  6. #26
    Mar 2018
    Saint Louis
    Quote Originally Posted by Free Bird View Post
    PS.... Do you have any details/pics of your fenders and the assembly process as they were going on. You took a very sanitary way of integrating/attaching them to the body. I'd like to learn more about how you did that
  7. #27
    Aug 2016
    houston, texas, usa
    There is an extra circuit you have to buy from Radiantz that allows the running, brake, turn combo. We couldn't get the stock harness to function properly... so, did away with it and everything worked fine.
  8. #28
    Jun 2017
    RoTTENchester, NY, USA
  9. #29
    20+ Posts
    Jan 2017
    Vail, AZ USA
    MDO
    I read your post and decided I needed a center running/brake light. I decided on the Custom Dynamics LB03. It has a low for the running light and a hi flashing brake light. I was going to install it where the red reflector is under the trunk latch but decided I wanted it higher. I'm mounting it with a tee bracket on the seat screw. I found a brake light feed the 7A plug. I'm stuck for the moment because I can't get the pin blank out of the number 4 pin hole on 7B. If anyone can help me with that I would appreciate it. I don't want to force it and damage the plug.
    Once I get the wire install into the plug I'll be able to finish it and add a picture.
  10. #30
    Quote Originally Posted by Rick405 View Post
    MDO
    Try a paper clip
    We never bought the tool made by Thexton
  11. #31
    300+ Posts
    Mar 2018
    Waelder, Texas
    Rick, I'm having the same problem after mounting a LB01 light bar on my luggage rack. Think I will use posi-taps for the power and ground to the frame.
  12. #32
    20+ Posts
    Jan 2017
    Vail, AZ USA
    Yeah. I tried pushing them out from the front. Pushing them out from the back. I'm wondering if they are a one shot use. I was trying to keep the rear light circuits on the 7B connector but it will be a week or so before I can get a new connector. I thought about using Posi Taps too. If I do it will be done tomorrow. I'm going to have to use them or solder tap wires for the ground and running light so I will probably just go with a third one for the brakes.
    Thanks for letting me know it wasn't just me.
  13. #33
    20+ Posts
    Jan 2017
    Vail, AZ USA
    Thanks for the suggestion. I tried it. I got more movement pushing it towards the front than the rear. Never got it out.
  14. #34
    20+ Posts
    Jan 2017
    Vail, AZ USA
    Default This is what I did
    Thanks MDO. Once again I am using your ideas to make my trike better. First the Sylvania LED tail lights. Now a center running/brake light.
    As I said in an other post I went with the Custom Dynamics LB03. They call it Non-Sequential/Flashing Brake.
    I thought about putting it where the reflector is under the trunk latch but decided I wanted it higher. I used a tee bracket and mounted it to the seat screw. I used Posi Taps to connect it and it made it very easy. Here are
    some photos. It's actually brighter than the pictures show.
Size:  540.9 KBName:  IMG_0435.JPG
Size:  787.6 KBName:  IMG_0437.jpg
Size:  479.2 KBName:  IMG_0436.JPG
  15. #35
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Thanks for posting pics. I like the way it looks, but I can't do that.
    I have the luggage rack & when I travel long distance, I have a bag on the rack.
    That sure would make it easy to wire with the plugs being right there under the seat.
  16. #36
    20+ Posts
    Jan 2017
    Vail, AZ USA
    My '17 has a small access panel on the top left back of the trunk. May be for an OEM trunk light. It goes right to were the rear light cable is. The Custom Dynamic lights come with a 36" pig tail. Looks like it is a little short for going from the reflector under the latch to where the cable is but wouldn't take much to add a little. I would put some shrink tubing on the wire where it comes through the trunk and up to the top of the trunk liner. Then some split loom around the top of the trunk. I would use adhesive tie wrap mounts around the top of the trunk. A grommet through the access panel and a little silicone would make it waterproof .
    That's the way I would put the Custom Dynamic light where the reflector is. For what it's worth.
  17. #37
    Oct 2017
    St. Louis, MO USA
    What access panel are you referring to?
  18. #38
    300+ Posts
    Mar 2018
    Waelder, Texas
    Really clean install, Rick. That looks great.
  19. #39
    20+ Posts
    Jan 2017
    Vail, AZ USA
  20. #40
    20+ Posts
    Jan 2017
    Vail, AZ USA
    Quote Originally Posted by RKplus10 View Post
  1. **DK Custom-LED Running/Brake Light for License Plate Relo**
    By DK Custom Products in forum DK Custom Products
    Last Post: 09-06-2018, 02:13 PM
  2. Replies: 0
    Last Post: 01-05-2018, 02:13 PM
  3. flashing brake light install
    By schiel1 in forum Honda Trikes
    Last Post: 08-10-2015, 06:33 PM
  4. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  5. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
