Likes Likes:  14
Results 1 to 18 of 18
Thread: Suggestions for Replacement Wheel Bearings
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    Default Suggestions for Replacement Wheel Bearings
    I'm looking for a replacement set of wheel bearings for the front wheel on my 2013 TriGlide. I've checked with the dealer for OEM and they are $27 apiece. I've looked at JP Cycles, Arlen Ness, All Balls Racing and Drag Specialties. They run from the cheap to even more than MOCO. Cheap may not be the best; nor may the most expensive be the best.
    I want a safe, reliable bearing set at a reasonable price with a reasonable warranty.
    No, they haven't failed. I've pulled the bearings in my spare front wheel to have all three spares powdercoated.
    Suggestions? TIA.
    All Balls and Drag use the same vendor
    Find a parts store that can cross a HD part number to SKF
    250+ Posts
    Oct 2017
    Somewhere,Texas USA
    Da-eeeee-yum, PrairiePilot........that shot went way over my head!
    Cheers!
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Any bearing distributor should be able to cross reference the bearings to a quality bearing,as Jack said SKF or Timken. When it comes to bearings i dont skimp. when i replaced the bearings and races for my pull behind trailer for the trike i went with Timken $ 80.00 for 4 bearings and races seemed like a lot but as my daddy always said cheap aint good and good aint cheap.
    200+ Posts
    Nov 2015
    palm bay
    Quote Originally Posted by prariepilot View Post
    Suggestions? TIA.
    As others have said go with a known good brand from a jobber. I like Timkin but ymmv.
    Ask tour local auto parts dealer where they get their bearings and check there. I used to pay under $10 a bearing but that was a while back.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Replaced my front tire and repacked the bearings. I failed to look for a stamped number on them. If any one does find a USA replacement, please post the name brand and number to help us fellow brothers n sisters. Thanks.
    Apr 2016
    Default SKF Bearing Cross-Match
    The cross-matched bearing for replacing the MOCO #9276 with an SKF Bearing is 6205-2Rs. These bearings are specifically for NON-ABS application only. I don't know of any TG's that have ABS!
    I am a firm believer in keeping it Harley ... sort of ... Just seems to me $27 for a bearing for a 30+k trike is not that bad. After 4-5 years, your bearings are still good, why not replace the ones you pulled with what came out. I could see it if they failed, but, since they didn't, why change? You go cheap, you get cheap. Just MHO.
    Apr 2016
    Default Why buy Chinese?
    SKF and Timken have plants all over the world; those plants may be making the bearings H-D is using in all their applications. I've used SKF bearings in other applications. I've been to the SKF manufacturing facility in Gothenburg, Sweden. I've observed their manufacturing processes.Ferrari, Rolls Royce, NASCAR, F1 and MotoGP (motorcycle racing) use SKF bearings. If they make a better bearing and it costs less, why not use it? Betcha H-D is not paying more than three dollars each for their bearings. Going cheap just means you don't have to pay the H-D 800% mark-up.
  11. #10
    Sounds to me that you made your mind up before the thread was started ... as your entitled too.
  12. #11
    I have a friend in Canada that gets his bearings from a John Deere dealer
    Seems they fit agriculture equipment besides Harley's
  13. #12
    Apr 2016
    Default NOT!
    Timken and SKF are not the only bearings out there. I had not made my mind up before asking, or I wouldn't have asked. There is a wealth of knowledge on this forum and it is a shame to ignore it.
    I just do not prefer to deal with the "mother ship" and their grossly inflated prices. I'll buy a $30 bearing if it proves to be the best choice. Just NOT from H-D.
  14. #13
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Suggestions? TIA.
    Go on line to Just Balls I've used them on previous bikes and they are priced right
  15. #14
    Quote Originally Posted by lightnin View Post
    Did ya mean All Balls?
    If so Drag Specialties sells the same bearing
  16. #15
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    The SKF brgs and Fagg NSK or whatever just might be the supplier for the MOCO brgs. They don't make their own brgs and most likely only source the bearings that fit their specs from the lowest bidder.
    SKF of a given number and suffix letters or numbers are all the same no matter where you purchase. 2rs is 2 rubber seals.
    I don't know if the 6205-2rs is the correct bearing or not, but $27 bucks each is crazy ! I think that is for 2 brgs.
    A good buy on the 6205-2rs SKF bearings is like here on EBay:
    https://www.ebay.com/itm/6205-2RS-SKF-Brand-rubber-seals-bearing-6205-rs-ball-bearings-6205-rs-/141452005937
    Here is a listing on Drag Specialties kit (2 brgs) for the bike not by brg #.
    http://www.dragspecialties.com/produ...umber=02150225
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  17. DKCustoms postbit
  18. #16
    Jul 2012
    Chubbuck Idaho
    Default HD Wheel bearing
    By the way HD # for the TriGlide is 9276B in the fish catalog at Ronnies HD. and priced at $18.99. + shipping.
  19. #17
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I needed to get rear axle bearings for my 2014 Tri-Glide last week. Could have gotten them from All Balls, but knew they were made in China.
    So I ordered them from National Bearings, an American company I've gotten bearings from as long as 40+ years ago....
    ....and guess what...
    Made in China.
    They are installed now.
    www.DKCustom.com
  20. #18
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default Chineese crap
    I guess Thers a hold on the fact that Trump was gona change that ?
  1. 2017 Tri Lost wheel bearings.
    By hddocfl in forum Harley Tri Glide
    Last Post: 01-12-2018, 03:50 PM
  2. Freewheeler front wheel bearings failure
    By stratcpo in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-06-2017, 06:47 PM
  3. Front Wheel Bearings?
    By BinIdaho in forum Harley Tri Glide
    Last Post: 05-03-2016, 10:43 AM
  4. Front wheel bearings
    By howardg in forum General Discussion
    Last Post: 04-25-2015, 03:38 PM
  5. Stallion Wheel Bearings/Hubs
    By gctrikeguy in forum Stallion Trikes
    Last Post: 10-21-2014, 09:30 PM
