Results 1 to 5 of 5
Thread: Differential / Transmission Sound
    10+ Posts raescuin's Avatar
    Jun 2019
    Las Vegas
    Default Differential / Transmission Sound
    On my 2012 GL1800 with Roadsmith trike kit, I'm noticing a sound like humming and slight grinding on all gears. I noticed there's no play or back and forth movement on the drive shaft between the transmission and differential. There is a ring that adjust the movement. My question is how much back and forth movement should it have? Thanks
  2. Roadsmith banner
  3. #2
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by raescuin View Post
    Where do you see this "ring"?
    I wouldn't expect to see any end to end free movement of the drive shaft once it's in place.
    Not to say you don't have a bad or failing U-joint …
    … just that driveshaft should not move freely forwards or backwards once put in place.
  4. #3
    Jun 2019
    Las Vegas
    The U-Joints are fine. The ring is located towards differential side. I think the ring prevents the shaft from coming off the transmission. I've adjusted the ring with a 1/4" movement back and forth and I don't hear the noise anymore but I'm not sure if that was right.
    I've also loosened the ring and when I pull the drive shaft towards differential it comes off the transmission shaft.
    I hope the picture helps. and thank you.
  5. #4
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    I have no firsthand knowledge but I believe the front yolk should be attached to the trans output shaft.I do not believe that split collar is something Roadsmith did.Hopefully someone with more knowledge will chime in soon.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
  6. #5
    Jun 2019
    Las Vegas
    Spoke with the Roadsmith Trike shop and they recommended a 1/16-1/8" play. While I was on it I grease the spline (it was dry) and did a ride test and it was a quiet ride. The noise is gone.. Thank you for the support.
  1. zerk on differential?
    By bikerbill in forum Harley Trike Conversions
    Last Post: 04-14-2024, 06:19 PM
  2. Tri Glide differential bearings.
    By bobscogin in forum Harley Tri Glide
    Last Post: 06-23-2020, 02:34 PM
  3. Champion Differential
    By tingrin in forum Champion Trike
    Last Post: 05-15-2020, 12:29 PM
  4. Differential offset
    By Jakeboy in forum General Discussion
    Last Post: 01-16-2012, 12:44 AM
  5. Rear Differential
    By Davidf66 in forum General Discussion
    Last Post: 02-04-2010, 03:24 PM
