Likes Likes:  4
Thanks Thanks:  8
Results 1 to 16 of 16
Thread: Trailering a Tri Glide
    40+ Posts
    Oct 2015
    NUNYA
    Default Trailering a Tri Glide
    What is the best way to tie down a Tri Glide on a trailer. I've tried several different methods and I don't like anything I've been able to come up with.
    Trail Rider
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    We haul our trike from Michigan to Maggie Valley and to Texas, every year. We use a trap style chock from HF. works as good as the expensive ones. https://www.harborfreight.com/1800-l...ock-61670.html
    We bolt it in the wood floor with Tee nuts under the floor and eye bolts, working as bolts with a handle. No tools involved. 2 hooked straps to the trailer hitch, keep the rear from sliding around.
    Quote Originally Posted by Trailridr View Post
    Trail Rider
    Under each rear shocks there is a tie down loop.....Thats where i Strapped mine..
    With the front i ran a strap though the wheel....Careful not to hit the rotor...and a towel between the strap and wheel so as not to scratch/mar it...
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    X2 how rhino does it. I have a cheap chock from I-can't-remember-where. I use two short ratchet straps to the tie down hooks under the back and then one through the front rim (with mircofiber in between).
    Probably hauled my 2016 and my current TG through 25 or more states the past 2 years with zero issues.
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
    +2 on the tie downs ... I put the front wheel in my python, wrap a short ratcheting strap arround the front wheel and python. Then I run a strap from each tie down to the sides about where the tranny starts piulling it forward and centering ... Works like a charm.
    I avoid the cheaper HF straps, they sell some that are rated at like 1200# and are like 2" wide.
    40+ Posts Rider70's Avatar
    Jun 2019
    Gettysburg, PA, USA
    Default Tie downs
    I just trailered min from Delaware to Pennsylvania. I used two of these, or something similar,
    https://www.amazon.com/Seamander-Securing-Motorcycles-Scooters-Equipment
    one on each handlebar making sure the attached ratchet strap did not touch the bike in any place, and also the two loops underneath by each tire as that’s what they’re for. At least that’s what my boys tell me.
    Made for a 4 point tie down.
    Set the parking brake and left it in gear. Didn’t move an inch.
    20+ Posts
    Mar 2019
    Columbus, GA, USA
    Default Straps on Front wheel
    Quote Originally Posted by ISP-FL View Post
    I bought some 3 in wide rubber blocks that have openings to pass the strap through and make sure the rubber block is on the front rim to remove the possiblity of the strap chaffing and thereby breaking. I use 2 in straps that are rated at 3,500 lbs. I towed my old Sportster with a Lehman coversion that way with the front wheel off the ground.
    The new(er) Tri Glide is too low in the back end for me to haul it that way, so I guess a trailer is necessary! I will however be using the same rubber blocks for the front wheel and I like the HF trap wheel chock.
    I noticed two loops, that look like links of a chain, under the trike when I was swapping out the mufflers and I assume those are the 'tow strap down rings.'
    200+ Posts whitefatboy's Avatar
    Feb 2011
    davison,MI.,USA
    Default trailering triglide
    Just remember to put bike in travel mode
    Quote Originally Posted by RDinGA View Post
    Yes they are............
  11. #10
    20+ Posts
    Mar 2019
    Columbus, GA, USA
    Default newbie question?
    Quote Originally Posted by whitefatboy View Post
    Travel Mode?
  12. #11
    Travel Mode?
    2014 and newer .........With your FOB in range, turn the ignition switch to IGNITION.
    Before the security light gos out turn the ignition switch to OFF...
    Within 3 seconds press both turn signals at the same time...
    The turn signals will flash once, And the system enters transport mode...
    Remove the FOB now your Trike can be moved without trigging the alarm/4 way flashers so as not to run down the battery when you are trailing...
    To exit transport mode...have the FOB in range and turn the ignition switch on,,,And that will disable transport mode....
  13. #12
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    What's this trailering concept you're talking about?
    IBA#61162
    PATRIOT GUARD
    USMC
  14. #13
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    I am thinking my 2014 the turn signals flash three times when it enters transport mode.
    2019 Goldwing CSC
  15. #14
    Quote Originally Posted by woody View Post
    ...Could be three, Been a while since i monkeyed with the transport mode....
    But then again what's the difference between two extra flashes amongst friends.....
  16. #15
    2014 models and newer:
    1. With an assigned fob within range, turn the ignition switch to IGNITION.
    2. Before the security system lamp goes out, turn the ignition switch to OFF.
    3. Within three seconds, simultaneously press both the left and the right turn signal switches.
    4. The turn signals will flash once, and the system enters transport mode.
    5. Remove the fob- your motorcycle can now be moved without triggering the alarm.
    To exit transport mode, make sure your assigned fob is within range, and turn your bike’s ignition switch back to IGNITION. Now you're ready to ride.
  17. DKCustoms postbit
  18. #16
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    When following the procedure, they will flash once immediately when you hit both turn signals, then 3 times a second later.
  1. Trailering a Stallion
    By Dean H in forum Stallion Trikes
    Last Post: 08-10-2011, 11:06 PM
  2. Trailering to Maggie Valley?
    By spiritdream in forum Other Rallies & Rides
    Last Post: 04-04-2011, 11:51 AM
  3. Trailering a stallion
    By ODDOMAN in forum New Member Introductions
    Last Post: 09-19-2010, 10:52 PM
  4. Trailering a Trike
    By robandlyn in forum Trailers / Campers
    Last Post: 10-20-2009, 09:06 PM
  5. Trailering a power wheelchair?
    By dwiht in forum Trailers / Campers
    Last Post: 08-14-2009, 10:14 PM
