SSpoon11hogmemberisoldNew Member Introduct...Hello from VA
SSpoon11ol' schoolNew Member Introduct...Hello from VA
SSpoon11Marc HNew Member Introduct...Hello from VA
SSpoon11ZammyNew Member Introduct...Hello from VA
SSpoon11Uncle FesterNew Member Introduct...Hello from VA
SSpoon11rhino 2New Member Introduct...Hello from VA
SSpoon11trike ladyNew Member Introduct...Hello from VA
SSpoon11SullyNew Member Introduct...Hello from VA
SSpoon11Jack KlarichNew Member Introduct...Hello from VA
SSpoon11GorillaNew Member Introduct...Hello from VA
SSpoon11SSpoonNew Member Introduct...Hello from VA
Results 1 to 10 of 10
Thread: Another question
    1750+ Posts slick rick's Avatar
    Aug 2012
    Dora Al
    Thumbs up Another question
    I know[ he needs help again],but if you dont ask you dont know:. My question 'changing from cable to hydraulic operated clutch, what parts are needed, would like to go with good quality parts. So I know I am a little dumb to all this but give me a little time.All imfo will be appreciated thank rick.
    Default Re: Another question
    Rick there is no dumb questions. That is why there is a forum to help those that need info. There are several companies that make a hydraulic kit for VW modifications. There are a lot of sand bugs out there that VW trikes use the same stuff off of. Basically you will need the master cylinder with either your hand lever a foot pedal setup. Then either steel tubing or there is flexible reinforced plastic tubing available. Then you need the slave cylinder at the clutch. They are really pretty straight forward. Hope this helps.
    80+ Posts classicfins's Avatar
    Feb 2011
    Ruston, La USA
    I've never dealt with the company before, but Possum Pride Trikes has some parts and kits you can look at. If nothing else it will give you an idea of what you are looking for.
    Custom VW Trike Bodies, Fenders, and Accessories-Possum Pride
    Doug Young
    Ruston, La
    Proud VW Trike Owner
    '86 Stallion built by Arizona Trikes
    Some people are like slinkies...
    Not much good for anything, but they sure are fun to push down the stairs...
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Hers a view of what the transaxle will need. Just add a master cylinder. You might need to put a 2 lb residual valve in the line if the master cylinder sits lower then the slave cylinder. This will keep the fluid from bleeding back into the master cylinder .
    SLAVE SAVER BRACKET FOR MENDEOLA TRANSMISSIONS WITH 5/16 HEIM JOINT FOR CNC, NEAL, WILWOOD SLAVE
    http://www.appletreeauto.com/VW-BRAK...ESSURE-VALVES/
    Aug 2012
    Dora Al
    Thanks Gorilla,what I have found on this site is some one is always willing to help.A little about the trike, built by Arizona Trike [Scorpion] revamped in 2006 changed fat boy tanks, added custom paint, and other things so that being said would like to retain original side mounted pedals.While doing this it will create a angle will it still work.Another question what is the best parts to use again thanks.
    Aug 2012
    Dora Al
    hey guys proves what I said while thanking Gorilla others chimed in, thanks will look at all this .Is it worth the change seems to be on everything I read again thanks rick
    100+ Posts matman1972's Avatar
    Dec 2012
    austell, GA, USA
    Quote Originally Posted by slick rick View Post
    Absolutely! I love mine. no problems for 7 years. I do need to rebuild the slave cylinder sometime soon as I am getting a slight weep from it, but I wouldn't trade it back to cable. I use a foot lever on the left for my clutch, and I also have my slave cylinder set higher than my master, but it has never caused any problems yet.
    I really like it in stop and go traffic.
    Got all my parts here. Pacific Customs Dune Buggy Parts, Sandrail Parts, VW Parts
    Aug 2012
    Dora Al
    Hey thanks guys done the research, one more question seems mounting brackets for slave cylinder are for type I or type II bus.Now what I have is a typeIII does it make a difference .Again guys thank you.
    70+ Posts
    Mar 2009
    Vale, NC USA
    Rick, Type 3 and type 1 VW trans are the same.
    The clear poly brake lines from EMPI have been discontinued. I tried several times to find one. What I did for a flexible line for mine was to use a VW rear flex line and bought one long piece of hard line with the correct double flare fittings to fit it. I then cut that in two to the correct lengths (one very short for the slave) and re-flared with the correct ends for the slave and master cylinders.
    Aug 2012
    Dora Al
    Thanks Chromedome,this will be on my[ got to be done list before riding season].Riding season is almost here and just getting more and more anxious.I got this trike late in season and one of many favorite places to ride is Natchez Trace, just cannot wait.I went for a short ride on my bike and found it not to be as comfortable as I remember, dont think I want to ride both.Guys for a lot of years have owned ,and even worked on big trucks,riding bikes most my life,built a custom bike in 04,sold in 07,but know very little about a VW.So again thanks rick
  1. GPS question
    By Thomkm in forum Harley Trike Conversions
    Last Post: 02-26-2012, 11:29 AM
  2. Question:
    By BWBlack in forum General Discussion
    Last Post: 10-02-2011, 03:48 PM
  3. To be, or Not to be, is the question
    By hoofsmit in forum Harley Trike Conversions
    Last Post: 01-03-2011, 01:17 PM
  4. My first question
    By Stephen in forum General Discussion
    Last Post: 07-06-2010, 11:06 PM
  5. VTX Question
    By oldnewby in forum Honda Trikes
    Last Post: 03-16-2010, 11:25 PM
