gfaltersack3Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
Likes Likes:  8
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 48
Thread: Tri Glide trunk lock
  1. #21
    100+ Posts nevtat's Avatar
    Aug 2010
    Las Vegas, NV
    Default Trunk lock
    On my 2012, I use a firm hand to close the trunk and I lock it every time. Have not had an issue yet.
  2. #22
    Sep 2014
    Box Elder, SD
    When the tri glide was new, the rear trunk opened one time. I have used dry silicone lube and no problems. I learned not to slam, push and pull, then lock. Jim
  3. #23
    200+ Posts scuba1954's Avatar
    Sep 2013
    Monroe, Ohio
    I see you are not too far from me. Where do you buy this stuff ??
    Meijer s
    Hi, I'm Mike and I'm a Chromahualic!http://www.hdforums.com/forum/images.../icon_bike.gif
  4. #24
    TOI - Idaho BinIdaho's Avatar
    May 2009
    Caldwell, Idaho
    Quote Originally Posted by geezerglide11441 View Post
    Probably from "slamming" the trunk door closed!! Mine broke the plastic that holds it in and I just had a new lock installed and adjusted by the HD Technician and now all I have to do is push it shut and press with the palm of my hand and it works better than it did new (2013 TriGlide). Also during the experience we ordered a new "black plastic" housing that broke and fixed the existing OEM lock. When mine finally broke, the push button came almost out and I just took a hold of what was sticking out and it came out very easy.
    Bottom line, "do not slam the door closed" as the plastic that holds the lock in will not take it. If you have to slam the door, use a small amount of WD-40 and continue to close it easy and press to latch with the palm of your hand. Works for me anyway!!!
    Roger
    Excellent advice....the trunk lock on my 09 TG literally "flew" across the garage floor! Yes, I was slamming the door shut. After HD tech instructions, I gently close and lock trunk.
    Barbara
    2020 HD Tri-Glide
    River Rock Gray/Black Accents
  5. #25
    Apr 2013
    Redmond
    Quote Originally Posted by BinIdaho View Post
    Yup, works every time!!
    Roger
  7. #26
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    On my '13 I push on the trunk 'til I hear a click than push hard one more time 'til I hear a second click. Then lock it.....no problems with it coming open. Think 'slamming' it would break something..
    8~\o
  8. #27
    Apr 2013
    Redmond
    Quote Originally Posted by Texan View Post
    On my '13 I push on the trunk 'til I hear a click than push hard one more time 'til I hear a second click. Then lock it.....no problems with it coming open. Think 'slamming' it would bread something..
    8~\o
    I guarantee that "slamming it" will eventually break the plastic that holds the lock set in place!! Don't ask me how I know!!
    Roger
  9. #28
    Jan 2012
    chesnee sc
    Default Just got back from dealer
    Had lock replaced and adjusted under warrenty. Will see if this works
  10. #29
    May 2009
    Caldwell, Idaho
    Roger
    That makes two of us ....bet we weren't the only ones.
    Barbara
    2020 HD Tri-Glide
  11. #30
    Apr 2013
    Redmond
    Quote Originally Posted by jfoster View Post
    Just make sure you don't slam it and it will last a LONG time!!
    Roger
    Yup!!
    Roger
  12. #31
    100+ Posts Tadgh45's Avatar
    Jan 2015
    South Plainfield,NJ,USA
    I have had multiple locking / unlocking issues with my 2015 Tri-Glide. Mentioned it to dealer at my last service and they adjusted and oiled it. No problem since.
    I did see a nice older couple have their trunk pop open on the Patriots ride from Fairfax to Rolling Thunder at the Pentagon last year. Fortunately I was able to get up them and tell them before their gear fell out. I was 3 bikes back from them in the alternate row and I couldn't believe that the guy directly behind them made no effort to tell them!
    Tadgh45
    2015 Harley Tri-Glide, Mysterious Red Sunglo
    V&H Duals, 4" Rineharts, SE ventilation, DK Custom lift kit & lots more.
    Amateur extra / VE. Call- AB2ZK
    OEM/CERT/RACES/ARES/AUXCOMM & Skywarn
    NRA Benefactor member
    V.P. Firefighters Brotherhood MC
  13. #32
    1250+ Posts Dave59's Avatar
    Dec 2015
    Mayville Wi USA
    I haven't had mine pop open but sometimes I have a very hard time getting it to close.
    "No matter what you ride, give respect to get respect"
    2016 Billet Silver/Black Tri Glide
  14. #33
    80+ Posts Jd1a's Avatar
    Oct 2018
    Waddell, AZ USA
    The dealer told me to push the door closed, don't slam it. My 2019 door poped open once so far on the first ride, rough road. Trip back was OK, 72 miles on it now.
  15. #34
    On my 11 Tri-Glide i had the door pop open twice ,And so i took a very small 9 inch bungie hooked it from one to the other lanyard support cable and the tension was just enough to keep it from popping open...50+ k on that one And i did the same on my 17 Tri-Glide only 8k+ on that one before i sold it...
  16. #35
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Since I started this thread 2 yrs ago, figured I should update. 32,000 miles later, trunk only popped one time (a long time ago) Dealer did a small adjustment & has not done it since. That was over a year a half ago. Gently push closed & lock. Ride safe everyone that can still ride. Winter Woes already. Maybe need to move in with Lady On a Mission. Janiene & I will be there soon Lola. lololol
  17. DKCustoms postbit
  18. #36
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    8 years, 3 TG's and over 75K miles and I've never had a trunk lock problem. I slowly close the door until it contacts the lock and then a firm little push. Catches every time. I've also never had the door open while riding either.
    I see other riders constantly slamming the door - no wonder they don't work. Weren't you ever told when you were a kid "Never slam or force anything"?
    IBA#61162
    PATRIOT GUARD
    USMC
  19. #37
    90+ Posts
    Oct 2015
    Indianapolis
    I have had a long history of my 15 TG trunk popping open. I put a washer under the trunk lid plunger to give it a little added height. On a trip to Louisiana from Indiana last October, it was still popping open. I stopped at a Wal Mart in Arkansas on the way back home and bought another washer and that added thickness made all the difference. It never popped open again the rest of the way home.
    You would think an expensive machine like the TG would have a better locking system.
  20. #38
    Aug 2010
    Las Vegas, NV
    My 11 Tri's trunk when it was new would pop open '' After the second time i very carefully adjusted the latch pin [spade] and it hasn't opened since then... Once last summer for the first time i locked the trunk' and it took a heck of a time to unlock it... That was the first time i ever locked it and the last... Probably dirt got in it...
    I keep my 2012 truck locked at all times. I also give it a tug once it's closed. A few drops of 3-in-1 oil keeps it fresh.
  21. #39
    150+ Posts greyfang's Avatar
    Nov 2010
    Loveland, Colorado
    Default Trunk lock
    For people that lube their locks, is it from the front or back?
  22. #40
    Quote Originally Posted by greyfang View Post
    When i did.......Right though the key AKA Barrow key hole...
  1. Freewheeler Trunk lock
    By manny in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-24-2022, 01:41 AM
  2. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  3. Trunk lock handle
    By adventurer 08 in forum Yamaha Trikes
    Last Post: 12-03-2013, 09:16 AM
  4. TG Trunk lock
    By Bones in forum Harley Tri Glide
    Last Post: 12-06-2011, 10:13 PM
