Results 1 to 7 of 7
Thread: Phone freeze alert
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Default Phone freeze alert
    Anybody using one. I'm trying to find a low temp phone dialer. I saw one a while back, but of course I can't find it now. I don't want any wifi or internet. Has to call from a landline to a landline. I found one I could set the low temperature on. I need it to call at about 60 degrees. I can find them for 42 to 45 degrees preset. But that's not that useful to me,as I'm over two hours away. Pipes will be freezing before I can get there. Also has to work during power failure. Anybody? Just to be clear no cell service at the cabin.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I have a wireless alarm at my garage . No internet required . However it goes thru a alarm company . Look up “Tellafreeze” I think that might be the one you want
    Thermalarm is another adjustable one . If you cut out the fixed sensor , and wire the adjustable one into the dialer box . After all , the sensors are just switches to activate the dialer box .
    400+ Posts
    Feb 2015
    Sussex nj usa
    Thanks Frank I looked up thermalarm nothing comes up.
    Telefreeze looks good but what's a dialer box. Looked that up and only brings up the help I've fallen and I can't get up. alarm callers.
    At our club house we just shut the well pump off open all the valves and faucets..Drain the water pressure tank and the Cold water heater...And we are done that is till someone forgets the draining procedure...
    400+ Posts
    Feb 2015
    Sussex nj usa
    Can't be doin that every weekend I go to the cabin. Lol. My house is the problem not the cabin.
    ViceVersa, Now i get it..........
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    The dialer box calls you when the temp is lower than the setting. Being most have a fixed setting , the thermalarm lll thermostat can be adjusted at your 60° temp , or higher .
  1. Which anti-freeze, green or pink?
    By lightnin in forum Harley Tri Glide
    Last Post: 06-09-2018, 07:06 PM
  2. Anti freeze leak
    By Rat Fink in forum Harley Tri Glide
    Last Post: 01-04-2017, 11:31 PM
  3. Anti-Freeze leak
    By Gorilla in forum Stallion Trikes
    Last Post: 04-11-2012, 10:51 AM
  4. Duel problem maybe Oil & Anti Freeze
    By kj5ix in forum Yamaha Trikes
    Last Post: 01-21-2011, 11:38 PM
  5. stallion alert
    By jimc in forum Stallion Trikes
    Last Post: 10-10-2010, 11:05 PM
