Likes Likes:  6
Results 1 to 14 of 14
Thread: Water Softener
    Apr 2010
    Shenandoah Valley of Virginia
    Default Water Softener
    Last winter we were in Lowe's, saw a clearance display with a nice price on a Water Softener. Well, my old one was starting to leak in a valve and it was 25 years old, and I wanted to switch to Potassium Chloride softener salt, so I bought it. It's installed and full and is working well …
    … but I have the old one on my basement stoop, and that sucker is heavy. I got most all the old Sodium Chloride out as well as water, I can off load it at the recycle center … but did I mention it's heavy. No hand holds. Tomorrow, I'm gonna take a sawsall to it, cut the resin tank and put resins in old coffee cans. They are mostly plastic anyway, no biohazards. Just a mess, but I bet it'll be some lighter.
    https://www.triketalk.com/forum/thre...odium-Chloride
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Cut it lengthways , they make a good BBQ .
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    Maybe wearing PPE would be a good idea. Better safe that sorry.
    Apr 2010
    The outside is plastic, the resin tank looks like fiberglass?
    Cut hand holes with the saws-all ....Wear gloves....
    Dec 2012
    Santee
    Be careful and don't spill the resin beads. If you get enough on your shoes it is like trying to walk on Ice. Where I used to work, we changed out the resin in our water softener, two tanks with 30 cu. ft. per tank. It was a mess. Most was sucked out by a vacuum truck.
    Ray
    2017 Harley Triglide
    Tijuana Border
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Sounds like a job for explosives.
    150+ Posts kodiak198's Avatar
    Oct 2018
    Johnson City, TN, United States
    Yah, detonate in place, that should do it.
    It takes years to develop trust, it only takes a moment to lose it.
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Be sure to take and post videos. Could be a very entertaining show.....! Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Ok , I thought it was one of those galvanized monsters.
    900+ Posts
    Bellville, Texas, USA
    Maybe call in a Napalm strike and incinerate it?
    Sunman
    2250+ Posts
    Ocala, Florida
    About cutting that fiberglass: PPE would be a good idea here as you don't want to inhale the dust of fiberglass.
    PC
    Beware of liberals posing as Americans.
    Apr 2010
    No, but I think as heavy as a new dry one is, this one is heavier because it maybe has a water logged resin tank, not dry resins.
    I thought about cutting hand holds in the outer body but wonder if the plastic will tear like if I run straps through them and use a come a long hung from a beam to lift and back my truck under it. I'd have to "drop" the thing off the tailgate at the recycle center. Like said, I have most of the salt out of it, I moved it outside with my hand truck.
    I hauled one to the dump years ago, it was a manual one, it turned over in my truck and made a mess. I was younger and did not own a sawsall then either.
    Yeah, I'll aim to at least photo whatever I do, I know I'm not the first.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Might be worth it to have the proper company come in and remove it for you... a sting in the pocketbook but DONE and out of your life...without wrecking/messing anything or your body...
  1. Replies: 14
    Last Post: 09-09-2018, 09:02 AM
  2. Road Water/Dirt Issues?
    By Jenady in forum Harley Trike Conversions
    Last Post: 01-18-2013, 02:52 PM
  3. Any water babies out there? Got to see this...
    By Mr.Wizard in forum General Discussion
    Last Post: 12-15-2012, 08:12 PM
  4. Water between the tour pak.....
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 06-08-2012, 08:12 AM
