Likes Likes:  26
Thanks Thanks:  1
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 53
Thread: Intermittent electrical
  1. #21
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Battery
    I do have a Haynes manual..my next move is to go from switch onward see what is going on.
  2. #22
    Quote Originally Posted by Clevelandpat View Post
    Good luck. Electrical is a real pain sometimes
    You have a good plan, by elimination you should get it
  3. #23
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default The sga
    Ok. Looks like I had a couple corroded connections and the power issue is corrected. Engine cranks good but no start. No spark at plugs. Center wire to coil has power but nothing coming from coils. I read some other posts of a possible angle sensor. Where is it located? Any ideas?
  4. #24
    If you follow the link in post 11 it will show you how to scan your ECM for codes, if your sensor is bad it should show a code
    Most trouble codes I have seen are related to crank or cam sensors, they will kill your spark
    Good on you for finding your cranking problem, stay with it and you will figure it out
  5. #25
    I believe the sensor is part of the turn signal module
    That should turn up a code when you scan the ECM follow post #11 to scan for codes
  6. #26
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Working
    Ok I found sensor connection at the module and tested sensor..1st test was .5.2nd test was 4.5 3rd 1.0. The connector seemed loose so I reassembled and it seemed secure. Bike starts right up and idles good..does not die in a few seconds like it did prior. I also went to the speedometer reset and read code d01clr. Is that code good? Thanks for all your help.
  7. #27
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Glad you found the culprit & thanks for letting us know.
  8. #28
    Good on you for sticking with it, I do not see your final code on a list
    The proof will be in the running of your Trike, good luck
  9. #29
    Update on your code, it is a speedometer code that checked the speed sensor showing the code is clear.
    I have not seen this list of codes before. The early 1999-03 bikes had some strange codes and a totally different way to check them. Go back to post 11 for info on that, or possible your Clymer or Haynes manual shows that.
  10. #30
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Code
    D01cLR...clear correct?
  11. #31
    Yes
  12. #32
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Back to the drawing board.
    I thought I had issue figured out but I guess not. Took bike down to the corner and back and it died. Light out everything dead. 5 to 10 seconds later everything comes on..it will crank. Backfire..run good about 5 to 10 seconds and die again. I believe it's that sensor as some of you thought. Anything else you can think of?
  13. #33
    Do you have a check engine light on?
    The problem you continue to have sure sounds like a crank sensor, it surely should show up on a diagnostic scan as low or no output
  14. #34
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default CEL
    Yes cel is illuminated..dealer didn't have one the other day suppose to be in on Wednesday.
  15. #35
    Have you checked the wires to the sensor? They do sometimes break from vibration, tho I am leaning more to the pick up coil in that sensor has shorted
    Good luck and do check back in when your problem is fixed
  16. #36
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Wiring
    Seems to be inorder. Kind of a pain to get to by that filter. Anything special I need to know installing?
  17. #37
    Lube the new O ring, check the torque value of the bolt in your manual, a bit of dilectric grease on the wire connection will be a plus
  18. #38
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Sensor
    One question.. Will that failed sensor cause the electrical system to completely go blank. This bike will start and run 5 to 10 sec then quit. No lights no nothing. Wait about 10 seconds the lights come back on.
  19. #39
    I have not seen that, electrical problems have a cursed past.
    Check your wires on the starter, make sure you have good and clean connections. Also pull you main fuse and clean the connections just for grins
    Anything is possible under the right conditions
  20. #40
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Starter?
    When the bike acts up as I said "the lights go out" literally. It's like you turn switch off. You wait a few moments and everything comes back. It will start and run a few moments and stops again. One thing when that happens it sometimes backfires trying to restart.
  1. Intermittent Engine Stall, Shutdown
    By TejasRanger in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-30-2021, 04:05 PM
  2. Intermittent starting problem
    By Stalloin 146 in forum Stallion Trikes
    Last Post: 09-09-2011, 05:44 AM
  3. electrical problem, volt meter in 12v range
    By silverdevil in forum Stallion Trikes
    Last Post: 03-12-2010, 11:50 PM
  4. Electrical Problem - Blowing Fuse
    By patriot in forum Honda Trikes
    Last Post: 10-15-2009, 08:50 AM
  5. Electrical Woes
    By Ozarkryder in forum Honda Trikes
    Last Post: 06-15-2009, 08:54 AM
