Likes Likes:  2
Thanks Thanks:  1
Results 1 to 7 of 7
Thread: Gas cap removal difficulties
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Default Gas cap removal difficulties
    I have a 1999 GL1500 that is VERY difficult to remove gas cap, on every fill up. Suggestions?
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Is it hard to turn or is it not coming off once turned.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Quote Originally Posted by Marc H View Post
    Very hard to turn
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by Pastor Ron View Post
    Very hard to turn
    Use some grease on the thread / neck where they engage. Clean off any rust or burrs present. You can use a very fine grit wet or dry sandpaper.
    You could even try some wet or dry paper with a string for retrieval inserted between contact points and work cap back & forth a little, not a lot though as you want some resistance and you don't want a lot of grit in the fuel. Maybe, pump fuel out afterwards and put fresh clean in or strain it through a paint strainer.
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Thank you all
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I've had to fo similar stuff to a 1500 ... be careful not to get junk in the tank.
  1. New Gas Cap Issues?
    By dartref in forum Harley Trike Conversions
    Last Post: 05-30-2016, 03:04 PM
  2. gas cap
    By T.C. in forum Stallion Trikes
    Last Post: 06-10-2012, 05:53 PM
  3. darn, lost gas cap
    By geraldlanc in forum Honda Trikes
    Last Post: 01-14-2012, 10:41 AM
  4. Lockaable Gas Cap and Hood
    By Switchback in forum Stallion Trikes
    Last Post: 10-22-2010, 12:31 AM
  5. GPS Gas Cap Mount
    By Guiderider in forum Harley Trike Conversions
    Last Post: 06-10-2009, 04:15 PM
