Likes Likes:  12
Results 1 to 20 of 33
Thread: 2+2 narrow sweeper
    Oct 2020
    apache junction, Az.
    Default 2+2 narrow sweeper
    Hello, I have a 2020 tri glide, I am looking to switch my handle bars out to the 2+2's narrow. I have seen post that you didn't have to change cables or wires extensions, but not all pertaining to the 2020. I do believe the 2019 and 2020 are same. So question is on the 2020 does anyone know if you have to change these two items or just reroute? i did see one post on a 2020 and he said did not have to do wires but I must of missed the cables part. Any help would be appreciated.
    Thanks, Mike
    1000+ Posts
    Aug 2016
    Des Moines IA US
    I can't answer your question and I'm surprised you didn't see the post that is about 4 posts down, all about the bars you want. You might want to view this and ask your question there if you don't see what you want
    All for now Trampas
    150+ Posts
    Jul 2019
    marquette mi
    Quote Originally Posted by heymikie View Post
    Thanks, Mike
    changed mine in aug on a 2019 didnt change or add anything, plenty of wire under the fairing if you take the plugs off the bracket. My clutch hose was fine ,the brake hose was tight . i think you will like the 2x2s my back and shoulders thank me every ride. one thing change the riser bushings to polyurethane while youre there
    150+ Posts windsurfed's Avatar
    Jul 2020
    Spokane WA USA
    Default HD answer
    I just had the 2+2 Narrow sweepers put on my 2020 TG. If you want the cables to route on the outside of the bars like the original handlebars, no wire extensions needed. (This is what I did) However if you want them to route inside the 2+2 Bars, Extensions will be needed. At least that is what the HD Shop said to me when they called me in the middle of the install and Ask me which route I wanted to take.
    Stupid is a choice
    Dumb is not a choice
    Stupid can be fixed
    Dumb cannot be fixed.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I've got these on order with my dealer for my 2020 TG and hope to have them next week. Before ordering I spoke to Khrome Werks customer service / tech service and they told me no wire extensions required and clutch and brake line OK - just clip the wire ties and free them up. Here is just one of the videos I've watched about handlebar changes. Not for these bars but the procedure is the same and he does an excellent job showing and explaining the process.
    I installed a set of Wild One 579s on my 2018 TG and ran the wires internally. I did need extensions for that but plan to leave the wires external on the Khrome Werks. Internal looks better but I'm kind of over being that anal. Doing it the quicker and easier way works for me.
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    I just installed the 2+2 narrow sweepers. Had no problems with the wires but did have a problem with Clutch and Brake lines. They were slightly short, had to run on top of the bars at the bottom. Couldn't find anywhere to get more length. If you find something I didn't please pass it along to me, I would certainly appreciate it.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by nucseal View Post
    All I can refer to is what is in the video I posted. And when I did the Wild One 579s on my 2018 TG I didn't have any problem with the hydraulic lines after I cut the cable ties and pulled on the clutch line. It was tight but did not bind and I rode it almost 30k miles with no problem. My '18 and my '20 have the same clutch line - 37200129 but different brake lines (upper portion) '18 - 41800183 and '20 - 41800687 but hopefully that won't be a problem.
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Quote Originally Posted by ultrafxr View Post
    Let me know if you run into the same problem I did. A solution if you have any. I cut all available ties and still just barely had enough to mount the bars.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Got mine installed today. Plenty of slack for all the electrical wires and the clutch was fine after I cut all the ties (there were 3 if I recall correctly). Brake line was pretty tight. I tugged on it pretty good to get enough slack to mount the controls on the handlebars but it fit. . . . and unlike the clutch line it doesn't see any movement when turning the front wheel so I don't think it is any problem.
    Went for a short 15 mile shake down after the install and I really like that the bars are closer so I don't have to reach for them. I think I'm going to like these bars.
  11. #10
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Looks like you had the same problem I had with the clutch/brake lines. And HD dealership says you can install 12" without a problem! Laughable
  12. #11
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    Default 2+2 narrow sweepers
    Hi, new guy here. My question is: How is the ride/feel with these bars over stock and compared to the 2+2 wide sweepers?
  13. #12
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Dale, I cannot help you but I can offer you a big Texas .
  14. #13
    150+ Posts
    Jul 2019
    marquette mi
    Quote Originally Posted by Fasteddy View Post
    seems easier to steer and more relaxed between shoulders after a day of riding, over all a more natural position for my hands.
  15. #14
    250+ Posts
    Dec 2009
    Wickenburg, Az.
    Quote Originally Posted by seniorsgt View Post
    Which are you talkin about being easier to steer, the narrow or The Wider sweepers?
  16. #15
    150+ Posts
    Jul 2019
    marquette mi
    Quote Originally Posted by azbob09 View Post
    narrow. maybe im just more comfortable so it feels easier
  17. DKCustoms postbit
  18. #16
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Majority of trikers utilize the narrow 2+2. It was first thing I change after buying my 20 Tri Glide in Sep. No more neck, back or shoulder pain. Stock bars suck. I did a lot of research before I bought and installed these!
  19. #17
    Dec 2013
    Clarion PA USA
    Default Wide sweepers are a little straighter in the grip.
    The Wide sweepers are a little straighter and 34" wide gives more leverage OEM are 30" Narrow Sweepers have the same grip angle as OEM. My stiff right wrist loves the wide ones as well as my back and shoulders. I installed a 2" tank lift and these really gave me lots of clearance bars to Fuel tank.
Size:  162.1 KBName:  DSC00554.JPG
Size:  161.5 KBName:  DSC00550.JPG
Size:  162.8 KB Name:  DSC00552.JPG
Size:  161.5 KB Name:  DSC01026.JPG
    This is what the OEM look like this picture is 2014 spring, getting out of garage asap.
  20. #18
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    Quote Originally Posted by Fearless View Post
    The grip angle is why I went with the wides. They will be installed next week.
    2016 Tri Glide, More DK than HD. Just shut up and ride.
  21. #19
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I had Wild One Chubby bars on my two wheelers and on my 2018 TG - 575s on the two wheelers and 579s on the TG. Like the Wide Sweeper they are about 34" wide. I liked them OK but on tight parking lot turns the added width was a hindrance imo. And the added width gets your hands out more in the wind stream which during cold weather I don't like.
    Since I don't have any problem at all turning my TG I decided on the 2+2 Narrow Sweepers and they are just fine for me. Don't have to reach for the bars any longer and the width is just fine.
    Now the Wild Ones being 1.25" vs 1" diameter look better imo. But the KhromeWerks sweepers are about half the price so all in all I'm extremely pleased with my choice of KhromeWerks 2+2 Narrow Sweepers.
  22. #20
    70+ Posts JohnK's Avatar
    Jan 2020
    Hays, KS
    Like Fearless, I have the wide-sweepers and tank lift. I had them on my '11 TG and had them installed on the '20 (along with some other do-dads) before I brought it home. One of my better add-ons along with the RZ seat.
    Just an ole VietNam Vet 67/68
    '20 Spruce TriGlide - lots of do-dads
  1. HD pullback bars vs. Werks 2x2 Narrow sweeper bars
    By DonC in forum Harley Tri Glide
    Last Post: 03-01-2022, 10:48 PM
  2. Khrome werks 2+2 sweeper ?
    By rickm in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-08-2019, 06:10 PM
  3. Replies: 2
    Last Post: 10-22-2015, 08:46 AM
  4. Ape Hanger Bars vs The 2x2 Werk Sweeper bars
    Last Post: 10-01-2015, 10:11 AM
