Likes Likes:  14
Page 2 of 2 FirstFirst 1 2
Results 21 to 35 of 35
Thread: What handlebars are you using
  1. #21
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by Hdlprasek View Post
    what is the tallest you can use without changing wires and cables?
    possibly 12" depending upon style you have check fitment. What fits the TWO Wheel Ultra's most likely fits the trike. Choose carefully
  2. #22
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Dealer says 12" but I put on 2+2 sweep (10" high) and it barely made it.
  3. #23
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    HD Batwing Reach
  4. #24
    350+ Posts
    Aug 2020
    Monaca, Pa, USA
    Stock. They seem comfortable to me.
  5. #25
    Stock........Right where i want/need them.......
  7. #26
    150+ Posts
    Apr 2018
    Cordes Lakes, AZ
    I just had a set of the HD Batwing reach bars installed. I basically do not have rotator cuffs in either shoulder and the pain was getting so bad after a few miles that I was considering selling the Tri-Glide, but did some experimenting and found that if I leaned forward enough to keep my elbows slightly bent, it solved the problem, so I had the reach bars installed. BIG improvement.
    They do hold my hands at slightly different angles and that will take some getting used to, but they allow me to sit upright instead of leaned slightly forward, and still have my elbows bent. I'm 5'10" and as a side benefit, they push my head back into the sweet spot for the speakers, I can distinctly hear all four of them now. Sitting back farther from the windshield, I did find that my face gets more raindrops than before.
    YMMV
    Lon
  8. #27
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by Teufelhunde View Post
    I just had a set of the HD Batwing reach bars installed. I basically do not have rotator cuffs in either shoulder and the pain was getting so bad after a few miles that I was considering selling the Tri-Glide, but did some experimenting and found that if I leaned forward enough to keep my elbows slightly bent, it solved the problem, so I had the reach bars installed. BIG improvement. They do hold my hands at slightly different angles and that will take some getting used to, but they allow me to sit upright instead of leaned slightly forward, and still have my elbows bent. I'm 5'10" and as a side benefit, they push my head back into the sweet spot for the speakers, I can distinctly hear all four of them now. Sitting back farther from the windshield, I did find that my face gets more raindrops than before.
    YMMV
    Lon
    when you get time post a picture of the new bars. I would like to see them. Congratulations I know the feeling the 2+2 wide sweepers worked for me ride safe Fred
  9. #28
    50+ Posts nokkon wud's Avatar
    Feb 2021
    Clearwater, Fl
    I bought the 2+2 wide sweepers but haven't installed them yet.
    Getting mixed thoughts on if I have to replace cable, lines and wires.
    Seems like I should.
    Any idea?
    The first 65 years of childhood is the hardest.
  10. #29
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    Quote Originally Posted by nokkon wud View Post
    Any idea?
    I got the wire extensions ($18) for mine but everything else worked just fine. It's one of the best comfort mods I've made. It's also nice having the clean look with just the brake line and clutch line outside the bars.
    2016 Tri Glide, More DK than HD. Just shut up and ride.
  11. #30
    Stock, moved forward for more comfort
  12. #31
    Dec 2013
    Clarion PA USA
    Any idea?
    I have no idea what year Trike you are running my old 09' I needed to swap the clutch cable (+6) not hard just time consuming, for a first timer working on one. Everything else worked out fine Wires and brake hoses even the dreaded green connector for the throttle sensor in the right bar. The difference was night and day for me... I also was considering getting rid of the trike because of the misery I was going through riding. It is expensive to have a Harley shop change them Independents are usually more reasonable regardless of how or who does the swap it's in my thinking it's worth it. The alternative is never enjoying the ride for the rest of time you wish to ride. Good luck on your choice think about it and I believe I know what you will do. Ride safe Fred.
  13. #32
    Feb 2021
    Clearwater, Fl
    Quote Originally Posted by Fearless View Post
    It's a 2013 TG.
    Personally I don't mind a longer clutch cable because it seems to give a smooth and easier pull.
    I'm new to anything that has a fairing. Never had anything but a windshield and that comes off for around town. All this tourpak, gauges and radio crap is all new to me.
    Coming from a 03 RKC I bought on 05. Shovels and a Pan before that.
    I notice the dingle ball bungie cord on your brake handle. Is that your Ebrake?
  14. #33
    Dec 2013
    Clarion PA USA
    It's a 2013 TG.
    The small elastic cord is an extra E brake I keep the OEM adjusted but you never know get a shop manual it makes it easy. The manuals are written at the forth grade level LOL
  15. #34
    150+ Posts
    Apr 2018
    Cordes Lakes, AZ
    Kinda lousy picture, been cloudy and sprinkling here, so took the photo in the bike barn, but you should be able to get the idea.....
  16. #35
    Dec 2013
    Clarion PA USA
    Good job look like they will be great
  17. DKCustoms postbit
  1. What Shocks Are You Using For Champions?
    By Ozarker in forum Champion Trike
    Last Post: 10-23-2018, 09:59 AM
  2. What are you using for oil in your trike and why that????
    By Trampas in forum Harley Tri Glide
    Last Post: 04-08-2017, 09:31 AM
  3. What Windows-based video editing software are YOU using?
    By 0pini0nated in forum General Discussion
    Last Post: 11-06-2013, 07:39 AM
  4. Which GPS are you using?
    By chickie in forum Accessories
    Last Post: 08-15-2010, 05:01 PM
  5. vibration in handlebars on champion trike
    By john in forum Honda Trikes
    Last Post: 05-16-2009, 11:08 PM
