LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  5
Thanks Thanks:  2
Results 1 to 12 of 12
Thread: Engine Guards for Freewheelers
    Default Engine Guards for Freewheelers
    Required when installing Engine Guards, P/N 49184-09A, 49050-09A and 46549-03 to 10-'11 FLHXXX and '15-later FLRT models.
    Here is the info for the parts to fit an engine guard to your Freewheelers
    This is from House of Harley's web page
    300+ Posts RedOregon's Avatar
    Aug 2015
    south of San Antonio
    Just wanted to put this out there: If you're installing an engine guard on a Freewheeler by yourself, it can be pretty hairy trying to line it up and torque it down all at the same time. Advice from the school of hard knocks, busted knuckles, and a lot of cussing: use a bungie cord or tiedown strap up over the top of the machine to hang the guard in about the right place. That'll allow you to line it up and torque it down *without* having to hold it up at the same time... it'll make a HUGE difference, trust me.
    2024 Tri Glide! Only modifications so far - transferred Rider backrest from old 2015 Freewheeler, just added highway pegs!
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    Too add something to a almost year old thread, I installed engine guard 49184-09A to my 2019 FLRT and also purchased the steering damper kit and found I did not need the kit.
    70+ Posts
    Jun 2019
    Unionville, OH, USA
    Quote Originally Posted by GTK View Post
    I just bought the crash bar too and am waiting on that adapter part. Looking at the bike I cant see the need for it. What exactly did it do for it?
    Oct 2020
    Las Vegas, NV. USA
    I put the Lindby Magnum bar and pegs on my 2018 M8 Freewheeler I like it, install was no trouble.
    Jul 2016
    cloverdale, ca
    Default Instructions for Installation of Engine Guard
    Good Morning,
    I have a 2019Freewheeler and I have purchased the engine guard and the damper part. I am trying to find some good instructions which I thought I had seen on the forum. I think I see where the attachment is to the frame but there are covers that seem to be on there pretty tight. So wondering if that is not the correct attachment point. Also I see a piece on the bike already that looks very much like the extra attachment piece I bought
    I was hoping to be able to do this myself- any help would be greatly appreciated!
    Quote Originally Posted by coral mustang View Post
    Good Morning,
    The engine guard will attach to the lower part of your frame, There should be plastic plugs in the frame holes. You will need a pick tool to pop them out. You may want to clean the threaded holes in the frame out before the install. This will maker the bolts go in easier. I hope this helps you and Welcome to Trike Talk
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    I had to buy bolts from HD because I am not capable of telling what size I need just by looking. Part Number 4924.
    The attachment piece is similar, but a little different. You will be able to tell the difference when you get it off. Be careful to put the eye ball looking washer on correctly.
    Quote Originally Posted by LadyonaMission View Post
    It looks like HD is cutting corners to save dollars not supplying bolts they know will be needed to do the install. What a shame
    60+ Posts
    Feb 2023
    Southport NC USA
    Default Cleaning threads
    Jack, as I am in the process of installing my Lindby Magbar, asking for your advice. How does one clean the threads in the frame? Appreciate all information. Thanks, Jim
    Quote Originally Posted by SouthportFLRT View Post
    Run a bottom tap thru the holes, spray clean the threads to remove any debris with brake cleaner
    60+ Posts
    Feb 2023
    Southport NC USA
    Thank you as always for your sage advise. Fortunately I was able to use Tap Magic oil and a stiff brush that cleaned the threads so that the bolts (H-D 4924) fit fully into the threaded socket. Indeed the plastic caps were a bitch to remove....no doubt the source of the offending material. Stay safe. Ride safe.
  1. Engine guards
    By Hotwheelz in forum Harley Freewheeler / Road Glide 3
    Last Post: 07-11-2017, 04:02 PM
  2. Boot Guards/Heel Guards Rider Floorboard
    By Amputee55 in forum Harley Tri Glide
    Last Post: 08-03-2016, 11:44 AM
  3. Bummin!! Freewheelers in the shop
    By Red59 in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-18-2015, 06:45 PM
  4. The First Annual Internet Bike Contest - Tri-Glides' & Freewheelers' Category!
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 02-10-2015, 11:30 PM
  5. Aftermarket Accessories Specifically for Freewheelers - a Sticky
    By Springman2007 in forum Harley Freewheeler / Road Glide 3
    Last Post: 12-11-2014, 05:12 AM
