Results 1 to 12 of 12
Thread: DK Custom Introduces a H4 LED Headlight w/ Limited Time Special Pricing
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Default DK Custom Introduces a H4 LED Headlight w/ Limited Time Special Pricing
    LED DROP-IN HEADLIGHT BULB
    Replace The Stock Yellow Light
    Premium White LED Light Bulb Makes
    A HUGE Difference!
    Click HERE For Details & Pictures
    Save 10% March 19-27, 2015 on the LED Bulb
    Use Coupon Code: Save10
    In Checkout
    www.DKCustom.com
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Default Re: DK Custom Introduces a H4 LED Headlight w/ Limited Time Special Pricing
    That sure is a bright headlight!
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Kelsey
    www.DKCustom.com
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Kelsey
    www.DKCustom.com
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Kelsey
    www.DKCustom.com
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Savings are still available
    Kelsey
    www.DKCustom.com
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    LAST DAY TO SAVE!!!
    Kelsey
    www.DKCustom.com
    200+ Posts Lizard's Avatar
    Aug 2013
    Nashville, TN USA
    Might want to check on this. According to info from a couple years ago, drop in replacement bulbs (LED and HID) are illegal as the reflectors are designed for a different type of bulb with a different light pattern. Dropping the improper type bulb in a stock reflector will result in light reflection in the wrong direction and possible blinding of oncoming traffic even with proper aiming, which may be impossible with the drop in bulbs. In states that require yearly inspections, these drop in bulbs will most likely fail.
    2013 Triglide, SE254E Cam, Arlen Ness Air Cleaner, Fullsac X-Pipe, CVO Mufflers with Fullsac 1.75" cores, 480# clutch spring with ClutchWiz, TTS Mastertune with custom tune.
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Lizard View Post
    These work very well from the riders perspective, and we've not had any cages flashing their brights like you would normally see if they were being blinded.
    However, as stated in the description-
    These are Not DOT Approved. Legal for Off-Road Use Only.
    Here is a pic against a wall, it has a pretty well defined cut-off, so the light is not going willy-nilly everywhere.
    www.DKCustom.com
    4750+ Posts
    Mar 2015
    Texas
    Do you have a equal replacement for the little spot lights Harley has? Would look tacky to change one and still have yellow spots. JMO
    American Legion Rider
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    I agree with you, and we are working on it.
    I personally don't need it for my TG or Softail, because I have the amber spots. But for most, it will be nice when we have the matching LED spots bulbs. Should be soon.
    www.DKCustom.com
    4750+ Posts
    Mar 2015
    Texas
  1. DK Custom Limited Time Special Savings!
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 11-21-2014, 11:51 PM
  2. ***DK Custom Products - Special 10% Savings on Select Items - Limited Time***
    By DK Custom Products in forum DK Custom Products
    Last Post: 08-15-2014, 03:55 PM
  3. ***DK Custom Products - FREEDOM SPECIAL - 10% Coupon Code - Limited Time****
    Last Post: 07-13-2014, 11:19 AM
  4. Replies: 1
    Last Post: 06-25-2014, 10:55 AM
