Likes Likes:  5
Thanks Thanks:  5
Results 1 to 17 of 17
Thread: TriGlide antenna will not come off
    80+ Posts Udawg's Avatar
    Jun 2020
    Kathleen, GA, USA
    Default TriGlide antenna will not come off
    Hi guys, Sorry to lean on you again but I got my TriGlide home and was going to do a simple swap to a shorter antenna. The one I used on my last TriGlide. I finally got the old one off by using a towel and vise grips for about 45 minutes. It was moving about a 16th per turn. Anyway I finally got it off and thought somebody must have use threadlocker on it. Then I proceeded to put the new one on and it's the same problem. Will only go on for about one turn then just locks up again. I looked at the threads on the stud and they don't appear to be crossthreaded but I can not get this thing on for anything. I wonder if anyone knows the exact thread size so I can go get a nut with the right thread and just use a ratchet and socket to clean it up all the way down. I tried with a dye but not sure of the thread size and also the dye hits the lip of the tourpak after one or two turns. Any help or ideas or prior experience with this situation would be greatly appreciated,
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    Two things : Are you trying to do this in a cold garage? You could also try soaking the threads in WD 40 or light machine oil. The antenna should go off and on by hand.
    Jun 2020
    Kathleen, GA, USA
    Quote Originally Posted by OLBLU View Post
    Thanks but it's about 70 degrees and I did put WD40 in the antenna threads and still no go. I have done at least half a dozen and never had this kind of problem.
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Quote Originally Posted by Udawg View Post
    If you're having that much trouble I would clean the antenna threads with a tap and clean the threads in the tour pack with a die.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
    I know you said it doesn’t look cross threaded, but the way you describe it It has indications of somebody cross threading it…
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    Thread size on my 2019 is 6mm X 1 thread pitch (6mm 1.0)
    Probably can get a nut that size at your local hardware store.
    I broke the stud off and had to drill out the rest of it on the tour pak rear assy.
    NOTE: You have to be very careful and have the drill centered exactly. I started with a very small drill and worked my way up to the correct size tap drill bit, then tapped it with lots of lube. Was a pain.
    Part number for the stud is
    76000186
    You do not want to replace the rear assy light as it costs $439.00.
    I could not remove the stud as I think it had loctite on it.
    You may also want to tap the antenna.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    When reassembling , use pentrax or some dielectric grease on the threads .
    Striped threads 101… Tighten till it loosens then back off a quarter turn..😉..
    Jun 2020
    Kathleen, GA, USA
    I think you're right. Has to be.
  11. #10
    Jun 2020
    Kathleen, GA, USA
    Quote Originally Posted by Koolbreeze View Post
    76000186
    Thanks KoolBreeze, that will definitely help knowing the right size. I'll try to use a dye and clean it up tomorrow.
  12. #11
    Jun 2020
    Kathleen, GA, USA
    Thanks, I hadn't even thought about a dielectric when reassembling. That'll probably help now and in the future.
  13. #12
    Jun 2020
    Kathleen, GA, USA
    Quote Originally Posted by Rogue1 View Post
    The antenna is new but I will take a dye to the stud and try to clean it up.
  14. #13
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    I wonder if anyone knows the exact thread size so I can go get a nut with the right thread and just use a ratchet and socket to clean it up all the way down. I tried with a dye but not sure of the thread size and also the dye hits the lip of the tourpak after one or two turns. Any help or ideas or prior experience with this situation would be greatly appreciated,[/QUOTE] Why do people put themselves through this self flagellation? Thread Detective, comes in both SAE and Metric ( get both). Check Amazon and Fleabay. Lifes too short to say bad words over a fastener.
  15. #14
    80+ Posts Jd1a's Avatar
    Oct 2018
    Waddell, AZ USA
    My antenna threads will get rusty after washing and rain. Have to clean the threads and assemble. Metric threads as stated, I carry a metric bold with t he threads filed like a tap to clean the antenna threads.
  16. #15
    100+ Posts
    Jun 2022
    South Carolina
    Use a thread chaser to clean threads, taps and dies are for cutting new threads...
    Remove and replace the antenna stud, about 8 bucks.
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
  17. DKCustoms postbit
  18. #16
    Dec 2012
    Santee
    Those antenna studs are a 1 inch 1/4-28 allen head set screw. I put stainless one in my bike and now I can't get the antennas off either.
    Ray
    2017 Harley Triglide
    Tijuana Border
  19. #17
    Jun 2020
    Kathleen, GA, USA
    76000186
    Thanks for the info KoolBreeze. I got the part from the Harley dealer and it was like a 2 minute swap out and a $7 part. All that worry and sweat because I had never done one.
    Thanks for all the help from everyone that replied.
  1. 2020 Triglide antenna
    By BKtrike in forum Harley Tri Glide
    Last Post: 03-27-2021, 11:24 AM
  2. What type of antenna do you use for FM and CB
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-12-2013, 08:27 AM
  3. antenna flag (US )
    By skibridg in forum Honda Trikes
    Last Post: 07-11-2011, 11:51 AM
  4. Electric antenna
    By molinoman in forum Stallion Trikes
    Last Post: 09-13-2010, 04:19 PM
  5. Antenna wire???
    By Friar_Funk in forum Stallion Trikes
    Last Post: 08-16-2010, 10:52 PM
