Likes Likes:  7
Thanks Thanks:  1
Results 1 to 8 of 8
Thread: Harley Throttle By Wire Fretting Problem
    Default Harley Throttle By Wire Fretting Problem
    TBW Issues Explained by HD Service Bulletin TT418A a MUST READ
    This is some must read info for everyone that has had issues with the TBW. This is a service bulletin issued by HD on 1/7/2011 it is bulletin # TT418A: DTC's P2135 & P2101 Theory & Diagnostics. I am going to condense this some but I also believe from my past experiences with my TBW that this also would include the P1510 code.
    TT418A service bulletin applies to 2008-Later Touring, Police & Trike Models
    Symptoms: Driveability or Performance Concerns; Abnormal or Erratic Mechanical Operation; Intermittent or Erratic Electrical Operation.
    Note: Throttle Position Sensor (TPS) circuit DTC's P0120, P0220, P0122, P0123, P0222 and P223 should take diagnostic priority over a P2135 code. If any of these TPS codes exist concurrently with the P2135, they should be investigated first using the diagnostic manual.
    The TCA has two potentiometers (designated as TPS1 & TPS2) and a electric DC motor for controlling the actuation of the throttle. The two TPS sensors work opposite of each other. As the throttle plate opens , TPS1 voltage ranges from 0.0-5.0 Volts, while TPS2 voltage ranges from 5.0-0.0 volts. The sum of the two TPS voltages should always measure approximately 5.0 volts. These wire are: TPS1, pin # 37 (BN/V wire) of the ECM, and TPS2 pin #36 (BN/R wire) of the ECM
    The TPS1 and TPS2 sensors should never add to more than 5.13 Volts Direct Current (VDC) or less than 4.87 VDC . A sum of voltages out of this range should register a current P2135 code.
    Troubleshooting:
    It is believed that FRETTING CORROSION is a major contributor of this code. A poor connection at the Throttle Control Actuator (TCA) can affect the sensor voltages reported to the ECM and this will set this DTC. As you can see from the General Information section, the sensor voltage only need to be altered by 0.13 VDC to possibly set the code.
    The most common vehicles to have these symptoms are those with more than 8,000 miles (12875 Kilometers) or 103 cubic inch and larger engines. Vibration is believed to contribute to the FRETTING CONDITION.
    Repair Procedure:
    1. While monitoring the TPS1 and TPS2 voltages on Digital Technician 2 (DT 2), wiggle the TCA [211] and the ECM [78] connectors.
    2. If the voltage changes while wiggling the ECM connector , replace the affected ECM terminals (part # 72605-08). These wires are: TPS1, pin #37 brown/violet wire of the ECM, and TPS2, pin #36 brown/red wire of the ECM.
    3. If no voltage change is noted while moving the ECM connector , the connection issue could be in the TCA. Replace all socket terminals with NEW terminals (part # 72663-11, used in current production) at the TCA connector[211B].
    4. BEFORE CONNECTING the TCA CONNECTOR, clean the male TCA pin terminals with a swab and alcohol, and ASSEMBLE WITH DIELECTRIC GREASE.
    DTC P2101
    General Information: The TCA contains two potentiometers (designated as TPS1 & TPS2) and a electric DC motor for controlling a actuation of the throttle. TPS1 & TPS2 are mounted in the TCA. They are connected to the keyed shaft of the throttle plate and used to communicate the throttle plate position.
    Each TPS supplies input to the ECM in response to the position of the throttle plate. The ECM activates the motor in the TCA to move the throttle plate, based on signals from the Twist Grip Sensor (TGS). When the ECM send voltage modulations to pins 2 & 3 0f the TCA to move the throttle motor, it checks fo subsequent TPS1 and TPS2 voltage changes. If it does not sense TPS changes it will set this code.
    Troubleshooting: First verify that the throttle plate moves freely when engine is not running. If it does not the TCA needs to be replaced.
    Poor ECM connections seem to be the most likely cause. Be aware that this issue may be aggravated by the seat pan making contact with the ECM connector. In most cases, this is caused by the installation of an aftermarket seat.
    A poor connection at ECM pins #29 & 30 could cause an interruption in voltage to the throttle motor and set this code. Similarly the ECM uses voltage from pin #52 yellow/green wire to supply power used at pins #29 & 30 and could cause the same symptoms.
    Repair Procedure:
    Identifying the connection issues at this location may be difficult.
    1. Replace all socket terminals with NEW terminals (part #72663-11 used in current production) at the TCA connector [211B].
    2. BEFORE CONNECTING the TCA CONNECTOR, clean the male TCA pin terminals with a swab and alcohol, and ASSEMBLE WITH DIELECTRIC GREASE
    Interesting Read ... especially the part about it most likely being due to aftermarket seats .. hmmmm ...
    2250+ Posts
    Ocala, Florida
    An interesting read, all right. Especially the part about it only taking a few thousand miles and on bikes with the 103 CI engine. Also, how could this ever be less expensive to build than a tradional cable operated carb or even injection?
    PC
    Beware of liberals posing as Americans.
    Meme Master
    Jan 2014
    Farmington, NH USA
    I cannot understand why the MoCo would make these vital controls so overly complex.
    What happens in ten years when these obscure parts are no longer available? Junk a
    $30K machine over a part that once sold for 30 bucks?
    WTF???
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Back in 2015, my 12 had that issue. They replaced it at n/c . But it did do some wierd things at times, such as throttle increase with out touching it. That will get your attention !
    50+ Posts Red Ryder's Avatar
    Feb 2019
    West Branch
    Thank You for the informative notice.
    I had to replace it twice on my 08 Harley Ultra.
    Neither one due to corrosion, they just quit working, failed.
    2nd time drove all 20 miles at 15 mpr in rain.
    Think dumb & dumber passed me.
    "Sometimes, it is Fun to let them slowly pass by, then Smile, as they wipe the Drewl off their face" :biggrin:
    100+ Posts grandpawj's Avatar
    Jul 2015
    Lancing, TN USA
    Jack, Thanks for the post. Yesterday my 08 Ultra had some freaky throttle responses. I looked at the throttle control on the handlebar having no idea it was all electrically controlled by a dc servo motor. My problem was that the rpm's didn't want to return to idle after releasing the throttle.
    Dead animals deserve balloons... MikeyTX's Avatar
    May 2016
    Big Bend Country, TX
    Back in 2015, my 12 had that issue. They replaced it at n/c . But it did do some wierd things at times, such as throttle increase without touching it. That will get your attention !
    Speaking of getting one's attention. Name:  Hula Hoop.gif
    2021 Mustang GT Premium A10 Handling Pkg
    Red White and BBQ Texas, it's whole whole nother country .........
    [SIGPIC][/SIGPIC]​
  1. Throttle by Wire High Idle Reset For Harleys
    By Jack Klarich in forum Harley Tri Glide
    Last Post: 03-09-2023, 06:35 PM
  2. Harley Throttle By Wire Tech Info
    By Jack Klarich in forum General Harley Chat
    Last Post: 11-03-2020, 01:00 PM
  3. Throttle by wire
    By Grumpy7760 in forum Harley Tri Glide
    Last Post: 07-18-2017, 10:54 AM
  4. Throttle cable problem
    By Doug D. in forum VW Powered Trikes
    Last Post: 04-16-2014, 06:49 PM
  5. Throttle Problem
    By GYPSYGAL in forum Honda Trikes
    Last Post: 05-30-2012, 02:32 PM
