Results 1 to 3 of 3
Thread: Back brakes
    40+ Posts
    Feb 2010
    SOMERSET UK
    Default Back brakes
    Has anyone fitted a servo to there trike to sharpen up the brakes. I have a 96 BossHoss the brakes are rubbish. I have fitted larger rear calipers which has helped but want better. There’s no room for a longer pedal and I’m running a 3/4 master cylinder. Thought I’d try a servo but wanted to hear other people’s experience.
    thanks
    30+ Posts
    Aug 2018
    Mahomet, IL
    Quote Originally Posted by knockdolian View Post
    thanks
    Hi Paul,
    I replied on the other thread also. Yes, some have added a power booster (servo). Not sure what they used. You can probably find that info on the V8 Bike Riders forums.
    Check this thread:
    https://www.v8bikeriders.com/forums/...ad.php?t=22530
    40+ Posts
    Feb 2010
    SOMERSET UK
    [QUOTE=Kruzn;622111]Hi Paul,
    Thanks for the info. I should have said I have discs on the back. I took the shitty tiny brembo calipers off. Made up some mounts and fitted a pair of Renault 5 turbo front calipers. I’ve also made mounts and replaced the willwood twin pots for Brembo 4 pots as well as fully floating discs. I do have a remote servo somewhere. I’ll try it and let you know.
    thanks again
  1. Rear disc brakes, VERY HARD pedal, weak brakes????
    By TrikerDoone in forum VW Powered Trikes
    Last Post: 05-29-2016, 12:14 PM
  2. California Law (All 3 need brakes or only the back)?
    By MdKnightMan in forum VW Powered Trikes
    Last Post: 01-28-2016, 10:20 PM
  3. Update on back brakes FuzzyWasHe and Gorilla.Msocko3
    By Ironhorsepilot in forum Harley Tri Glide
    Last Post: 03-21-2015, 09:32 PM
  4. How do I link the front and back brakes
    By Duck in forum Honda Trikes
    Last Post: 09-25-2014, 10:50 AM
  5. VW trike back brakes
    By greg will in forum VW Powered Trikes
    Last Post: 12-24-2011, 10:41 PM
