SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
SSpoon14hardwickbvNew Member Introduct...Hello from VA
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Likes Likes:  23
Thanks Thanks:  8
Results 1 to 20 of 28
Thread: R & R Freewheeler Gas Tank
    Default R & R Freewheeler Gas Tank
    This is a must to replace spark plug wires, not so much if you are just doing spark plugs
    1 I pulled the main fuse
    2 remove seat
    3 disconnect fuel line ( push up on the collar pull down on the line)
    4 On the left front bottom of the tank lightly pull on wire that runs to fuel gauge and un plug it ( I believe the manual says to draw the fuel gauge out of the tunnel to unplug it , IMO too much work and NOT necessary )
    5 remove rear bolts on tank
    6 unplug wire loom running near top of battery up and under gas tank ( there is NO need to remove the console) unless you want to do extra work that is not needed
    7 disconnect the fuel vent hose
    8 remove the front 2 bolts holding tank to frame and lift the tank off
    Reverse the steps to reinstall, take care when setting the tank down on the frame
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Thanks Jack. I'm curious , when you unplug the fuel line, is it under any pressure at all?
    Also, how did the old plugs you pulled look?. You must be close to 20,000 miles.
    If you let your Trike set over night NO gas will dribble out No pressure But I still pulled the main fuse
    The original plugs looked OK, tho the center electrode was pretty rounded ( that equals higher voltage required to fire the plug Higher resistance) in the old days we would flat file the electrode and re gap em
    The firing line was dark gray turning to a lighter brown= getting plenty of fuel unlike the Twin Cams that run lean,( white)on the electrode. AND I hate it when folks say it is impossible to read a spark plug now that we have un leaded gas That is pure non sense If you know what to look for and HOW to do it it comes pretty easy. I hope that helps
    Oct 2017
    St. Louis, MO USA
    Thanks Jack. I was thinking that about letting it sit overnight to let any pressure bleed off.
    I'm a little under 8,000 miles & plan to pull the tank at the 10,000 service, check the plugs & those plug wires you mentioned. I heard someone say before the M8 had rubbing on the plug wires under the tank.
    It's something worth checking.
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    A week or so ago when I removed my tank on the Tri Glide, I placed a plastic grocery bag underneath the fuel disconnect line and laid some paper towel on top of the bag. Was concerned in preventing fuel from getting on the cylinder and having to work around that gas smell....well to my surprise very little came out. Most important too is having as small amount fuel in the tank as possible, after all we have to lift that rascal.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    Your post should save me some work in the future.I always removed the consol when removing tank,now if I can locate the wire connectors,I shouldn't have too.
    Quote Originally Posted by GTK View Post
    Once you remove the seat you will see the main wire you have to disconnect
    The fuel gauge wire is tucked up under the tank left from bottom side of the tank
    Grab a hold of it and give a slight pull, you will see the connection
    Meme Master
    Jan 2014
    Farmington, NH USA
    So what was causing the plug wire wear?
    Did the factory somehow cut corners in the installation?
    Inquiring minds want to know!
    Tight fit under gas tank, wires can and do rub on tank
    The RS rear wire had arced on rear rocker box also, IMO could have run the wires a bit better @ the factory
    Meme Master
    Jan 2014
    Farmington, NH USA
    Not that I'm gonna run out & buy a Free anytime soon but, is there a longer plug wire available or coil relocation option to eliminate the "rub" on tank?
    I am sure there is
    The main problem is the Milwaukee8 engine has 4 plugs
    The RS plugs are set down deep in the heads
    IMO HD should have run the wires thru the electrical caddy under the tank
    #30 in the diagram
    Meme Master
    Jan 2014
    Farmington, NH USA
    Makes more sense now. Thanks Jack!
    With 4 plugs they must be running at least 2 coils?
    Thinking out loud: Seems that on the automotive side individual coil packs are adapted to each cylinder/sparkplug and they're really small/compact nowadays, which would lend themselves to be mounted in close proximity to the plugs...
    # 7 is the coil Pete
    Oct 2017
    St. Louis, MO USA
    1 other item I saw in a video & forgot to mention, but is worth noting:
    After hooking everything back up, it's a good idea to turn the key on and let the fuel pump pressurize the fuel line you disconnected, while checking with a light for leaks.
    Especially for the anul among us, as I am a member of that club.
    Thanks for posting Jack.
    Thumbs up
    Very good point
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    OK probably a dumb question but why do you / we need to change plugs at only 20k? With modern electronic ignitions at least in automobiles they can go much, much longer. I changed the plugs on my Buick SUV a while back when it hit 100k and the plugs looked pretty good to me. And after the change I really could not detect much if any change in the way it ran.
    Seems like a bit of overkill to me but I'll defer to those who have more technical knowledge than I have. I just hit 20k on my TG so should I be doing this also?
    13000+ Posts FuzzyWuzHe's Avatar
    Quote Originally Posted by ultrafxr View Post
    i pull them and check them and re gap them at least once a year ... at 20k ... I'll just replace them.
    Plugs are really cheap and easy to change ... why not change them as recommended by the schedules?
    2 years or 30K miles is what the owners manual calls for
    These are plain Jane plugs, not Platinum or Iridium so they will wear like plugs in the past on Harleys
  19. #19
    Oct 2017
    St. Louis, MO USA
    1 other item worth mentioning, prior to trying to undo the fuel line quick disconnect, I put a rag behind it and sprayed a shot of silicone on it & moved it a little & it makes things much easier.
  20. #20
    What oil do you use to do that?????
    Sorry Jack .... couldn't resist.
  1. Front plug wire insulation & gas tank
    By Beorn of Ga in forum Harley Trike Conversions
    Last Post: 07-08-2014, 06:01 PM
  2. Auxiliary Gas Tank
    By philmcc in forum General Discussion
    Last Post: 07-08-2011, 04:03 PM
  3. Gas tank knob mod
    By John Luciano in forum Honda Trikes
    Last Post: 04-16-2011, 10:54 AM
  4. Second gas tank
    By wics51 in forum General Discussion
    Last Post: 04-13-2011, 08:29 PM
  5. Amount of usable gas in tank
    By darrell moore in forum General Discussion
    Last Post: 01-28-2010, 12:31 AM
