Likes Likes:  1
Results 1 to 13 of 13
Thread: Flat bed trailer to tow Trike?
    20+ Posts
    May 2011
    Council Bluffs, IA USA
    Default Flat bed trailer to tow Trike?
    Does any one know of a company that makes a flat bed short trailer, wide enough for a trike? Or should I just check for what's available at U-Haul?
    Owen.
    750+ Posts
    May 2011
    peru,in,usa
    Default Re: Flat bed trailer to tow Trike?
    you could make a car dolly into one. here's anothers guys project.
    another thing is in most states you don't have to have plates for it.
    300+ Posts brianl's Avatar
    May 2013
    leominster, ma. USA
    Quote Originally Posted by NEMO View Post
    Owen.
    From the specs I've read, trikes are less than 5' wide and other than the Roadsmith HT1500, slightly less than 10' long. I have a Big Tex landscape that is 6'x10' I.D. you may be able to fit it onto a 5'x10', but I would try one before buying.
    750+ Posts
    May 2011
    peru,in,usa
    i still like the converted car dolly. MAN he did a great job.
    100+ Posts Smitty Werben Manjensen's Avatar
    Aug 2012
    Lost in Kansas
    If you want to pay an arm and leg, Aluma makes one.
    Motorcycle/Bike Trailers - Aluminum
    PS: Not a flatbed though
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Even if a trike fits on a trailer doesn't mean it will pull good. You need some extra room to get the hitch weight right or add weight to the trailer somehow. It will pull like a wet noodle if you don't.
    May 2011
    San Angelo
    Quote Originally Posted by Rsw View Post
    Very good point. General rule of thumb is 10 to 12.5 percent of total trailer and load weight should be felt on the tow vehicle hitch.
    2015 GL1800/Roadsmith HTS1800
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    I have a Droptail trailer that was built for two bikes. I removed one of the wheel chocks and moved the other one to the center mounting position. I have had it for three trips from Florida > Wisconsin > Florida. It pulls great and I can then fold it up and stow it vertical in my garage. The only problem I have had is the fenders work the bolts loose and I have to tighten them even though they are the aircraft type locking nuts. Also the vibration on the fenders has now broken the brace on one, welding required. My old Kendon for my Ultra bike did the same thing. I even balanced the tires thinking that would stop the vibration, wrong.
    http://www.droptailtrailers.com/Crui...ilers-s/12.htm
    My Droptail I found on Craigs List used.
    Kendon also makes a two bike trailer that can be converted for a trike. It is a little shorter and uses a single wheel ramp, therefore two more ramps would be required. The droptail has the full width loading ramp that drops via hydraulics.
    http://www.kendontrailers.com/
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
    50+ Posts
    Dec 2012
    Cedar Park, Texas, USA
    I bought my Triglide from an owner in GA, and used one of these from U-Haul: U-Haul: Equipment specs 5x9 with drop ramp. I towed it back to Houston with no problems, but it was a pretty tight fit.
    100+ Posts
    Nov 2011
    kernersville NC. USA
    I have an E-Z Hauler two bike flat bad trailer that would easily convert to a trike hauler. For Sale $1200.00.
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    I have this. Never towed it at high way speed with trike on board. Never thought about towing my trike.....
    Shop Carry-On Trailer 5-ft x 10-ft Treated Lumber Utility Trailer with Ramp Gate at Lowes.com
    Yes towed it home empty with the trike 20 miles....
    With military discount $900
    I use my enclosed snowmobile trailer. 7' wide and 20' long. V nosed fiberglass with ramp on the back. I drive it in, tie down and hit the road.
    950+ Posts
    Jun 2013
    DFW, Texas
    Quote Originally Posted by brianl View Post
    I have a Goldwing trike and it fit onto a 5 x 10 nicely. Recommend getting a tilt bed and add a winch in case the trike is DOA.
  1. Ford Flat Head V8 Trike
    By FLTR2008TRIKE in forum Home Built Trikes
    Last Post: 08-19-2013, 10:24 AM
  2. Change 5-round plug-in to 4-flat plug in for trailer
    By BinIdaho in forum Harley Trike Conversions
    Last Post: 02-26-2013, 11:42 PM
  3. Run flat rear tires on a trike??
    By Dante221 in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-30-2012, 05:43 PM
  4. flat tire
    By oldmanonavtx in forum Outrigger Style Trikes
    Last Post: 06-29-2011, 10:43 PM
  5. Fixing a flat
    By Saltywheels in forum Tires, Wheels, Brakes, Front End
    Last Post: 03-20-2011, 10:49 AM
