Likes Likes:  4
Results 1 to 12 of 12
Thread: Full flow oil filters
    30+ Posts
    Sep 2014
    yateley hants uk
    Default Full flow oil filters
    What are the thought on these full flow oil filter, it bolts on the end of the oil pump and takes a standard screw on cartridge.
    Is there any loss of pressure through resistance of the cartridge?
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    I have used them on 2 engines and seen no problems.
    But I do have a 36mm pump though (the one in the pic is a 32 I believe)
    Thank you
    Bob
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    I like mine but keep in mind they make one for a 3 bolt cam and one for a 4 bolt cam. Also bigger isn't' always better.
    100+ Posts roadhawk's Avatar
    Jan 2016
    Bakersfield, Ca. USA
    Works great on mine. Between that , and the huge oil cooler it also adds almost a quart capacity. Good when pulling our tent trailer.
    On four or three, it's me.:wave4:
    Sep 2014
    Moneta VA
    I have a large Oil cooler on my Trike also.
    What I did not realize when I installed it that the oil lines cost more than the cooler itself.
    Thank you
    Bob
    Jan 2016
    Quote Originally Posted by Fowler View Post
    Lines can be spendy.
    I got a Hayden kit that came with hoses, clamps, and hose fittings. Not the best hookup, but ok if you keep an eye on it and change the hoses yearly.
    Braided steel lines and AN fittings will come when $$$ is available.
    Also added a 9" fan for when I'm grinding slow up those steep hills, and airflow is low.
    Quote Originally Posted by hawkeyefxr View Post
    Re: oil pressure, mine came with the full flow, and indicates 47-49 lbs.
    Showed no loss after I added the cooler either.
    30+ Posts
    Sep 2014
    yateley hants uk
    This is the one i have seen, not sure what pump i have on mine, did not know they even made different size pumps. Where do you get these. I am interested in looking into this more.
    Sep 2014
    Moneta VA
    I think I have a 32mm not a 36mm
    The old one must have been a 30mm
    Sorry for the confusion It was a long time ago when I replaced it
    I got it from Dans performance But any VW parts shop should have different sizes.
    I had a pic showing the difference in gear sizes but I guess when my son updated my web site he accidentally got rid of it
    Also if you take the pump off you can measure the height of your gears. That will tell you what size you have
    Be carfule when putting it back together that you use the correct gaskets in the correct location. Otherwise you may end up with to much clearance between the end of the gears and the plate
    In case you have not taken it apart here is a pic with the cover off mine
    Thank you
    Bob
    30+ Posts
    Sep 2014
    yateley hants uk
    Cheers for that info,i will look on Dan's site.
    I am in the UK and i have not seen one over here, if i order from the US customs slap their price on as well so what you pay in the US tranlates to UK pounds, not good. Anyhow thats another story, i will still look around.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Another place that is great to deal with is CarCraft:
    http://carcraftstore.com/
    Here is probably the one that you are wanting to install including the "bypassed" oil pump: http://carcraftstore.com/oilfilterpumps.aspx
    And it gives you the option on the 3 rivet or 4 rivet camshaft.
    However, keep in mind that if you ever decide to install a merged 4 in 1 header system these pumps WILL NOT work with the merged header. You cannot install the oil filter!
    In fact, the rep from CarCraft sent me the new pump for free because they did not have that disclosure on the merged header.............Now they have the disclosure. :
    http://carcraftstore.com/mergeexhaustsystem.aspx
    I had that exact pump, and still have it in a box, and when I purchased and installed the 4 in 1 merged header I had to buy a totally different oil pump front plate. I ended up relocating my oil filter and running hoses to it.
    Just an FYI if you ever do decide to buy a merged exhaust system.
    Sep 2014
    Moneta VA
    My exhaust is kind of close to the filter but I can still get it off
    Last summer I used a shorter filter thinking the exhaust would heat up a long one to much
    In the colder months I used a longer filter
    I think this summer I will stick with the longer filter and just keep a eye on it. If it becomes an issue I will switch back to a short filter
    Thank you
    Bob
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    With the merged header there isn't even enough room for the shorter filter.
  1. K&N Filters?
    By DblTrbl in forum Yamaha Trikes
    Last Post: 12-23-2014, 03:20 PM
  2. Open Air Filters vs. Covered Air Filters
    By seabiz in forum Harley Trike Conversions
    Last Post: 03-08-2013, 05:58 PM
  3. Oil Filters
    By rickt in forum Honda Trikes
    Last Post: 07-10-2011, 02:27 PM
  4. Gas flow question...........
    By Big_Steve in forum Honda Trikes
    Last Post: 08-12-2010, 05:19 PM
  5. oil & filters
    By Road Runner in forum Stallion Trikes
    Last Post: 04-23-2009, 11:18 AM
