Likes Likes:  3
Thanks Thanks:  3
Results 1 to 10 of 10
Thread: Considering a Purchase
    100+ Posts
    Sep 2015
    Lexington
    Default Considering a Purchase
    I've ridden a trike for several years, but sold my Tri Glide last year after being advised by a doctor to take a year off riding. My neuron eval is next week, and I'm likely to be cleared.
    I'm seriously considering an RT model.
    Is there anything I need to know such as recalls, recommended modifications, etc? When I bought the Glide, I was unaware of the heat issues and really did not appreciate the time, effort and money required to bring it up to what I considered should be factory specs, so that's kind of what I'm looking for.
    Oct 2010
    USA
    I went from a Tri to a 14 RT Spyder.
    Somethings that do stand out.
    • Make sure the dealer does a Laser alignment if you decide to by one
    • Takes some getting use to with the inverted from end versus rear.
    • I love the semi auto shifting
    • Dont miss the clutch handle
    • drive like a Cadillac in My Opinion
    • Tire pressure and Tires are a big topic on these Bikes.
    • Farkles Anything you want
    • Power steering is even better
    • Yes its does have plastic to take off to do oil changes and things
    I love the ride. I did replace the tires over time and made it even better,Baja Ron Sway bar helps a lot too. Now its even better than stock.
    Lighting is a nice extra option.
    Just upgraded my shocks but stocks are fine too.
    Does that help any
    100+ Posts
    Sep 2015
    Lexington
    Helps a lot, thanks. What you DIDN'T say tells even more. When I asked for similar input on another, uh, vehicle, I was referred for several thousand bucks worth of upgrades.
    Do I need a laser alignment on a new trike? Just wondering.
    100+ Posts
    Sep 2015
    Lexington
    Thank you. I will check it out.
    Oct 2010
    USA
    Quote Originally Posted by Fredward View Post
    Yes it is HIGHLY recommended to get the laser aligned. If you buy new it should already be done but ask if they do it that way.
    What I didn't tell you was HOW Happy to get my ass off the TANK on a Spyder. I was a Die Had Harley Fan but the crapola parts and tired of wrenching on it. They test rode a Spyder and been on it even since.
    The Spyder lovers site has lots of info but lots of conflict info at times
    Test ride one and see what you thing. Sometimes certain bikes and not everyone preferred for riding.
    OH I will tell that stock seat if horrible but everyone has different fanies and preferences.
    Plenty of info out there on the SPyder
    Sep 2012
    Lakeland, FL
    Mutha, I've read on the lovers forum that the RTL seats are the best they have ever ridden, but as you say, different behinds, etc. I know the seat on the RTL demo was as comfortable as I have ever experienced, but then, that's 20 mins or so. Can't draw good conclusions from a short ride.
    Oct 2010
    USA
    Some like them some dont. They are great the first Hour after that I found myself sliding forward and never got comfortable. Like I said Each Butts and body's are different and sometimes need a better option
    My Ultimate seat been really good for me. and for the Wife. I dont hear her Groan as much
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    Lazer alignment is usually not performed by dealers by should be done ASAP usually by an independent contractor. Squared Away is probably the best known. They can usually be found at many of the Spyder rallies. As to the seat,I found that the seat was not good enough for long distance or great amounts of time. I solved that problem by putting in a gel pad from motorcycledave.com. Heat,I don't think this is a problem on the 1330,but there are block off plates you can add easily and cheaply. I added a BajaRon Swaybar to mine but I rode it for a year first. It did make a big difference. I also went to car tires all the way around but waited until the factory tires wore out.
    Happy TRAils/NSD
    Paul
    Sep 2012
    Lakeland, FL
    Hey Paul, do you ever ride two up on your RT? If so, any problem packing for a road trip?
    I don't for very far as my wife wont ride very long. I also have a trailer in case she changes her mind.
    Happy TRAils/NSD
    Paul
  1. Considering a Stallion
    By Oldmanwheeler in forum Stallion Trikes
    Last Post: 01-18-2019, 07:48 AM
  2. Newbie Considering Conversion Kit
    By pegbead in forum New Member Introductions
    Last Post: 06-20-2011, 08:24 AM
  3. Newbie Considering conversion
    By pegbead in forum Miscellaneous
    Last Post: 06-13-2011, 04:45 PM
  4. Considering a Hannigan Trike
    By TnTrike in forum Harley Trike Conversions
    Last Post: 08-04-2010, 02:07 PM
  5. Considering a Motor Trike?
    By BlueTrinity in forum General Discussion
    Last Post: 03-09-2010, 06:47 PM
