SSpoon11hogmemberisoldNew Member Introduct...Hello from VA
SSpoon11ol' schoolNew Member Introduct...Hello from VA
SSpoon11Marc HNew Member Introduct...Hello from VA
SSpoon11ZammyNew Member Introduct...Hello from VA
SSpoon11Uncle FesterNew Member Introduct...Hello from VA
SSpoon11rhino 2New Member Introduct...Hello from VA
SSpoon11trike ladyNew Member Introduct...Hello from VA
SSpoon11SullyNew Member Introduct...Hello from VA
SSpoon11Jack KlarichNew Member Introduct...Hello from VA
SSpoon11GorillaNew Member Introduct...Hello from VA
SSpoon11SSpoonNew Member Introduct...Hello from VA
Likes Likes:  10
Thanks Thanks:  3
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 53
Thread: Wheel Bearing / Caliper drag ??
  1. #21
    100+ Posts 1 triker's Avatar
    Dec 2018
    Hempstead,tx,Waller County
    good morning. in a previous thread you said your brake pedal would not come back up, did you figure out what that problem was. I would change the clips and spring washers, there is a lot of heat buildup in this area and the spring washers loose there springness and then the pin rattles around and falls out over time, also lets the rotor wabble back an forth. the pedal not coming back up happened to me on a ride last fall stopped at a light and pedal just stuck down, brakes were all locked up. was able to pull up pedal and limp home. ended up being master cylinder.
    good luck
    dragon
    Thanks, I will look at that today. I hope I can get a replacement spacer and hex head bolt that was missing.
    # 796
  2. #22
    Dec 2018
    After taking the hub apart I found a hub seal only on one side. Shouldn't there be one for both sides?
    # 796
  3. #23
    Quote Originally Posted by 1 triker View Post
    yes on both sides. it is hard to get the axle through the 2 which is why it was probably left out.
  4. #24
    300+ Posts
    Signal Mountain Tn
    To make insertion of the axle easier, I had a piece of stock machined the size of the axle, and the length the thickness of the wheel and hubs. It is easy to insert the dummy axle, then when the wheel is in place just take the axle and push it through. A piece of wood dowel would probably work also.
  5. #25
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by trikervet View Post
    When you remove the axle, just slightly bevel the outer edge on one or other ends so it is not being forced thru and you will never have that issue again. I have posted this years ago. Tomg
  6. #26
    Dec 2018
    Thanks to both who replied.
    # 796
  7. #27
    Dec 2018
    Hi, can someone tell me where can I get the outer seal for the hub? I bought one from the auto part store but the axle will not pass thru. OOpppsss, just found it at Amazon.
    # 796
  8. #28
    I had to trouble getting all my seals from NAPA part #s on my post on this repair.
  9. #29
    250+ Posts
    Dec 2010
    oly,wa
    the inner seal I have had to wait a week to get one, the outer seal usually have it, if not overnight.
    Dragon
  10. #30
    Dec 2018
    NAPA wanted $23.00 to ship the seal to there store.
    # 796
  11. #31
    250+ Posts
    Dec 2010
    oly,wa
    o'reily wanted 8 dollars for shipping
    Dragon
  12. #32
    Dec 2018
    HELP! lol, I have the new seals but I still can not get the axle thru them, what's up with that??
    # 796
  13. #33
    300+ Posts
    Signal Mountain Tn
    Did you try poking the axle through with the wheel off the bike just to see if it would go?? Too late now, but if you had ran the seals down over the axle before installing them then you could rule out "seals wrong size." Just a thought.
  14. #34
    Oct 2009
    Titusville, Florida
    A couple of years ago I purchased my bearings and seals for Locate ball bearings and the seals were about $3 each. They either shipped for LA or Chicago. Received in a few days.
  15. #35
    Dec 2018
    I tried to get the axle to go thru the seal with the wheel off but no luck.
    # 796
  16. #36
    300+ Posts
    Signal Mountain Tn
    This is the part number I have for the wheel bearing seals: 470625
  17. #37
    Dec 2018
    Good morning
    I would follow along jacks advice but I would just take the wheel off and repack the tapered bearings with new seals (15 dollars each). I don't know how many miles you have. smell the grease from each bearing, if it smells burnt at all it needs to be changed. I am in the process of replacing these bearings and races right now. at least you will know if it is a bearing.
    Good luck
    Dragon
    Hey, what seals are you using and the part number? I have tried 3 different seals and the axle will not go thru and the seal just slide in the hub without much resistance. They all had id of 1.125.
    # 796
  18. #38
    Dec 2018
    I found it, but can not get the id and od on them. Did you get any specs on them?
    # 796
  19. #39
    300+ Posts
    Signal Mountain Tn
    There are quite a few listed on Ebay. You may find one that has the specs listed.
  20. #40
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I googled that number and the first two to come up had the specs listed.
  1. Clutch drag
    By Boom in forum Harley Trike Conversions
    Last Post: 07-18-2015, 04:59 PM
  2. front wheel bearing honda vt750ca with motortrike roadhawk rims
    By leatherandflames in forum Honda Trikes
    Last Post: 01-13-2015, 11:16 AM
  3. Front Wheel Bearing??
    By delta in forum Harley Tri Glide
    Last Post: 07-11-2014, 03:48 PM
  4. Voyager wheel bearing
    By sirkitrider in forum Outrigger Style Trikes
    Last Post: 03-26-2013, 06:49 AM
  5. Bad Front Wheel Bearing
    By Oldmsocko in forum Harley Trike Conversions
    Last Post: 08-29-2011, 09:24 AM
