Likes Likes:  11
Thanks Thanks:  3
Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
Thread: Parking Brake Hex Bar Adjustment
  1. #21
    90+ Posts
    Jun 2018
    Forney, Texas, USA
    OK, using vise grips on the silver metal barrel spacer, I finally got the ADJUSTER HEX cover to come loose so that when I turn it to the right(clockwise), the number of screw threads are visibly increasing. So far, I have added over 1" of visible threads turning the ADJUSTER HEX cover. However, the trike still moves back and forth in a 3 to 4 foot span distance with the Parking Brake's pedal set on the 4th click. How much more screw threads distance do you think I am going to have to make visible before I see the Parking Brake pedal holding the Trike on the 4th click or do you think I have already gone to far indicating I need to replace the rear brake pads? On your Trike, how much screw thread distance do you have between the silver metal barrel spacer and the ADJUSTER HEX cover with the JAMNUT screw threads included? Thank you, Allen S.
  2. #22
    There is a possibility your pads may be worn
    However ,lengthen the adjuster till you get to 2-3 clicks and the trike does not move, press your rear brake pedal after making your adjustment also, it should be firmer and a bit higher
    Get your rear brakes inspected to be sure the pads are OK
    I have a lot of threads exposed on mine, I keep my pedal adjusted for best parking brake holding and optimum rear brake pad adjustment
  3. #23
    90+ Posts
    Jun 2018
    Forney, Texas, USA
    Thanks Jack, Both You and MDO have been a lot of help. The instructions in the HD Service Manual makes the process very simple if everything is work as it should. However, in this case, everything did not work as it should plus the Service Manual does not state if more or less screw threads need to be visible when performing the Parking Brake Pedal Adjustment. Once again, thank you both for all your help. I will let you know if and when I finally get the Parking Brake Pedal to hold on the 4th click. Allen S.
  4. #24
    Thumbs up
    Good Luck and keep us all posted
    MDO ( Michael is my partner in crime) He always has good info you can stand on
  5. #25
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Your going to have to get that adjuster pretty hot to break it free
    Use a vise grips on the other end, go easy, if it does not come free you will need more heat
    I use a spray can of Liquid Wrench on corroded/rusty parts, it has worked wonders for me. I use some silicon spray for general lube of pivot points/hinges.
  7. #26
    Oct 2017
    St. Louis, MO USA
    Thanks Jack, I have good info, unless I'm wrong. You sir are a mechanic, I am a garage hack the Navy taught to use a meter & turn a wrench in a limited form. On my subs, Missile Techs had to take care of the missile & launching system, which included electronics, electricity, hydraulics, pneumatics & water systems, so I got a little of everything, but I was an expert in none, just enough experience to get by.
  8. #27
    Thumbs up
    You pay attention to detail, ask all the right questions and give help based on your experiences.
    What more could anyone ask for.
    Keep on qualifying the members questions, together we will get it right and have a positive impact on the community here
  9. #28
    90+ Posts
    Jun 2018
    Forney, Texas, USA
    Hi Jack/MDO, Just wanted to give you an update on trying to loosen the threads inside the ADJUSTER HEX cover to adjust the Parking Brake pedal. The silver metal barrel spacer I was trying to hold and stop from turning, using vise grips, split and formed a crack on the side of the spacer from the vise grips applied pressure/teeth allowing the whole parking brake mechanism to, once again, turn while turning the ADJUSTER HEX cover. In turn, after a few "*#$!@*" choice words, I decided to tighten down the JAMNUT up against the ADJUSTER HEX cover and use a 1" Velcro strap to "pull-in" the front brake lever to the twist throttle if I ever need to park the TRIKE on an incline/decline in first gear. It is so seldom I use the Parking Brake, it seems to be most economic thing to do unless there might be a reason it would damage the Trike. In case I want to have the Parking Brake linkage repaired, do you happen to know if a new silver metal barrel spacer, threads insert, and ADJUSTER HEX cover can be installed after the OEM ones have been removed?
    Once again, thanks for all the help.
    Allen S.
  10. #29
    # 29 is the front cable with adjuster, it aint cheap
  1. 2018 TG Parking Brake ...adjustment question
    By midiwiz in forum Harley Tri Glide
    Last Post: 09-14-2018, 10:02 PM
  2. Handle bar adjustment.
    By guatdoc in forum Honda Trikes
    Last Post: 07-12-2016, 08:19 PM
  3. Rear Brake Adjustment
    By eastkytriker in forum Honda Trikes
    Last Post: 05-19-2015, 09:02 PM
  4. Handle Bar adjustment for comfort
    By MMH in forum General Discussion
    Last Post: 02-12-2014, 10:58 PM
  5. Hand brake adjustment C90 Lehman Jackal
    By dadorfman in forum Lehman Trike
    Last Post: 12-21-2012, 09:00 AM
