Likes Likes:  3
Thanks Thanks:  2
Results 1 to 9 of 9
Thread: Tramp Driveshaft lube
    60+ Posts ProudTexson's Avatar
    Dec 2012
    Big Spring Texas
    Default Tramp Driveshaft lube
    2008 Lehman Tramp. 28000 Miles. I have been trying to find anything about Driveshaft inspection or Lube of spline end that goes into the Transmission. I would be thankful for any info on this. It looks to be a major job but I can do it if need be. Just need to know how or if it is needed.
    Thank You everyone in advance. The ProudTexson
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Dave, I'm sure Jim (Lee H Mann) will see this and chime in, might take a day or so.
    Dec 2012
    Big Spring Texas
    Quote Originally Posted by Zammy View Post
    Thank you
    +1 ... he's the resident Lehman guru.
    Dec 2012
    Big Spring Texas
    From what I can find from reading I will have to take the differential loose and move it back to pull the drive shaft out. I guess until I find out for sure I will just not worry about it.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Quote Originally Posted by ProudTexson View Post
    No need to remove the driveshaft. The only joint needing lubrication is the rear u-joint. I have never seen a driveshaft failure on a C-50 and I know of several that have over 80K on their rides.
    Jim Murphy
    Iron Butt Rider 2001
    Dec 2012
    Big Spring Texas
    Thank you very much. That’s such good news. I keep the rear u- joint lubed. Thank you again for being here to help us out.
    60+ Posts
    Apr 2017
    Sunbury
    This is good to hear I to was wandering since ours has over 40,000 . I just give it a shot of grease in the joint several times a season here in northeast. Thanks for the info.
    Sep 2016
    Springfield, Mass. USA
    I own the Roadsmith model (2010 Goldwing) and shot a bit of grease into the spline w/o a problem...Jack it up, and place a jack stand under (FOR SAFETY) using a grease gun, place on grease jurk and pump a couple of shots up onto the spline... ********* Don't over lube/as soon as you see grease oozing out...stop!***********
  1. Lube Your Harley Clutch Lever
    By Jack Klarich in forum Harley Freewheeler / Road Glide 3
    Last Post: 09-17-2017, 05:10 PM
  2. The Frog Lube trial.
    By Jimsjinx in forum The Gun Enthusiast
    Last Post: 11-03-2013, 08:43 AM
  3. drive shaft lube
    By geraldlanc in forum Honda Trikes
    Last Post: 04-11-2012, 09:00 PM
  4. lube procedure
    Last Post: 04-11-2012, 08:47 PM
  5. lube for 7.5" ford rearend
    By steamer in forum Harley Trike Conversions
    Last Post: 01-21-2012, 01:00 AM
