LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  9
Results 1 to 19 of 19
Thread: thanks
    May 2022
    louisville,KY valley station
    Default thanks
    i have an 05 FLHTCUI that has a bad wobble in front. MECH. is confused on what to do to fix and is there anyway to tell what kit is on the trike ?
    Quote Originally Posted by bob21430 View Post
    Hey👍..Bobby Welcome to Trike Talk…👍👍.
    And A little more info would be helpful..
    May 2022
    i edit the post a little. we replaced the Heim rod ends. what info will help ? and i can try and figure this thing out.
    A picture of the Trike/Kit/ body would help somebody identify the kit for you..
    Jun 2008
    Lovington, NM, U.S.A.
    Sounds like you have a Motortrike, but a picture of the body would be helpful. Have you tightened the steering bearings? Does the trike have raked triple trees (AKA Ez-steer).
    Retired trike builder
    the pics you did post are they where the swing arm attaches to the frame?
    May 2022
    Yes where it attaches to the trans
    May 2022
    Quote Originally Posted by trike lady View Post
    i have been told they didn't rake it at all
    May 2022
    hope these help
    May 2022
    also he has put air values in the front forks to add air to
    looks like a motor trike to me.
    And that mount looks like it's cracked. I cannot now remember where I read that that was an issue, but if it is that could be part of the problem.
    May 2022
    unsure what a "motor trike" is it also has the screaming eagle package on the motor. used to have a small wobble around 20 or 30 mph and I could throttle though. i replaced front tire with used tire I know bad ideal. drove it less than 100 miles and was on express at 70 mph and it tried to shake my wife off. was able to get off express and do back roads fine. Now my mech can get the wobble to stop. he told me that crack was trans where swing arm mounted but I will ask again. he think I might have to replace the whole rear end and i don't know if I have the money for it.
    Jun 2008
    Motortrike is the brand of conversion. They should have installed an EZ-steer, as it makes the trike easier to steer. If the motorcycle frame is cracked, it will be a big job to disassemble the motorcycle, remove the neck and get a replacement frame from HD and this is an expensive job.
    May 2022
    i will ask my mech. again i believe the pics he sent me was the top of the rear def. were the bike attaches but i will double check. there is no east steer on the neck and the neck is not cracked.
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Nice looking trike - does indeed look like a MotorTrike - the rear on my GW looked the same.
    I no longer have that Wing - but as I recall, I had to put a rake kit on to make it steer easier. My bike had a 3% rake. My new Harley trike is a CSC conversion and has an 11% rake.
    Hope it all works out for you
    May 2022
    being told this iso. plug is a known problem in Harleys. now i have to look for a Mobile TIG Welder to fix case and then have to by new Billet Isolators. and he says the crack is on the rear transmission where the pivot shaft goes though. he is speaking foreign lang. to me. for the Isolators he recom. Raw M3 from Mad Monkey Motorsports.
    May 2022
    More pics might help
    May 2022
    More pics
  19. #19
    Oct 2010
    USA
    May be better off to get a good used transmission or new one . Why did that crack like that?
  1. Thanks Dave and Dave
    By bdn56 in forum Harley Trike Conversions
    Last Post: 07-26-2010, 08:46 PM
  2. I wanted to say thanks for the help!
    By 5thwheel in forum General Discussion
    Last Post: 06-24-2010, 11:58 AM
  3. Triked at LAST THANKS To All For
    By TRIKERBOB69 in forum Honda Trikes
    Last Post: 04-23-2010, 05:00 PM
  4. Thanks for the Experienced rider post
    By retnavyflyr in forum General Discussion
    Last Post: 10-11-2009, 10:41 PM
  5. Thanks Bazooka!!!!!
    By Jimsjinx in forum General Discussion
    Last Post: 03-22-2009, 03:34 PM
Tags for this Thread
