Results 1 to 6 of 6
Thread: Honda GL1800 with lehman trike rear rotors
    Sep 2015
    bernardston
    Default Honda GL1800 with lehman trike rear rotors
    I need rotors for my 2007 wing with the Monarch II. $500 plus for a couple rotors seems a bit much. Has anyone ever found another rotor that can be used? I've read earlier posts but haven't seen an answer.
    Any one have the info for him? Welcome to your first post
    Jun 2010
    Indianapolis, In.
    Are they warped?
    You can have them turned just like automotive/truck rotors.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by warren View Post
    There are other rotors that can be used, but they require changing the brake system; calipers and all. More expensive ......
    Get the rotors while you can b/c they will not be around forever.
    http://mjtrikes.com/shop/index.php?m...roducts_id=289
    http://www.ebay.com/itm/201805685413...84.m1555.l2649
    Jim Murphy
    Iron Butt Rider 2001
    Sep 2015
    bernardston
    Thanks for the info. I wouldn't be against changing out the rear system if over the counter parts could be used. I'd even be OK without the parking brake setup. I grew up with a GM mechanic for a Dad, spent 13 years managing an auto parts store and retired after 25 years with the state. This is my 1st trike after riding BMW's for years. I've got it up of the lift in my shop for the winter and both rotors are scored. With the relative thinnest of the rotor I don't believe that it can be turned down.
    It's winter up here in Massachusetts so it's a good time to work on it. Would you be willing to share more info on what alternative parts could be used? It's good to know that you do have the original rotors if I change my thinking. thanks, Warren
    Martinsburg, WV
    PM sent..............
    Jim Murphy
  1. Rear tire sizes for gl1800 lehman monarch ii trike
    By Motogordo in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-24-2016, 10:23 AM
  2. Honda GL1800 rear brake recall
    By JaysGone in forum Honda Trikes
    Last Post: 04-01-2016, 02:25 PM
  3. Lehman brake pads and rotors
    By gwetts in forum Lehman Trike
    Last Post: 01-18-2015, 07:21 PM
  4. Lehman gl1800 trike trunk seal
    By DeerWrangler in forum Honda Trikes
    Last Post: 08-25-2011, 04:09 PM
